Old 10-18-2011, 01:17 PM   #1
vettedad61
hood vibrate solution
my hood vibrates on my 72, do they sell something to go between the hood and hood support to stop this?
anyone ever use something homemade or from lowes etc to fix it?
I am looking for something that fits and looks as if it was factory.
Thank you!
vettedad61 is offline   Reply With Quote
Old 10-18-2011, 01:19 PM   #2
shawno72
C/10 junkie
shawno72's Avatar
Re: hood vibrate solution
I am looking forward to some answers for this as well.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 10-18-2011, 01:29 PM   #3
leddzepp
Moderator
leddzepp's Avatar
Most vendors carry the pads that squeeze between the hood and the supports...Brothers and LMC have a nice diagram in their catalogs. There are also rubber bumpers and adjustable stops to keep the hood shut tight.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
leddzepp is offline   Reply With Quote
Old 10-18-2011, 01:29 PM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
That's what these little guys are for.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 10-18-2011, 02:32 PM   #5
beautimus
beautimus's Avatar
as already said before, make sure the hood is down on the bumpers all the way around first, then yes, most of the vendors sell the pads that go between the support ribs to keep the center of the hood from vibrating up and down in the air stream. i have not seen the foam pieces that go in the bracing above the hood hinges however. But maybe on of the board vendors will chime in about those for us. best of luck to you, Tony
i survived cancer and kidney stones, but my kids are killing me.
beautimus is offline   Reply With Quote
Old 10-18-2011, 02:45 PM   #6
RenoKeene
Florida Edition
RenoKeene's Avatar
I haven't found the ones above hinges yet but I'll probably get some high density foam sponges, dye them black, cut em the size I want and swedge em in there.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 10-18-2011, 02:46 PM   #7
68gmsee
Active Member
68gmsee's Avatar
Are you referring to the center line of the hood vibrating up and down?
As mentioned above replacing all the rubber pads should eliminate a lot of the movement but one word of caution on the hood brace pads. Use extreme care when prying the brace and the hood apart to insert the pads. These pads are a lot thicker than the ones on the hood now and the hood sheetmetal is easily bent if using the wrong tools.
I made wooden wedges out soft wood and pushed it in to pry the support and hood apart. Any wide wedge that's non metallic should work just don't force it in by hitting it with a hammer. I made a small bump on the top of mine on one side that I had to repair.
68gmsee is offline   Reply With Quote
Old 10-18-2011, 08:03 PM   #8
squirel
squirel's Avatar
If the center vibrates up and down you could do what I did and add an extra brace from an old hood that was rotted out. You do need to cut a section out of the center but it sure strengthens up the hood.
In some foreign language "merge" means to stop and turn your head left.
My build page
http://67chev.shawwebspace.ca/
squirel is offline   Reply With Quote
Old 10-19-2011, 12:53 AM   #9
edhtrd71
Dont know where to get them but my truck originally had long strips of foam like padding in between the hood and the underhood supports. They kept falling out after I had the hood repainted so I tossed them (stupid I know). My wife asked me the other day at about 85mph is the hood ok? It looks like its gonna open. It would be nice to have them back.
edhtrd71 is offline   Reply With Quote
Old 10-19-2011, 07:14 AM   #10
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
I have so many little projects going on, but one I'm going to do is make a cross brace from the small channel brace I took out from under the bed when I re-did my exhaust. That hood "bowing" in the middle is not necessary. I've checked it out and have a design in my head. BUT, like I said, too many others in line. I'll do pics when I get there. Should be mostly time, not much money - My kind of project!
TobyArnot is offline   Reply With Quote
Old 10-19-2011, 10:33 AM   #11
68gmsee
Active Member
68gmsee's Avatar
Read previous posts above....
Old 10-19-2011, 09:30 PM   #12
pritch
pritch's Avatar
I'm going to face this issue pretty soon myself. I wonder if you could get it braced where you want it and then use a urethane caulk or something. I would think that would be strong and permanent. Just one of those random thoughts that run through my mind sometimes.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 10-19-2011, 09:40 PM   #13
67swb72klb
67swb72klb's Avatar
i have seen problems with urethane (no give) and seem to suck the skin down imo i would stay with the foam
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 10-20-2011, 09:14 PM   #14
pritch
pritch's Avatar
Makes sense to me, I'll stay with the foam.
'68 Panel
'68 C-10
Ol' Green
Old 10-21-2011, 11:43 AM   #15
mbgmike
use the spray foam like they use in new vehicles now. Thats what its for. Unless you want an original look
mbgmike is offline   Reply With Quote
Old 10-22-2011, 10:09 AM   #16
alsriv2
alsriv2's Avatar
Location: Formerly MD and San Diego, now loving life in Arizona
That center brace is exactly what I need for my 2 trucks.
Where can I find that brace? I have not seen them on any chevy hood before, so I am not sure what you are referring to when a "old hood rotted out".
What make/model vehicle was the donor for your application?
Thanks!
Alan
alsriv2 is offline   Reply With Quote
Old 10-22-2011, 10:17 AM   #17
71sierragrande
Petroleum User
71sierragrande's Avatar
The old man used to have wood shims wedged in his '71 Cheyenne. Looked totally factory! (kidding) But it worked for an old DD...
1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto
2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto
71sierragrande is offline   Reply With Quote
Old 10-22-2011, 10:24 AM   #18
squirel
squirel's Avatar
The center brace is just one of the side braces cut down. I circled the side brace I used for the center brace below. I just had a old 67 hood that was rotted and had a fan go through it so I just cut one of the braces off it and then cut a piece out of it the middle to shorten it and the welded it up
My build page
Old 10-22-2011, 11:10 AM   #19
Andy4639
Orignal Goof member
Andy4639's Avatar
Question Re: hood vibrate solution
Can I ask what you speak of and do you have a link for it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 10-22-2011, 11:17 AM   #20
squirel
squirel's Avatar
Andy4639 here is one 3m makes
http://www.azautobodysupply.com/duflfo046flo.html
My build page
Old 10-22-2011, 11:23 AM   #21
Andy4639
Orignal Goof member
Andy4639's Avatar
Cool Re: hood vibrate solution
So you wouldn't be scared the stuff pushes out the hood when it rises. I was thinking tape one side of the brace off and fill with this stuff would help. Then cut off the rest that extends past the brace edge. This would also give it some place to go besides up. It will go to the least resistance right. So if one side is left open the foam would not push the hood away from the brace just fill the area between.
Old 10-22-2011, 11:31 AM   #22
68gmsee
Active Member
68gmsee's Avatar
Here's my attempt a few years ago at fixing the bow on an extra hood that I have. I gave up and haven't finished it but it looks like with a little massaging like bending the 1" square tube to conform to the hood, some rubber padding and tack welds or bolts, it would do the job.
I like squirel's method...
Old 10-22-2011, 11:37 AM   #23
squirel
squirel's Avatar
It does not push a lot I would just put it in there and let it expand out the brace and then trim it off after wards. This is the same stuff they use on factory vehicles and if it does not warp the metal on a flimsy honda civic hood it is not going to on one of our hoods
My build page
Old 10-23-2011, 10:55 AM   #24
vettedad61
This what I am going to buy to fix mine...Brothers trucks catolog on page 35 1-800-977-2767 Thanks for all the help and info
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
