Old 01-11-2012, 08:50 PM   #1
crazzy88
How can I get my 1971 Chevy 4x4 to ride smoother??
How can I get it to ride smoother? It's lifted 4inches
crazzy88 is offline   Reply With Quote
Old 01-11-2012, 09:26 PM   #2
84chevy4x4
84chevy4x4's Avatar
Re: How can I get my 1971 Chevy 4x4 to ride smoother??
drive faster not many straight axle units ride smooth haha
1984 Chevy K20 work in progress
1977 Chevy C30 Dump
1979 GMC 35 4x4 Dump
1969 GMC 1500 Rat
84chevy4x4 is offline   Reply With Quote
Old 01-11-2012, 09:41 PM   #3
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
You build a 4 link suspension with airbags or coil-overs and your truck will ride like a caddy. The only thing I can truly tell you is get procomp springs, they make the softest springs I know. Also try adjustable shocks. They have a lot to do with the stiffness of the ride.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 01-12-2012, 03:33 AM   #4
lukefalls
When I lifted mine in about 2003, Skyjacker had the softest. That was a while ago and I trust Chevy1TonFun. That being said, I'm linking mine.
If its only lifted 4", I suggest:
Move the rear springs to the font using DIY4X brackets. Buy or make you own longer shackles.
Find a set of junk yard 56" rear GM springs. Install them on the rear using Off Road Designs shackle flip. With 56" springs, put the left bracket on the right and the right bracket on the left. That'll make for a perfect shackle angle. Find a good set of shocks.
All that should cost you about what a set of springs will run you from Skyjacker or ProComp (or close to it).
If you really wheel it, you'll want cross over steering. That setup will give you a ton wheel travel; more than stock steering can handle in some cases.
lukefalls is offline   Reply With Quote
Old 01-12-2012, 10:55 AM   #5
Chevy1TonFun
Grease Monkey
Lukefalls: I total forgot about longer springs, I must have been out of it last night. Thanks for the kudos as well.
Crazy88: As luke said call Kurt at DIY4X and order his 67-72 B52 kit and his rear shackle flip kit. Then get your self some 52" long eye to eye 4" lift springs for the front an find a stock set of 63" long for the rear and don't forget about the shocks. The shackle flip will give you 4" of lift in the rear. Accomplishing this will give you the softest ride achievable on a lifted 4x4 without 4 linking it.
Old 01-12-2012, 11:13 AM   #6
faithblinded
I came to the thread planning to give the same answer you've already been given.
DIY4X B52 Kit and Rear Shackle Flip with some Pull a Part leafs: 52" for the front, 64" for the back
I would also add greasable bolts front and rear(6 total), and all new poly bushings. Maybe overkill for your rig, but the heavy duty rear shackles they make are pretty sexy too.
This is exactly what I'm planning for my Suburban, when I can afford all the parts. I already bought a set of leaf spring plates and u-bolts for my rear from DIY4X, and man are they beef! You really can't go wrong with their gear.
Once you've upgraded your springs, you are left with shock absorber choices. Some of the adjustable units might be what you want, so you can dial in the level of softness you want. I dont have any experience with any high end shocks like that though, so cant make any specific recommendations. I am running Rancho rs5000's on my Suburban, and I ran Bilstien HD's on my last 4x4 rig(a trailblazer). I prefered the feel of the bilsteins, and I wish I had got them for my Burb. Next time...
Let us know what you decide to do to your truck.
Peace
Ken in Cleveland
faithblinded is offline   Reply With Quote
Old 01-13-2012, 07:38 PM   #7
crazzy88
You guys rock thanks!
Old 01-14-2012, 10:20 AM   #8
I'd have to know just what you have to answer best. But yeah,longer springs and sliders is the best way for staying with leaf springs.
'67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi...'The 67' (project)
'72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok...'The 72'
"Don't call me a rough cut country gentleman. I'm just a redneck"
R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586
Old 01-15-2012, 02:20 AM   #9
edhtrd71
I probably shouldnt be wasting your time because it looks like there is plenty of knowledge giving good advise, but you might also look into Deaver leaf springs they can make you custom springs for what you want. In desert racing if you cant afford to link your truck you run deavers.
edhtrd71 is offline   Reply With Quote
Old 01-15-2012, 08:56 AM   #10
aboveall
Junior Member
Best smothers ride system is to 4linck it and put in some KN nitro shocks you can hit a speed bump doing 60 and not feel a thing just could be really costly or try sky maker springs or call nationally springs and they can make a soft ride spring
aboveall is offline   Reply With Quote
Old 01-16-2012, 02:55 AM   #11
rjsdad
rjsdad's Avatar
Deaver Springs and Bilstiens.
rjsdad is offline   Reply With Quote
Old 01-16-2012, 03:49 AM   #12
69CST4x4SWB
Formerly 72_GMC_Sierra_Grande
69CST4x4SWB's Avatar
Location: The Beautiful Pacific Northwest (GOD'S country)
How about new rubber cab mounts... not urethane since it is harder!?!?
In GOD I Trust All Others I Question!!
