Old 01-09-2012, 08:54 PM   #1
westgl
westgl's Avatar
Disc Brake Conversion for my 67' C10 LWB
Hello,
I have a 67' Chevy C10 LWB Truck with 6-Lug Drum front brakes.
A neighbor of mine has a Complete Disk Brake Front end out of a 1972 Chevy C10 Pickup He say's it is a 5 on 5 lug pattern.
The question i have is will that fit on My truck, And what is the 5 on 5 lug Pattern? Is that a 6 lug?
I have not yet seen the condition of these and my neighbor has them tucked away and has not looked at them in a while.
He is asking $200.00
westgl is offline   Reply With Quote
Old 01-09-2012, 09:14 PM   #2
jocko
jocko's Avatar
Re: Disc Brake Conversion for my 67' C10 LWB
5 on 5 is not 6 lug - it means 5 lug nuts on a 5" bolt circle. You would need 5 lug wheels with this setup.
Edit: just to clarify - half ton trucks were 6 lug thru late 60's - early 70's were 5 lug (only 1/2 tons that were 6 lug in early 70's were 4x4's)
I don't recall the exact year of the changeover, but you fall into the same category as 60-66 half ton trucks with your 1/2 ton 6 lug life.
Old 01-09-2012, 10:22 PM   #3
westgl
westgl's Avatar
Thanks for the quick reply
Any idea what diameter those disc's are on a 72' c10?
Westgl
Old 01-09-2012, 10:26 PM   #4
lolife99
Old Member
lolife99's Avatar
Westgl
They call them 12",... but I think they are actually 11-7/8".
Keith
Convert to disc brakes.
WTB: Radio Delete Plates and clips.
Old 01-09-2012, 11:15 PM   #5
Forgasmic
Forgasmic's Avatar
You should check out lolife99's Drum to Disc brake conversion thread. It answered all of my questions for me. I purchased a 71-72 complete disc brake set-up crossmember and all from teeitup, Randy, who was great to do business with btw , and its going on my '69 C10. Crossmember should bolt right up to the frame, getting it blasted first so havent mounted it yet.
Forgasmic is offline   Reply With Quote
Old 01-09-2012, 11:39 PM   #6
gcburdic
Restoration Virgin!
gcburdic's Avatar
this is what they are talking about...very good info...thanks lolife...you'll need to read thru this post http://67-72chevytrucks.com/vboard/s...68&postcount=4...67-70 truck with 71-72 Crossmember Not Yet Installed:
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban
Current Resto: 1966 Mustang-Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 01-10-2012, 12:41 AM   #7
westgl
westgl's Avatar
Thanks to all that replied.
That was a good write up by lolife99, thanks for pointing that out gcburdic
I think that will work then. $200.00 does not sound too bad I will probably have to rebuild & paint.
I am not sure if it has the steering gearbox with it, & if it does, is it a power or manual
i know that it was sitting out side for 5 years so I am not expecting to much, he says that he swapped to a 4 wheel drive front end, that is why he is selling it.
I will need to buy a new Brake master Disc/drum style, SS. brake lines & some adapters.
Old 01-10-2012, 01:36 AM   #8
jocko
jocko's Avatar
and wheels (?) (converting 6 to 5 lug) Maybe he'll throw some wheels in with the bargain??
I'm just spit-ballin' here, but by the time you spend $200 on the used stub, then buy the Disk/Drum mc (what about a booster?), brake lines, adapters, etc that you mention you'll need in the post above - (and wheels?) - well, won't you be close to buying a brand new 6 lug disk conversion kit? Probably not THAT much, but something to consider since you're not getting all the freebie parts along with the stub like master cylinder, etc and will need new wheels (unless you already have some 5 lugs layin around). And if it's been laying around outside for 5 years, I'd imagine the disks are pretty much rust piles by now - so throw those in too while you're at it. Maybe the calipers won't be frozen.
I don't want to poop in the punch bowl, but seems if you're basing your choice on opportunity of a local stub and saving some $, there are a few other considerations that haven't been discussed. Just a thought, I could be way off base, but these are questions I'd be asking myself, so thought I'd share. Either way you decide to go, it will be a very worthwhile upgrade.
