Old 12-04-2011, 04:20 PM   #1
jack SF
How to remove 66 deluxe steering wheel
How do I remove the horn ring off wheel. I pulled hard but still not coming off. I don't want to crack it. Thanks for any help.
jack SF is offline   Reply With Quote
Old 12-04-2011, 04:31 PM   #2
el minero
el minero's Avatar
Re: How to remove 66 deluxe steering wheel
On my 63 there are small screws behind the spokes on the wheel that hold the ring in place. Not sure if 66's are that way but have a look behind the wheel and there should be 5/16 or 1/4 hex head screws.
el minero is offline   Reply With Quote
Old 12-04-2011, 04:39 PM   #3
Hilandr451
Hilandr451's Avatar
You need to use a steering wheel removal tool. You can find these at just about any parts store from $15.00 to $100.00. Kragen's & O'Rileys will usually let you borrow one for free providing you pay the cost of the tool as a returnable deposit up front. again, that is usually around $15.00.
Here's a how-to page I put together to do exactly what you're trying to do:http://www.64moneypit.pages.qpg.com/...cks/id108.html
Greg Smith a.k.a. "The Highlander"
1966 C20 Custom Camper, 2017 Chevy Silverado 1500
Highlander's Project Pics
Highlander's web site: www.6066ChevyTrucks.com
Hilandr451 is offline   Reply With Quote
Old 12-04-2011, 04:50 PM   #4
jack SF
El minero- I dont see any screws.
Hilandr451-very nice write up. i got puller for wheel.
I don't know how to remove horn ring. I think it's just pressed in there on a rubber sleeve , but I'm not sure. How hard do I pull/pry on horn ring.???
Old 12-04-2011, 04:55 PM   #5
jocko
jocko's Avatar
jack - you must pry (usually can do it by hand) the center cap off - then you'll see the 3 screws. Hard to tell the cap is removeable, but it is.
Old 12-04-2011, 05:09 PM   #6
Hilandr451
Hilandr451's Avatar
The very center of the horn ring pops out and there is a single nut that holds the steering wheel to the shaft, and 3 screws holding the horn ring. The picture below shows the main nut removed as I was going back together with the whole mess.
Make sure you don't loose this:
Or this:
After removing these items, you will find the threaded bolt holes to attach your puller to:
Make sure to remove the horn actuator button and the little spring inside before you pull the steering wheel off.
Old 12-04-2011, 08:28 PM   #7
brawley
Easy Does It
brawley's Avatar
if its a deluxe model then you need to unscrew the 2 small screws on the backside of the wheel -you will see holes behind each spoke,one on each side, then it falls off
brawley is offline   Reply With Quote
Old 12-04-2011, 08:57 PM   #8
jocko
jocko's Avatar
the wheel pictured above by hilandr is a deluxe (for 66) - so should be nothing more than prying off the center, then removing the 3 screws. Brawley - are you referring to a 65 & prior deluxe wheel? If so, I did not know that about them, thanks. I believe the 2 screws you are referring to are for prior years - what you described is the same attachment method for early 60's full size cars as well (i.e. 2 screws from behind wheel).
Old 12-04-2011, 08:58 PM   #9
rideblue00
rideblue00's Avatar
If you think theres a black rubber ring under it, then just pull it up with your hands. There are 3 types. One is like Hilandr451 shows. Another is like brawley said, with screws in from the back side. The 3rd is like i said. The rubber ring should come out with the cap. I dont have any pics, my stuff is packed away. Post up a pic of yours.
rideblue00 is offline   Reply With Quote
Old 12-04-2011, 09:24 PM   #10
paphigliano
the horn will pull off,,it is usually a job for a 3 handed man ,,,just pull hard while having a screwdriver popped in the back prying at the same time,,,,then once all the cups and screws are undone,,,,and the 3/4 nut removed,,,most times you can rethread the nut most of the way back on to protect the threads and hit it really hard with a 20lb hammer while pulling the the steering wheel,,,this will usually pop most steering wheels off ,,,even those which have never been removed before,,if this does not work you will need to get a puller,,but they can be really hard on the plastic part of the wheel,,,just be carefull,,,but usually the bang and pull method works just fine,,,
paphigliano is offline   Reply With Quote
Old 12-05-2011, 11:03 AM   #11
jack SF
I gave up yesterday. Will get a 3rd hand today. I
Have seen broken off 66 deluxe wheel horn rings and now I know why. Thanks for all the help.
Old 12-05-2011, 03:24 PM   #12
1963c-10
1963c-10's Avatar
Nice write up, wish you had one on the 63 standard wheel
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 12-05-2011, 11:05 PM   #13
paphigliano
Originally Posted by paphigliano View Post
the horn will pull off,,it is usually a job for a 3 handed man ,,,just pull hard while having a screwdriver popped in the back prying at the same time,,,,then once all the cups and screws are undone,,,,and the 3/4 nut removed,,,most times you can rethread the nut most of the way back on to protect the threads and hit the nut at the top of the stem really hard with a 20lb hammer while pulling the the steering wheel,,,this will usually pop most steering wheels off ,,,even those which have never been removed before,,if this does not work you will need to get a puller,,but they can be really hard on the plastic part of the wheel,,,just be carefull,,,but usually the bang and pull method works just fine,,,
Old 12-06-2011, 12:05 AM   #14
Hilandr451
Hilandr451's Avatar
I mean no disrespect to our Paphigliano, but I would highly recommend the $15.00 steering wheel puller over the "pop & pull" method. Trust me from personal experience, it is very easy to mushroom out the fine threaded steering shaft, even with the nut in place and pulling on the wheel while your buddy smacks the shaft with a 20lb sledge can be dangeruth to thay the leatht.
Old 12-08-2011, 12:42 AM   #15
jack SF
hi. first of all i got to stop drinking beer when im working on the truck! hilandr was correct. the center cap comes off.. thanks to all.
Old 08-17-2014, 04:08 PM   #16
mjs94080
mjs94080's Avatar
Question Re: How to remove 66 deluxe steering wheel
SO, to remove "HORN CAP", (not steering wheel)......
To remove "HORN CAP" on a 1966 Chevy C10,...you are all suggesting that
it needs to be "pried off" ?
I dont want to crack my Horn Cap..........it doesnt seen to want to snap out.
Any more suggestion...?
mjs94080 is offline   Reply With Quote
Old 08-17-2014, 04:15 PM   #17
vin63
It's Better With Nitro
vin63's Avatar
Yes, the 1966 Deluxe steering wheel is the same the early Nova/Chevy II steering wheels (I owned a '63 Chevy II for 30+ years). Pull the center cap off that is held in place by a spring steel retainer just as Hilandr451 noted and pictured in his post. This gives you access to the fasteners to remove the horn ring.
This steering wheel, correct?
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 08-17-2014, 04:17 PM   #18
mjs94080
mjs94080's Avatar
Thank You Vin63!
Old 08-17-2014, 04:29 PM   #19
mjs94080
mjs94080's Avatar
Thank You Vin63!
And yes it's the same exact steering wheel in your post, except I have a 3 In A Tree Column Shift.
Old 01-20-2018, 04:25 PM   #20
Bobs65stepper
I just picked up this set up anyone have any pics of what the set up under the horn button looks like the guy I bought the truck from has some kind of 80ís steering wheel set up and I need to get all the guts to put this steering wheel set up on my truck any help would be appreciated if what I wrote makes sense 😂
Bobs65stepper is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
