Old 12-22-2011, 09:43 AM   #1
rideblue00
rideblue00's Avatar
My tach install thread
Well, i finally decided i wanted a tach in my "gauges" cluster. So i did some quick research and decided on the Sunpro FZ88R. It has a similiar look and correct sweep. As far as i can tell its only availible in the 3 3/8" inch size. I ordered it from Summit Racing at the cost of 129.99. It comes with a mounting cup and 2 brackets. Steering column mount and dash mount. And screws and instrucions obviously. No wires.
I have some pictures here that illustrate how it fits in my cluster. This tach is a sealed unit. Which means you cant take the internals out unless you cut the case. So im going to attempt to install it as its comes out of the box. Initially, it appears to fit very close. So i am going try to design a plate to go over the back of the cluster housing to bolt the tach to.
So this is as far as ive gotten. I plan to finish this in 2 weeks(dont hold you breath..lol). I will try to get my plate cut out and finished within the next few days. More pics to follow soon. Any questions?
rideblue00 is offline   Reply With Quote
Old 12-22-2011, 09:48 AM   #2
rideblue00
rideblue00's Avatar
Re: My tach install thread
pics of the tach
Old 12-22-2011, 09:51 AM   #3
rideblue00
rideblue00's Avatar
pics of tach in cluster
Old 12-22-2011, 09:57 AM   #4
rideblue00
rideblue00's Avatar
In the last picture you can see some of the chrome face exposed. I will try to paint the face black to eliminate the shiny spots. The face is offset a little bit. So opening up the black cover plate to a full circle may not work. Oh, and i did have to file down the back of the black cover plate because it had a radiused protrusion sticking out. But i didnt have to file it flush. I will try to get a picture of this, but i have to take another cluster apart to get the picture.
Old 12-22-2011, 10:23 AM   #5
tomfg
Very interesting, look forward to your progress. Do you plan on installing anything in the other left hand hole?
I plan on starting my conversion soon, but have already purchased a reproduction tach from one of the old Chevy parts houses.
Debated a long time on what to do with the other hole as long as I had the cluster out. Thought about a vacuum gauge, clock, etc., but finally decided on a Volt Meter. Just awaiting for it's arrival before the fun begins.
I ordered a
"Auto Meter 2319 Auto Gage 2-5/8" 10-16 Volt Short Sweep"
Hope I can get it to fit, and look decent.
Good luck on your project.
tomfg is offline   Reply With Quote
Old 12-22-2011, 12:37 PM   #6
chevyrestoguy
chevyrestoguy's Avatar
I have been considering this EXACT SAME mod!!! Man, I am definitely tuning in to this thread.
My ideas were similar to yours, but I was planning to disassemble the gauge, which meant gently prying open the crimp on the chrome bezel. If you did this, you might be able to utilize the factory gauge plates. Looking at your set-up, I might just do the way you're doing it, as it looks much easier than my way.
I was going to contact one of the gauge overlay companies and see if they would make me an overlay with the correct green lettering to match the rest of the cluster. I found overlays for 5,000 rpm and 6,500 rpm faces, but nothing to match the new Sun tach's 8,000 rpm sweep.
If you're looking for a cheap idea to fill the left side of the cluster, check out my '64 build thread and see how I did my vacuum gauge for cheap.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 12-22-2011, 12:52 PM   #7
markeb01
Senior Enthusiast
markeb01's Avatar
Itís a shame they didnít produce this new tach with the same bolt-together technology found on the vintage models. It would make things a lot easier for gear heads that canít leave anything alone. I have had good luck in the past twisting bezels off gauges and using the guts inside factory panels on 1940ís cars. Just a little scary on a brand new gauge costing over $100, since you canít know for sure what else they may have changed until after itís torn apart.
Looking forward to seeing this all back together.
Old 12-22-2011, 01:27 PM   #8
neslie
Lmc list a tach conversion kit on page 73 of the catalog. Said it's for trucks that didn't come with the tach in the factory cluster.
neslie is offline   Reply With Quote
Old 12-22-2011, 01:54 PM   #9
1963c-10
1963c-10's Avatar
Also comes with a hefty price
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 12-22-2011, 02:20 PM   #10
rideblue00
rideblue00's Avatar
Im excited about this as well. I have a few more pics here. I have to come up with a way to bolt it in. I have the plate as you can see. I have to weld some tabs on my .030 aluminum....that out to work well...lol. Its very thin. I plan to try to make more of these. We will see.