Old 01-10-2012, 07:53 AM   #9
lolife99
Old Member
lolife99's Avatar
I agree^^^.
There is nothing in that 72 crossmember assembly, that you don't already have on your truck.
(except the disc brake spindles)
If your adding drop spindles,... then there is NOTHING that you need.
The rotors, calipers, bearings,... should all be replaced with new.
The 71-72 steering linkage is a plus,... but not neccessary any more with the new conversion spindles for 63-70 trucks. ($228/pair)
Just a thought.
The only advantage to spending $200 on the extra parts,... it would allow you to rebuild them in your spare time.
Then swap all the parts later.
I'm not sure it's worth $200.
I think most of it will be replaced with new parts anyway.
Keith
Old 01-10-2012, 10:55 AM   #10
westgl
westgl's Avatar
Yea you guys are probably right.
After all I do want this truck to stop very well and not have problems.
When I put the new disc's I was looking at the CPP setup #6770cbk5 Looks like it is a complete setup and includes booster, mstr cly. $599.00
I will be doing a engine and trans swap, right after i do a front end rebuild and Rear bushing suspension.
I have a Rebuilt 350ci .030 over, 9.1:1 coated pistons with Vortec heads, and a comp cam with a performer eps intake and a 600cfm carb. roller rockers. waiting to be shoehorned in to my truck.
Comp Cam's dyno says 348h.p. & 415 ftlbs torque with this setup, I do want to make sure i can stop.
The Trans/converter is a built 700r4 from phoenix.
It currently has a I6 250ci and a 3 speed manual trans
I would like to lower it a little I want the fender to tire spacing to be equal all the way around the tire.
I dont know how much lowering that will take maybe 3" inches?
Correct me if i am wrong but you cannot use 15" rims with the disc's, 16" rims or larger? or you contact the rotor.
Advantages to dropped spindles, disadvantages?
I will want to still use the truck as a truck for some haulin
Old 01-10-2012, 11:46 AM   #11
lolife99
Old Member
lolife99's Avatar
If you want to lower it,... use drop spindles.
They will work fine with 15" wheels.
Keep the wheel backspacing at 4" or less and you will be fine.
Keith
Old 01-10-2012, 12:01 PM   #12
westgl
westgl's Avatar
Where can i get drop spindles?
And what about the rear?
1967 Chevy C10 Lwb I6-250ci 3spd manual trans
Future Projects, Power Brakes, Front Discs, Power Steering, Paint Frame, New 350ci engine Bored .040 357ci Magnum, Vortec Heads, Comp XE262 Cam, Performer EPS Intake, 650CFM Carb, Rebuilt Trans 700r4, 2000-rpm stall, Completely Rebuild & Upgrade Front & Rear Suspension & Steering Components, Suspension Drop 3.5" & 5" Drop, 1.250 Sway bar,
Old 01-10-2012, 12:02 PM   #13
too much stuff
Roadtrip!
too much stuff's Avatar
$200 seems pretty high for something that came on every 2wd 1/2 ton truck starting in 71. I have actually thrown them away over the years.
67 gmc custom lwb dakota truck
69 swb 4x4 project
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 01-10-2012, 06:20 PM   #14
71 super
71 super's Avatar
Check GMC pauls as well I have used their kit twice and it is really complete and uses good parts.
67 plain jane swb red
68 gold and white swb cst anniversary
68 gmc custom black swb
70 orange and white swb bb
70 medium green and white custom lwb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
71 super is offline   Reply With Quote
Old 01-10-2012, 06:37 PM   #15
lolife99
Old Member
lolife99's Avatar
Ok,... what is the plan?
Using the '72 parts or not?
Spindles can be ordered for 63-70 trucks.
71-72 spindles are different.
Steering stuff is different.
There are many good drop spindle companies.
McGaughys
Belltech
Western Chassis
Performance Online.
Summit Racing is a good source for affordable drop spindles.
What is the big picture plan?
Rebuilding everything?
