Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 12-09-2011, 02:44 PM   #1
theastronaut
theastronaut's Avatar
How To Fix Uneven Panel Gaps
Uneven panel gaps drive me crazy, so I found a way to fix them. You'll need 1/8" steel welding rods, welder's magnets, a grinder, a welder, and a DA sander. A long, flexible straight edge will be helpful also.
Once you have the door or panel adjusted so that the body lines are lined up and the panel is flush with the surrounding panels, take a look at the gaps and figure out how big of a gap you want between the panels. You can get carried away with this, make a feeler gauge to check and make every gap dead even, or you can just even out the worst areas.
Here's what I'm starting with. On this truck, I'll just be straightening out the worst areas as the owner doesn't want a full on show truck. The gap under the body line is a good bit larger than it is around the rest of the door.
To start, bend the 1/8" welding rod to the shape of the door/panel edge and use magnets to hold the rod flush with the edge of the panel. Tack weld around the magnets to hold the rod in place. You can fine tune the shape of the rod to the edge of the door before you fully weld the rod on.
Once the rod is tacked in placs you can fully weld it on. I like to do one spot weld at a time, skipping around to limit heat build up until all of the gaps are filled in.
After fully welding the seam, grind the welds down flush with the door skin. I like to use a 4.5" grinder to knock down the biggest part of the weld bead, then switch to a 2" air grinder to finish off the weld.
There will be smaller uneven spots that won't need 1/8" rod. Just weld up the edge enough to close the gap.
Some areas will have a gap that is too small. For this you can't just grind the edge down because the edge will split. Grind it, then you'll have to weld the edge after grinding it down, and then grind the welds down to even out the gap again. Once you have the gaps even, take your DA sander and round over the edges of the areas you reworked so the edge will be rounded and smooth. Try to match the radius of the original edges the best you can.
theastronaut is offline   Reply With Quote
Old 12-09-2011, 03:58 PM   #2
custom86
Re: How To Fix Uneven Panel Gaps
thats some nice work man. i just started doing this to my tailgate on my 86 cause it didnt fit for s***. good layed out guide for others to learn. thats the name of this game
custom86 is offline   Reply With Quote
Old 12-09-2011, 04:07 PM   #3
theastronaut
Here's what one looks like when all the gaps match. I made a feeler gauge to check and adjust the gaps until they matched on every panel.
Old 12-09-2011, 04:09 PM   #4
theastronaut
Thanks man, thats what the forums are for.
Old 12-09-2011, 04:20 PM   #5
custom86
That blue one looks sexy. That's one of my pet peeves spend all that time on paint and body but don't fix the gaps. Money down the drain
Old 12-09-2011, 09:16 PM   #6
kev2809
low n' slo
kev2809's Avatar
Nice work! Can you use that same technique on the body itself? I have an unusual twist on my driver door side...and I need to close the big gap it shows but I was thinking of welding rods on the body.
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 12-09-2011, 10:37 PM   #7
theastronaut
It works better on the edge of a panel since you can't tell it once its painted. I guess you could weld a rod to the door jamb but you'd have a strange lump in the door jamb.
Old 12-10-2011, 01:43 AM   #8
oldspowered67C10
theastronaut, what color is that?
oldspowered67C10 is offline   Reply With Quote
Old 12-10-2011, 08:50 AM   #9
theastronaut
It was suppose to be the original 64-66 light blue but its a little darker. I think I've still got the paint code at the shop, I'll try to find it.
Old 12-10-2011, 09:11 AM   #10
Indian113
Indian113's Avatar
Thanks for posting these pictures and explaining how to do it! Stuff like this is what makes this site the BEST
Indian113 is offline   Reply With Quote
Old 12-10-2011, 10:44 AM   #11
El Campo
El Campo's Avatar
Nice!
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 12-10-2011, 11:10 AM   #12
mbgmike
we have been doing that for 30 plus years. good post however for people that have never seen it. I don't like doing it. some guys slit the panel and shift it over. whatever works sometimes you have to make it work
mbgmike is offline   Reply With Quote
Old 12-10-2011, 12:40 PM   #13
kev2809
low n' slo
kev2809's Avatar
Can u explain how that is done? I've seen the welding rods but I dont think I seen this method...
-_--_--_ _________
Old 12-10-2011, 03:51 PM   #14
BlueJeep
BlueJeep's Avatar
You make a slice with a cutoff disc on the jamb side, then pry it over where you want it with a screwdriver and then weld up the slice you just made.
build threads:
http://67-72chevytrucks.com/vboard/s...d.php?t=384736
http://67-72chevytrucks.com/vboard/s...=1#post8149268
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 12-10-2011, 04:55 PM   #15
lowdownstar
big guy
lowdownstar's Avatar
Thanks for taking the time to teach us how to do it right! I am just about to start working on my doors and this is going to help me big time.
