Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 12-15-2011, 09:00 PM   #1
rpmgroup
chassis saver paint?
Those of you that have used Chassis Saver on your frame, how did you like it? and would you use it again? any tips besides not to get it on your skin?
THANKS
rpmgroup is offline   Reply With Quote
Old 12-15-2011, 10:28 PM   #2
turp mcspray
turp mcspray's Avatar
Re: chassis saver paint?
I use it. It is just like POR15. (moisture cured urethane) I always use it over sandblasted surfaces. I like to spray it. When I do, I wet down the booth floor with hot water to get the humidity up. This speeds up the dry time, so I can spray the second coat coat with almost no waiting. No complaints. If you spray any other paint on top of it, you must start spraying it while the Chassis Saver is still tacky, for good adhesion.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 12-16-2011, 12:02 AM   #3
freakshow108
freakshow108's Avatar
X2 I love this stuff!!
freakshow108 is offline   Reply With Quote
Old 12-16-2011, 10:07 AM   #4
rpmgroup
Turp, what kind of paint do you spray on for a topcoat?
Old 12-16-2011, 11:33 AM   #5
turp mcspray
I've been using a Sherwin Williams product called Sunfire. It is a urethane that is very durable, and even resistant to brake fluid. The can is labeled as semi gloss, but it ends up being very close to the factory satin black finish. You can spray anything you want over the chassis saver.
I'm going to try the paint line by Bill Hirsch. They offer most of the same product line as POR, but considerably cheaper. All of that marketing that POR does, adds to the cost.
Turp Mcspray
Old 12-17-2011, 11:54 AM   #6
rpmgroup
thanks
Old 12-17-2011, 03:47 PM   #7
79k30dually
Make sure you read all the safety precautions, this type of paint is high in ISOSYONATES(SP). Most respirators will not protect you from these chemicals. Ron
79k30dually is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
