Old 11-26-2011, 10:32 AM   #1
blfuller123
blfuller123's Avatar
68 build...south of DFW
I thought I would post my build. The truck is a 68 GMC SWB. I got the truck and the rockers had been replaced, it had a 350/350 engine and transmission. The truck had been converted to 5 lug on the front, but still had the 6 lug rear end with leaf springs. It also came with a set of 17 inch billet wheels and tires. I think I will be swaping to some 20 or 22 inch. I will be swapping the front end from the 4 headlight gmc to a 2 light chevy. I am using a posi rear end out of a late model camaro with the disc brakes.
Here is the truck the day I brought it home
blfuller123 is offline   Reply With Quote
Old 11-26-2011, 10:35 AM   #2
blfuller123
Re: 68 build...south of DFW
I got the body off the chassis and got it moved into the shop.
Old 11-26-2011, 10:38 AM   #3
blfuller123
I was looking for a chevy core support and grill and ran across this complete front clip that I couldnt pass up.
Here is the rear end, it was a 5x4.75 so I redrilled the axles to 5x5. I got all of the brackets cut off and it is cleaned up ready to go.
Old 11-26-2011, 10:49 AM   #4
blfuller123
I got some work done to the chassis this week. I got the front cross member and rear leafs removed. I also removed the remaining crossmembers, got the frame cleaned up and painted.
I have my airbags, and drop spindles already. I have placed an order for a Porterbuilt front dropmember, a rear weld in notch, the bridge with the bags located on the inside of the frame rails, and the trailing arms/trailing arm crossmember kit. I decided to get the inner bag mounts in the event I decide to go with a really wide rear wheel and tire. I love the look but I havent commited to that route yet.
The last time I heard from Nate, everything is supposed to ship out by the end of next week.
Old 11-26-2011, 01:42 PM   #5
SCOTI
SCOTI's Avatar
Excellent start. Motor looks like it was fairly fresh?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-26-2011, 05:31 PM   #6
blfuller123
Im not taking a chance on the engine. It had just one bolt in the engine mounts, the ac compressor had one bolt going through the bracket, the transmission crossmember just had 2 bolts holding it in. at a minimum, I will pull off the heads and take a look at everything. I may just end up getting a crate motor and start fresh.
Old 11-26-2011, 06:19 PM   #7
mightymouse
mightymouse's Avatar
nice find on that 68 front/clip . keep pics coming
mightymouse is offline   Reply With Quote
Old 11-26-2011, 10:33 PM   #8
blfuller123
Pulled the heads on the engine and truns out the engine is a 305.
It looks like maybe a valve job has been done but the cylinders need to be machined. All of the accessories were just finger tight. Im thinking seriously about a crate motor now. I would like to get something mild with a lumpy cam.
Old 11-26-2011, 11:15 PM   #9
mcbassin
Still Learning
mcbassin's Avatar
looks like a great projoect. Im in
mcbassin is offline   Reply With Quote
Old 11-29-2011, 05:40 PM   #10
blfuller123
I got the drop spindles put together today and I got the rear calipers put back on the rear end and the rear wheels and tires mounted again. I have to leave out for work tomorrow and wont be home for a week but im hoping to have some parts by the time I get back.
Old 12-12-2011, 06:04 PM   #11
blfuller123
All of the rear parts made it Saturday. Im hoping the front dropmember will be here within the next week.
Finally got to spend some time on the truck today. I got the trailing arm crossmember installed, and the notches located. I got the notches about 1/2 of the way welded up. Im hoping to finish all the notches up tomorrow.
Old 12-12-2011, 07:01 PM   #12
kev2809
low n' slo
kev2809's Avatar
nice...lookin forward to this build!
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 12-12-2011, 10:03 PM   #13
Big-Blue
Big-Blue's Avatar
Saw you were thinking about a crate engine. Seems like these Year One engines are priced great and crank out 400 hp. I believe they are assembled at a engine shop around Texhoma. You could probably have them throw in a different cam and pick it up for cheap. As is they are under $3k.
http://www.yearone.com/serverfiles/f...ngine&SM=1&SC=
Big-Blue is offline   Reply With Quote
Old 12-12-2011, 10:16 PM   #14
mcbassin
Still Learning
mcbassin's Avatar
Man, that's a nice mess of new parts!
Old 12-13-2011, 06:01 PM   #15
blfuller123
Still havent commited to what I will do as far as the drive line goes, im still tinkering with the LS1 route. I ordered SBC motor mounts with the dropmember.
Got a little more done today. I got the frame cut and got the notches all welded up. Tomorrow I am going to try and get the rear end set in place and the airbag brackets welded up.
Old 12-13-2011, 10:36 PM   #16
69CST-V
69CST-V's Avatar
I'm in. Looks like a great start. What did you use on your frame?
Bryce
'69 SWB Fleet Still Under Construction
Company Trucks
69CST-V is offline   Reply With Quote
Old 12-14-2011, 03:05 PM   #17
blfuller123
I was able to get the rear end mocked up before I got a call to head out for work. I may get a little done Saturday, but after that, it will be after Christmas before I can do anything else. I didn hear form Nate and the front dropmember shipped yesterday.
Old 12-14-2011, 06:27 PM   #18
67cheby
67cheby
67cheby's Avatar
i am along for the ride, nice start !!
67cheby is offline   Reply With Quote
Old 12-14-2011, 06:58 PM   #19
gearheads78
gearheads78's Avatar
Nice build. I forced myself to not go look at that truck for two weeks. Glad to see someone doing something with it.
gearheads78 is offline   Reply With Quote
Old 12-14-2011, 08:36 PM   #20
blfuller123
I looked at it for a good month and a half before I picked it up.
Old 12-14-2011, 08:43 PM   #21
VA72C10
VA72C10
VA72C10's Avatar
Nice project! Looking forward to it!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 12-14-2011, 08:57 PM   #22
blfuller123
I got the rear kit with weld in notches. The pan hard bar mount is a weld in piece too. Anyone have pictures of where that mount goes? It looks like it goes between the frame rails somewhere but Im not positive. I didnt really have a chance to look at it. Also, the carrier bearing I have on my driveshaft has 2 holes pertty close together and the crossmember has them spread apart, are there two different carrier bearings?
Old 12-15-2011, 01:10 AM   #23
mcbassin
Still Learning
mcbassin's Avatar
Originally Posted by blfuller123 View Post
Still havent commited to what I will do as far as the drive line goes, im still tinkering with the LS1 route. I ordered SBC motor mounts with the dropmember.Got a little more done today. I got the frame cut and got the notches all welded up. Tomorrow I am going to try and get the rear end set in place and the airbag brackets welded up.
Definetly go LS if you want. I don't think you will be dissappointed.
You are doing a great job on all your chassis mods. Keep the pictures coming.
Old 12-15-2011, 10:36 AM   #24
tattoed71
tattoed71's Avatar
nice wheels
tattoed71 is offline   Reply With Quote
Old 12-15-2011, 08:12 PM   #25
blfuller123
Originally Posted by tattoed71 View Post
nice wheels
They will be fors sale soon
Thread Tools
Display Modes
Copyright ©2000 - 2021, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
