![]() Join Date: Feb 2011
1972 C20 Disc brake front hoses
Having fun trying to find the correct front brake hoses for my truck. I have purchased three different sets w/out success. The most current set purchased are long enough, secure to the caliper w/out issue, but will not secure to the frame properly.
I can push the line through the frame bracket, tighten the metal line to the hose ok, but the little push clips will not attach because the hose it not able to go through the frame braket far enough to get the clips back on. My original hoses were trashed, I never thought I would have a hard time finding correct hoses for a Chevy truck. If anyone has some originals they might want to sell, I would consider buying them and having them redone or if any one has run across this, I would like to hear their solution. Thanks in advance.
Jeff Horsman 1972 C20 Highlander "C" 1966 Olds 442 L69 four speed 1971 Skylark (GS clone racecar) 494 stroker 1986 Buick T-Type |
Sierra Grande Club
Re: 1972 C20 Disc brake front hoses
Where did you get the hoses? I wouldn't expect it to be hard to find either.
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
Several different vendors on the board, some were too short, others the ends were wrong. The best fitting thus far are from Brothers Truck Parts, but they still are not an exact fit.
Went through the same problem, no one has them. Brothers sent a pair. One was for discs, the other was for drums! Ended up making a pair out of braided stainless.
72 C10 suburban, lowered,nice original 55.1 Panel, bagged,old school 56 Panel,ls power,frame up build 72 C30 enclosed car hauler, 454,FI,4L80E |
TTT...anyone else have any ideas??
go to rockauto.com, never had any issue with stock replacement parts
"To speak of the art of one loom, the art of one river, the art of one tractor, or the art of one automobile is not preposterous; it is to point to the size and importance of the gap between general knowledge and situated knowledge" - James C. Scott 1969 C10 - http://67-72chevytrucks.com/vboard/s...d.php?t=492064 1930 Tudor Sedan |
#7 | |
well, my last suggestion would be just make a frame bracket of your own, a small piece of steel, self tapping screws, and a drill bit, should be easy as anything else.
Something could be made I am sure, but wanting to keep the truck original as possible. As many of these trucks are around I am sure someone has found the correct hoses or has made some from originals. I wish I had not thrown my originals in the trash.
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
Have you tried In-Line tube? WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook Click Here For our Die Cast For Sale. No appointment necessary. 72 BB Chevy K-5 Blazer 67 I-6 (Soon to be BB) Panel "Founder" Classic Heartbeat Pickup Club Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
![]() Join Date: Apr 2011
I got hoses for my K20 with PB from rockauto.com, I got some NOS Wagner hoses and they fit perfect. Maybe I got the last two? I'd keep checking with them and even give them a call, it seems like their inventory is pretty fluid and might change week to week.
I just checked my receipt from when I replaced the front brake hoses on my '72 K20. The NAPA number is 36761. It was a direct replacement and is still listed with them. Hope this helps.
#13 |
Their catalog has the same part number for 1/2 and 3/4 ton. They will probably be wrong also.
#14 |
I appreciate the info, but would the K20 be different from a C20 since the K's are four wheel drive?
#15 |
I put a 72 disc brake front end on a 68 a few years back and got the hoses from my local CarQuest parts store.
#16 |
Was the truck a 1/2 or 3/4 ton?
#17 |
#18 |
Ttt
#19 |
It was a 1/2 ton.
Just realized your looking for 3/4 ton info. |
#20 |
TTT...anyone?
#21 |
![]() Join Date: Aug 2005
this not much help but i posted it anyway
this is a x interchange for 1/2 tons. We use the nexpart system. it seems like no one makes the 3/4 ton hoses. you may want to to a brakequip dealer. they can make anything. My son is a factory rep for NAPA on the east coast i will ask him . these are all they list ACDELCO 18J1836 AIMCO B916885 CARQUEST SP4948 CARQUEST/RAYBESTOS SP4948 CENTRIC PARTS 15066088 DORMAN H380712 NAPA 380712 RAYBESTOS BH380712 ac delco does not list a 3/4 ton at all which is odd. i learned something today Last edited by mbgmike; 12-10-2011 at 10:34 AM. |
#22 |
#23 |
Manes truck parts lists a 3/4 ton hose. they cost more than the 1/2 tons. You may want to call them and ask. I have used them and they are a great company to deal with
#24 |
"brand new second-hand"
i just check my NAPA receipt and I used part #36592 for my 69 c-20 with power brakes.
Steve 69 3/4t custom camper tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c 67 Camaro 96 Impala ss-sold 04 hybrid Honda-saving gas for the blue truck!:b69: |
#25 |
If you have the stock front end the 69 has drum brakes. The 71/72 is disk. WES
Thread Tools | |
Display Modes | |
