Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1988-1998 Chevy & GMC Pickups Parts Board
Old 11-21-2011, 10:53 PM   #1
VH Coachworks
VH Coachworks's Avatar
Complete Dome Light with WHITE LED's intstalled!
Up for sale is a Dome Lamp out of a 97 Suburban. It has high power white SMD LED's installed in all 3 locations (2 map lights & the main dome light). The LED's are the biggest and brightest LED's that will fit, and they are BRIGHT!! Below are a few pictures of the LED's on, to show how bright and intense in color they are! VERY nice upgrade!!
This will fit all 88-98 Chevy & GMC truck models (regular cab, extended cab, tahoe, suburban etc)
Asking $49.95 shipped to the lower 48 states.
Thanks for looking!
1949 Chevy 3100 5 window shortbox - soon to be stretched, chopped and Camaro Sub-Framed' "Grandpa Ed I"
1967 Chevy C/10 SWB - 327/3 on the tree "Grandpa Ed II"
1994 GMC K2500 ECSB - 350/4L60E "Mean Green"
- VH Coachworks -
Facebook
67-72 Chevy HD Headlight Harness's For Sale HERE
67-72 Chevy & GMC Ground Strap Kit's For Sale HERE
67-72 Chevy Rear Speaker Enclosures For Sale HERE
67-72 Chevy Power Door Lock Kit For Sale HERE
VH Coachworks is offline   Reply With Quote
Old 11-26-2011, 09:36 PM   #2
ScottH
ScottH's Avatar
Re: Complete Dome Light with WHITE LED's intstalled!
can u post a pic of the back? Would like to see how it could be mounted, thinking of using it in a different vehicle.
thanks
Scott
1972 C10 lwb fleetside
1966 GMC G1000 van
1955 Chevy sedan delivery
1946 Chevy half ton swb
1936 Ford 5 window coupe
ScottH is offline   Reply With Quote
Old 11-27-2011, 01:27 AM   #3
VH Coachworks
thanks
Scott
Sure Scott, here is a picture of the backside where it mounts. It mounts with 2 Phillips screws, that are located in the center of the housing.
If you have any other questions please feel free to ask!
- VH Coachworks -
Facebook
Old 11-27-2011, 07:42 PM   #4
jb1016
"Oh well, it's a driver."
jb1016's Avatar
I'll tell you up front, I can't spare the $50 right now, but I'm curious...would this mount in the stock location in an early interior? (1993 in my case)
Very cool upgrade. The factory dome light leaves a lot to be desired in my truck.
Old 11-28-2011, 03:02 PM   #5
VH Coachworks
Yes sir, this will mount directly up to any 88-98 interior. All of the 88-98 trucks shared the same dome lamp, and these are a direct bolt in to the trucks!
- VH Coachworks -
Facebook
Old 11-28-2011, 10:26 PM   #6
jb1016
jb1016's Avatar
Sweet, that's good to know.
Old 12-03-2011, 11:09 AM   #7
chevytrucksonly
chevytrucksonly's Avatar
Not clear about statement below-mount directly to a Burb or c/k Truck. However they will not mount directly as a replacement to a Truck lamp without cutting original mounting brace and trimming sheet metal so the back of map/doom light(that you have pic of) will recess up flush.
94 Chevy 6.5 Turbo Diesel 2500 HD
BD Power - 4 inch exhaust and Turbo Down pipe, Towing Towing chip and intercooler
FSD cooler relocated behind d/s battery with air ports
Duramax fuel lift pump with digital sytem
Jet HD 4L80-E transmission with deep pan
410 semi-float HD rear axle
Dual Thermostat Water Pump
12k Hydraulic winch with custom built bumper
Custom Interior with Buckets, center and overhead console etc
3 Pod gauge setup
chevytrucksonly is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright 1997-2009 67-72chevytrucks.com