Old 12-22-2011, 04:49 PM   #11
lowmemory
lowmemory's Avatar
Good job done!
I need to do it myself otherwise I won't be happy.
lowmemory is offline   Reply With Quote
Old 12-22-2011, 04:56 PM   #12
markeb01
Senior Enthusiast
markeb01's Avatar
The casual observer would never know that didn't come from the factory.
Old 12-22-2011, 05:42 PM   #13
Greg63
Enjoy your truck
Greg63's Avatar
Nice work - looks great.
Greg.
1 Corinthians 10:13
1963 Chevrolet 1/2 ton
2010 Camaro SS/RS
2014 Jeep Grand Cherokee
2016 Jeep Cherokee
Greg63 is offline   Reply With Quote
Old 12-22-2011, 10:40 PM   #14
rideblue00
rideblue00's Avatar
Thanks for the kind words. I still have to finish the back plate for the tach to bolt to. And i also am going to track down a clock for the other side. If i can, i plan to make these back plates to sell. Got to finish the design first. I found the tach through summit racing, but saw it also on ebay for 99.99. I paid 129.99. I wanted to go through summit in case i had to return it. I will try to get pics of the way it came out of the box. I considered just putting on my steering column. Then decided to put it in the cluster.
Old 12-23-2011, 01:43 AM   #15
scottveazie
I was looking at the exact same tach for my '65. Can you give any details on the bracket you made?
scottveazie is offline   Reply With Quote
Old 12-23-2011, 01:48 AM   #16
jocko
jocko's Avatar
hey, looks very nice! jocko like!
Old 12-23-2011, 02:55 AM   #17
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Looks really good.
Appreciate you posting your work.
66 Service truck build:
Old 12-23-2011, 09:58 PM   #18
rideblue00
rideblue00's Avatar
Not sure what details you would like. Im not finished with it yet. The gauge is just sitting in the hole temporarily. I tried something different today and it didnt work. Im still trying to come up with a way to bolt it. Time is kinda short with the holiday an all. I will try to work on it tommorrow again. I will give an update soon.
Old 12-27-2011, 09:15 AM   #19
rideblue00
rideblue00's Avatar
Heres a picture of the black overlay plate. It has a raised part that needs to be filed down. In my picture you can see this, right at the end of my marker. I just filed it down flat. Otherwise it holds the tach away from the window to far.
Old 12-27-2011, 09:21 AM   #20
rideblue00
rideblue00's Avatar
Heres a pic of my plate almost done.Im gonna paint it yet. Its 2 pcs of aluminum welded together. I have some other ideas about making them from steel. Once i get back to work after the new year, i will have access to a plasma cutter and will try to make these from steel.
Old 12-27-2011, 01:25 PM   #21
jimmydean
jimmydean's Avatar
Nice work!
I just replaced the backs on mine for both the clock (custom) and used a tach similar to that, but not as nice.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 12-28-2011, 01:07 AM   #22
Captainfab
60-66 Nut
Very nice work
Old 12-28-2011, 01:23 AM   #23
losthope
losthope's Avatar
I see you selling these tach brackets on ebay in the near future nice work!!
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 12-28-2011, 07:28 PM   #24
rideblue00
rideblue00's Avatar
Thanks for the compliments. As far as selling them, i have a few other design ideas. I wont be able to explore them till next week or so, when i go back to work. Im going to try to make them out of steel instead of aluminum. The real problem is cost(isnt it always) and time to make. I should have bought the tach that classic parts or lmc has. If could source the tach for under 100 and get the plate for like 40, thats closer to what i think people would pay.We will see.
Old 12-28-2011, 11:52 PM   #25
T2vigil
T2vigil's Avatar
I have been keeping trac of this from the first day. By far the best post concerning tach alternatives. I have an original Sun Tach but it is for a V8 and I will be keeping my in-line 6. The original tach is engine specific and to have it refurbished at about $260 is cost prohibitive. Your Idea is perfect. Now for the question. Have you looked at removing the chrome bezel prior to mounting it? And what would be the pros and cons in doing so?
T2vigil is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
