Old 01-12-2012, 03:34 PM   #1
LockDoc
The Original Thread Killer
LockDoc's Avatar
How To Remove The Lock Cylinder From A Blazer Hatch Handle
First off I would like to thank Randy (teeitup) for sending me a handle to work with. His assistance made this "How To" possible.
To start with I like to soak down the handle good with PB Blaster and let it sit for a few hours before trying to dissemble it. If there is no rust or corrosion and the lock cylinder is loose in the handle you can probably skip this step. (highly unlikely)
First you have to remove the escutcheon retainer pin. (First two pictures) Then you can slide the spring assembly off and remove the escutcheon. (picture three) The spring assemby keeps the escutcheon tight aginst the handle and keeps the handle from flopping around in the hatch. When the escutcheon is off you will see the lock bolt and the cylinder retaining pin. (picture four) If you notice in the fifth picture one end of the lock bolt has a flat side on it, mark the handle with a punch mark so you know which side this end of the bolt was on. It does make a difference... Remove the cylinder retaining pin (picture six) and slide the cylinder out (picture seven). If the cylinder is stuck rap the handle on the palm of your hand and see if it slides out. ( make sure the cylinder will fall into your hand and not on the floor) if it doesn't come out try gently rapping one end of the "T" on a more solid surface. I use the edge of my workbench with a folded shop rag on it. You want to rap it as close to the cylinder as you can without the cylinder hitting the bench. Again, hold your hand under the cylinder so it doesn't fall on the floor. After the lock cylinder is out remove the lock bolt. It just slides out. CAUTION! Do not try to remove the lock bolt until the lock cylinder has been removed... If it is stuck you may have to use a small hammer & punch to remove it. Picture eight shows the lock cylinder out of the handle, and picture nine shows what the lock bolt looks like. Clean everything up including the lock bolt and the hole it fits in and you are ready for re-assembly. Once you have a key made put a small amount of Vaseline or thin grease on the lock bolt and put it back in the handle the way it came out, then insert the cylinder with the key in it, making sure it is flush with the face of the handle. Turn the key and make sure that the solid end of the lock bolt slides out of the handle OK. With the lock bolt in the out position put your fingers on the face of the lock cylinder and make sure you can pull the key out. If you can't you may have to pull the cylinder out slightly and rotate it 180. If it works okay put the cylinder retaining pin back in and finish the assembly.
I did not find any code numbers on the lock cylinder so a key could not be cut by code. These are a pretty simple lock and it should be no problem for a good locksmith to cut a key for these. I didn't try it but it looks like the wafers for the older GM glove box locks will fit the handle cylinder, so it wouldn't be a problem to key the lock to an existing key or match the other locks on a vehicle, if a different handle were purchased. The following key blanks fit the lock cylinder I worked on: B40 ("A" keyway), B42 ("C" keyway), B44 ("E" keyway), B45 ("H" keyway), B46 ("J" keyway), & B47 ("K" keyway). If all of the handle cylinders are made the same then they should be keyable to any of these existing keys.
LockDoc
Leon
Old 01-12-2012, 03:36 PM   #2
LockDoc
LockDoc's Avatar
Re: How To Remove The Lock Cylinder From A Blazer Hatch Handle
Rest Of Pictures.
Leon
Old 01-12-2012, 04:49 PM   #3
gcburdic
Restoration Virgin!
gcburdic's Avatar
FAQ stuff right there...thanks for your time and detailed write-up on this Leon...we appreciate you contributions!
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban
Current Resto: 1966 Mustang-Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 01-12-2012, 07:44 PM   #4
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Thats it! Thanks Randy and Leon. This will help us out alot. Time to re-chrome my handle and get a key made up!
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 01-12-2012, 07:45 PM   #5
rockc
Thanks for the info. This will help a lot.