Thanks Ray
ps the blue truck is perfect!
lowdownstar is offline   Reply With Quote
Old 12-10-2011, 05:35 PM   #16
kev2809
low n' slo
kev2809's Avatar
i see...
not trying to jack the thread but i figure i would post in here since its related...
the jamb on my driver side looks twisted...it was hit on that side before i bought the truck. i replaced it with new metal but the jamb was still twisted at the top and bottom. could i weld rods to the actual jamb, or should it be split open and pushed over? I know its a little hard to see in the pics....i dont have a digital camera
TOP
BOTTOM
-_--_--_ _________
Old 12-10-2011, 08:48 PM   #17
theastronaut
Originally Posted by El Campo View Post
Nice!
Thanks dudes!
I've used that technique also, and it works better than grinding into the edge of the door since you avoid the edge splitting. The bodywork on the cab is finished though so I didn't want to cut back into it. I normally would do the metalwork on the cab and doors at the same time but it wasn't possible on this job due to trouble finding suitible hinge pins and getting them replaced in time to get the doors on and adjusted while we were doing the metalwork on the cab.
Thanks Ray
Glad to be a help!
i see...
the jamb on my driver side looks twisted...it was hit on that side before i bought the truck. i replaced it with new metal but the jamb was still twisted at the top and bottom. could i weld rods to the actual jamb, or should it be split open and pushed over? I know its a little hard to see in the pics....i dont have a digital camera.
I think I can see where the jamb is twisted at the top, and it looks like the seam in the drip rail may be pulled apart some? That's going to be a tough repair if you want to keep all of the bodylines/gaps parallel with each other. Its hard to get a good frame of reference with just the pics you posted though. Something is out of place, either the door post or the front door/window frame but it's hard to tell which is out of place. The back of the post is parallel with the back door window post. The front top of the post looks twisted but the front edge still looks parallel with the rear door post. The top gap of the front door looks good though, so maybe the window frame isn't square? How does the front door gap look below the window frame? Start a thread with more pics and we'll help you out the best we can!
Old 12-11-2011, 02:12 AM   #18
Daze57
Daze57's Avatar
astronaut - what great work ! gaps are so very even - i am sure that took alot of time
great lookin truck also - kudos man !
Daze57 is offline   Reply With Quote
Old 12-11-2011, 02:46 AM   #19
fakerwade
fakerwade's Avatar
Once again,,,,very nice work,,,,thanks for the thread.
Wade
JUST WALK AWAY, AND I'LL SPARE YOUR LIVES!!!
Build thread "TANGERINE" http://67-72chevytrucks.com/vboard/s...d.php?t=498570
Board Members Met: bigblock68, ol_skool_chevy ,68TT,atvpro
fakerwade is offline   Reply With Quote
Old 12-11-2011, 06:04 PM   #20
kev2809
low n' slo
kev2809's Avatar
Will do...thanks for the nice write up!
-_--_--_ _________
Old 12-18-2011, 08:05 AM   #21
C-10cutty
C-10cutty's Avatar
Very good work and great idea.
C-10cutty is offline   Reply With Quote
Old 01-17-2012, 12:19 AM   #22
01chevduramax
01chevduramax's Avatar
I Just finished replacing LH cab corner, RH cab corner, rocker, outer floor patch, A and B pillar patches. When I started all this my passenger side door gap didn't look that bad. But once all the work was done it looked off. The gap between the B pillar and the door is wider than anywhere else on the truck. I never heard of the split and pry method until tonight. My problem is the guy at the paint store told me a little -evercoat rage gold- in the door jamb is fine as long as its not thicker than 1/4". So I went for it. I built it up 1/8 to 3/16. Now its in primer. What are the odds the paint will crack there? Should i go back and do it over?
P.S. the rod welded to the door method won't work for me. The door looks perfectly straight. The gap between the bottom of the drip rail and the bottom of the door is whats off. From the bottom of the rail up is good. below tapers out towards the bottom.
'71 org/wht 3/4 ton 4x4
01chevduramax is offline   Reply With Quote
Old 01-17-2012, 01:00 AM   #23
68 SWB
68 SWB's Avatar
You should post a pic of it.
68 SWB is offline   Reply With Quote
Old 01-17-2012, 01:28 PM   #24
Lauppster
If only I had read that 4 weeks ago...
I'll sleep better knowing that this was an "approved" fix method!
An aluminum (or non-ferrous metal) backer plate under the edge weld helps to keep it from blowing or falling off when welding.
Lauppster is offline   Reply With Quote
Old 01-17-2012, 07:03 PM   #25
01chevduramax
These are the only 2 pictures I took that really show where the bondo went. I sanded 90% of the stuff off then primed. The thickest spot is around the bottom rear corner of the door jamb. about 1/4" across once sanded. from there to the start of the drip rail it feathers down to zero filler.
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