Balljoints, tie rods, control arm bushings?
The year of spindle you choose,... will decide which parts you buy.
The rearend can be swapped out for a 71-72 5 lug rearend,... or you can buy conversion axles.
Keith
Old 01-10-2012, 07:16 PM   #16
westgl
westgl's Avatar
well I am new to these Older trucks, But Not to working on cars.
My plan was to drop in a new engine & Trans, but more power always means upgrading other systems.
I had not thought that far ahead.
But Now that i am at that point, please provide some info/suggestions.
I will be adding Power brakes.
I will be adding a front & rear swaybar to get the truck to handle a little better.
Are there any benefits going to the 71-72 vs sticking with a 67-70
I would like the truck to hold the road better, by swapping the front & rear worn parts.
I wanted to rebuild the front end and replace the susp rear bushings.
I saw some poly bushings I would expect them to be better, but is the ride much harsher and more noise?
westgl
Old 01-10-2012, 07:31 PM   #17
lolife99
Old Member
lolife99's Avatar
I suggest ECE.
(www.EarlyClassic.com)
Call and talk to Stan.
They have everything you need to convert your truck to 5-lug disc brakes.
These guys are not just parts vendors,... the own and drive these 67-72 trucks.
To me there is ZERO advantage of using 71-72 parts.
In the old days,... that's what you had to do.
Now there are disc brake spindles for your '67.
Call ECE.
Also,... look at 72BlckButy's "Blank Slate thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=353633
Nate's truck is the cover truck for the new LMC catelog.
But it rolls on ECE suspension.
Keith
Old 01-10-2012, 08:49 PM   #18
westgl
westgl's Avatar
Thanks for the Info lolife99,
I'll give Stan a call.
That is a very nice looking truck, I am sure it gets a lot of looks.
I hope my truck looks that good when it grows up
I will post a couple of pictures if i can figure out how to.
I warn you, My truck has not been washed or waxed (other than mother nature) in 2 years+
westgl
Old 01-11-2012, 07:18 PM   #19
westgl
westgl's Avatar
Here Is My 67' Like i said it has not been washed in two years, except by mother nature.
Last time i drove it was a year ago.
She is ready to see some action, I am going to clear out some stuff/projects out of the shop and get started.
My front windshield is leaking condensation on the inside, and it has that foggy look in the corners of the glass time to replace it and the seal.
It came with a Shell, but it is on there to protect the wood bed right now. When it is done, that shell is coming off.
Here are some pictures.
These pictures were taken on a very overcast/cloudy and dark day, it may look better when it is a sunny day & washed
Old 01-11-2012, 07:28 PM   #20
westgl
westgl's Avatar
This truck was painted about two years ago with 5 coats color, & 5 coats of clear.
I was going to rub out the paint, to get more depth and shine, But
I lost interest/other projects and it sat.
Since i sold my other Truck, and now i am Truckless, now it is time, for Project C10.
Old 01-11-2012, 09:38 PM   #21
lolife99
Old Member
lolife99's Avatar
NICE looking truck.
Keep us posted with your progress,...
Keith
Old 04-23-2014, 04:14 PM   #22
Billett
Billett's Avatar
Just lurking around and found this old thread. I happened across a set of 71 spindles, rotors, bearings, calipers, and new pads on CL the other day. Picked them up last night for only $80. Checked out the FAQ thread so I can see that I'll still need MC, prop valve, hoses, tie rods and ball joints, but then I came across this thread.
I get that there isn't an advantage to using these old parts, but is there an advantage to using new ones or does it really matter? I like the height my truck sits at right now so I don't really need drop spindles. Pads look perfect and the rotors don't look bad either. I suppose the calipers may need replacing, but at that point it's still cheaper than a set of $270 spindles or a swap kit right? Is there something I'm missing or did I actually get a good deal this time?
Will
1968 C10 - Project Texa Go 6.0/4L80e
1961 Falcon - Project Falcon Punch 144 I6/2spd
2012 JKU - Funkmaster Flex 2.5" BB, 33" A/Ts
2004 HCH - HYBRID POWAHH
Billett is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