1969 Chevy CST/K10 SWB (Legs)
1969 Chevy C/20 LWB (Old Gray Mare)
1972 GMC Sierra Grande (Orange Creamsicle) Sold
1979 Chevy C/30 Cheyenne Flatbed Dually (FatBoy) Sold
1991 Chevy C/1500 Silverado (LowBoy) Sold
2008 Harley Davidson Electra Glide (Black Betty)
Fords:1935/1939/1960/1964/1995/1997x2/1998/1999/2002 Lightning ALL SOLD
69CST4x4SWB is offline   Reply With Quote
Old 01-17-2012, 11:49 AM   #13
splehigh
splehigh's Avatar
Thicker foam in your seat. LOL
splehigh is offline   Reply With Quote
Old 01-19-2012, 10:49 AM   #14
70custom20
70custom20's Avatar
I went from rubber cab mounts to urethane mounts, and it made no difference whatsoever. The only thing it did was stop the cab and bed from hitting each other.
70custom20 is offline   Reply With Quote
Old 01-19-2012, 12:09 PM   #15
OregonFXSTC
http://www.tuffcountry.com/chevy-gmc...lift-kits.html for the front.
OregonFXSTC is offline   Reply With Quote
Old 01-19-2012, 12:24 PM   #16
snj8198
snj8198's Avatar
Originally Posted by OregonFXSTC View Post
I've ran TC EZ rides in all of my solid axle Chevy's and find them as good as it gets for over the counter systems. Their ride quality on an empty truck is much softer than Rancho, Superlift and Rough County but of course their light spring packs lack the hauling capacity of other brands with heavier spring packs. There's always a trade off.
Regardless, even with EZ rides my truck rides much better with an extra 1000 lbs in it. Empty it's 6,000 lbs.
-steve
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 01-19-2012, 06:21 PM   #17
RastaRobb
RastaRobb's Avatar
I just did new u-joints all around, and wheel bearings and the difference was incredible. I didn't realize how bad it was until it was better. Not much money either.
RastaRobb is offline   Reply With Quote
Old 01-26-2012, 05:49 PM   #18
72longbed
72longbed's Avatar
The only way to get a 71/72 Chevy 4x4 to ride smoother is to lift the gas cap and pull a cadillac under it and re-install the cap.
It's a truck .... they ride rough until 600 lbs. or more is dropped into the bed.
Tough Country EZ- Ride springs are the softest ride by far for our trucks. Tried them all. Much better ride than stock springs too.
72
72longbed is offline   Reply With Quote
Old 01-27-2012, 04:12 AM   #19
69CST4x4SWB
Sorry 70custom20... You got what I was saying backwards! The urethane mounts are harder than rubber which would make it ride stiff. With you replacing worn rubber (stiff = no cushion) with "stiff urethane" is why you saw no difference!
Old 02-05-2012, 10:16 AM   #20
70custom20
70custom20's Avatar
No, I read what you posted, and in my experience replacing rubber with uerethane made no difference. When I restored my 70 3/4 ton, I put brand new rubber cab mounts in, about 3-4 years later I put the urethane mounts under the cab, and the truck rode exactly the same. Now the back of the cab doesn't get dented anymore from the bed hitting it. Suspension mods could/would make the truck ride smoother, but cab mounts won't. I'm planning on doing longer springs under my truck to try get a better ride.
Old 02-07-2012, 10:02 PM   #21
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
This may not be helpful since you already have a truck but Lwb's ride better than Swb's, less pitch as you go over bumps.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 02-08-2012, 01:43 AM   #22
sethv
sethv's Avatar
I lol'd. This is the poor man's way (not a bad thing, either!!)
1981 K10 Scottsdale
305 ci | TH350 | NP208 |
60k miles
sethv is offline   Reply With Quote
Old 02-08-2012, 12:22 PM   #23
Mr. 250r
Mr. 250r's Avatar
How about this idea... http://coloradok5.com/ranchoreview.shtml combined with b-52s from diy4x I think that's the smoothest ride your going to get in a straight axle I've just learned to accept it and maybe some late model bucket seats as my bench seat throws me around
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 t-top play toy
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
1995 Geo Metro - 5spd play toy - Sold
2001 3500 6spd 5.9L - Tow truck - Sold
2003 1500 Silverado - Weekender
2004 3500 6spd 5.9L - Tow truck - For sale
LS info
http://lsx4u.com/lsxinfo.html
http://www.pirate4x4.com/tech/billav...SPrimer/Part1/
http://www.pirate4x4.com/tech/billav...SPrimer/Part2/
Mr. 250r is offline   Reply With Quote
Old 02-14-2012, 05:29 PM   #24
dbash
I am new to this forum, I have owned a K-10 for 5 years and I am just starting a frame off resto mod and a smoother ride is one of my top goals. Thanks for this thread, as a result of reading it I was introduced to and ordered a full set of Deaver Leaf Springs 4" lift yesterday. I am seriously considering Bilstine's as well.
I will post a thread for my build as soon as the site gives me permission to do so. I cant right now for some reason.
I have two and a half 67-72 trucks that I will post to be parted out as well. Again I am restricted from doing so for some reason right now. I have contacted the admin, waiting....
You guys are awesome there is so much info here I really wish I had found this forum sooner.
dbash is offline   Reply With Quote
Old 02-15-2012, 06:42 PM   #25
rocket20
how much lift dose the stock springs give you ? if i were to do this to clear 38s on a 15x12 wheel what would i need?
rocket20 is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
