Old 11-06-2011, 11:43 AM   #1
stomper
Junior Member
stomper's Avatar
Starter Brace or Bracket - What can I do?
Did my research and found 2 choices from Summit for my SBC. One had a picture that looked like it would work
http://www.summitracing.com/parts/NAL-354353/
the other - no pix on Summit website
http://www.summitracing.com/parts/NAL-03965588/
Information sort of lacking on Summit but determined one was for BBC so I ordered the other. I assumed it's the correct one for my SBC.
Now I see Sallee Chevrolet lists these:
http://www.sallee-chevrolet.com/Star...arts/index.cfm
#03965588 - Starter Brace BBC 168 Tooth,
#03965589 - Starter Brace SBC 168 Tooth,
#00354353 - Starter Brace 153 Tooth.
Summit sells a 153 tooth flywheel starter brace for SBC and not a 168 tooth? GRrrrr... I'm just venting now.
Can anyone reply that you got part number X from vendor Y and it worked for your 168 tooth flywheel SBC?
"I was patina when patina wasn't cool."
1977 Cheyenne SWB yellow/blue
stomper is offline   Reply With Quote
Old 11-06-2011, 11:51 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Starter Brace or Bracket - What can I do?
I would just cut that one off, drill a hole for the stud, and bolt it up. If you had to you could elongate the hole a little for some "wiggle" room. That one has a slot in it anyway so elongating the drilled hole wouldn't hurt anything.
Just my 2¢ worth..
LockDoc
Leon
Old 11-06-2011, 12:10 PM   #3
cdowns
cdowns's Avatar
that sure wood seem 2 b the fastest bestest way to get it done
Old 11-06-2011, 12:43 PM   #4
stomper
Junior Member
stomper's Avatar
Thanks for the quick reply guys. I wish the solution was that simple. Unfortunately it's not as easy as drilling a hole in the brace. In the photo the starter and brace are fastened tightly to the block. What you can't see is there is a little space between the stud and edge of the brace. The brace does not have any 'meat' around the stud for a hole.
If I drill a hole in the brace at the proper height, fastening it down would pull the FWD end of the starter toward the block and the nose away from the flexplate. The purpose of the brace is to help keep the starter gear engaged with the flexplate.
I could smash and bend this brace so that it fit - but gee I just spent $10 for a proper part. I might as well start with a piece of angle... ...and I'm going for a nice clean install so a smashed brace or piece of farm engineering is not what I want.
Anybody know what GM part #03965589 looks like or if it works for sure and where you got it?
Old 11-06-2011, 01:23 PM   #5
too much stuff
Roadtrip!
too much stuff's Avatar
3965589 looks a little different than what you have. There is no slot. It is listed for a 66-70 small block. It is still available from GM for less than $10
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 11-06-2011, 01:47 PM   #6
bigkountry
Family Man
bigkountry's Avatar
You could always do a pie cut relief towards the top, bend it out to the correct angle, weld the relief spot, grind it down and rattle can it. Then you could do the elongated hole like suggested above and it would look like it was made to fit.
70 SWB....in peices waiting for the new shop to be built!
bigkountry is offline   Reply With Quote
Old 11-06-2011, 10:35 PM   #7
stomper
Junior Member
stomper's Avatar
Found a pic
http://www.gmpartsdirect.com/results...number=3965589
Looks like what I need but I thought that about the other one....
Ill give it a try on my next parts order.
Old 11-07-2011, 01:28 AM   #8
Livrat
Member #1049
Livrat's Avatar
Jared, just stop on by the shop and I'll give you one, bring the one you have so we can make sure you do not get a wrong one
Livrat is offline   Reply With Quote
Old 11-07-2011, 01:47 AM   #9
stich626
heat the brace at the top just under the bolt holding it to the block and give it a little bend.. then cut a hole for the stud.. no one will know after you paint it and it'll now work with both starter types..
stich626 is offline   Reply With Quote
Old 11-07-2011, 02:05 AM   #10
FLEET72
FLEET72's Avatar
I think LockDoc Meant:
Oscar
'72 Shortbed Fleetside
'95 Jimmy 4X4
'69 GMC Custom Camper
FLEET72 is offline   Reply With Quote
Old 11-07-2011, 03:13 PM   #11
stomper
Junior Member
stomper's Avatar
Fleet72 - DOH! OK I'm an idiot. That should work.
Mark - Thanks. Fleet72 has pointed out a good solution. I'm sure I'll see you soon anyway. PM'ing you a question
Thread Tools
Display Modes
Copyright ©2000 - 2023, vBulletin Solutions Inc.