Rock C
72 chevy 3/4 ton 4X4
rockc is offline   Reply With Quote
Old 01-12-2012, 08:08 PM   #6
LockDoc
LockDoc's Avatar
Thanks guys. It didn't take too long to do it once I got started on it. Took longer to size down the pictures than anything...
LockDoc
Leon
Old 01-12-2012, 11:27 PM   #7
YBNORML
YBNORML's Avatar
Excellent work, great detail. Thank you for your time!
Jason.
Please note : Any items I have posted for sale are also listed locally and listing may end at any time.
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 01-13-2012, 08:11 AM   #8
rsavage
rsavage's Avatar
Nice how to do it, Leon. Thanks.
1961 C1 Corvette
69 Blazer K5
2019 Ram Rebel
rsavage is offline   Reply With Quote
Old 01-13-2012, 09:11 AM   #9
teeitup
Just like to part out trucks!!
teeitup's Avatar
Leon, you did good!!!!!!!! Thanks for your time doing this. Randy
67 Chev swb stepside 4x4 283 4 speed w/ 2 inch lift
72 blazer 4x4 4 speed Cheyenne build in process
1958 Cameo (one of 1405 built, it was my dads)
1988 Chev SWB 4x4
2011 Crew cab Z71
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 01-13-2012, 02:31 PM   #10
4oldcars
4oldcars's Avatar
Leon! You da man!
4oldcars
Driving:
1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado
The ones I let go:
1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed
4oldcars is offline   Reply With Quote
Old 01-13-2012, 05:24 PM   #11
D.PASSMORE
One of the First
D.PASSMORE's Avatar
I took my first one apart today! Gotta find a reasonable plating company now.
Old 02-18-2012, 02:31 AM   #12
augie
Waiting for Paul to Open Safe
augie's Avatar
Thanks for the great work Leon! A copy is over in the FAQ area here http://67-72chevytrucks.com/vboard/s...d.php?t=509656
Norwood Survivor
http://squarebody.net
augie is offline   Reply With Quote
Old 03-11-2012, 08:50 PM   #13
D.PASSMORE
One of the First
D.PASSMORE's Avatar
I figured I would share the pictures of my re-chromed handle. Sent it off to Spacecoast Plating & Metal Refinishing, Melbourne, FL. Paid $94.00 for shipping (both ways) and plating. Came out really nice. Had the lock cylinder re-keyed - $25.00 to $50.00. So, you could put $125 - $150 into it and have a nice/new peice. Took a while to find a used handle. All the re-keyed / decent hatch handles that I looked at were well over $200. Good luck!
David
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
Old 03-11-2012, 09:21 PM   #14
BOHICA
BOHICA's Avatar
Thanks, guys, this is very helpful.
Since I'll be using mine for camping, I've been wondering... Could a hole be cut inside the hatch for an interior handle to be rigged up? I want to be able to open/close mine from the interior, but don't have a top or hatch yet that I can look at.
1954 Ford F-100
1956 Chevy big window
1970 4x4 Blazer CST
1987 Land Cruiser
1990 Chevy K3500 454
BOHICA is offline   Reply With Quote
Old 03-11-2012, 10:17 PM   #15
Bentblazer
Bentblazer's Avatar
I used a garage door handle and the square shaft is longer, it might work.
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
Bentblazer is offline   Reply With Quote
Old 03-19-2012, 07:03 PM   #16
oldrustytrucks
Awesome! Thank you!
oldrustytrucks is offline   Reply With Quote
Old 12-28-2012, 08:55 PM   #17
Dale99
Bringing this back to the top.
So if I understand this it is....
roll pin
roll pin
lock bolt
lock bolt, I need to punch and hammer on the notched side forcing it out on the full round side?
2008 Sierra k3500 LMM
1994 s10 blazer 4x4
1991 Camaro Vert Rusted in Half RIP
1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364
1967 C10 L6/3tree(dads truck)
Dale99 is offline   Reply With Quote
Old 12-30-2012, 04:46 AM   #18
roOstersan
roOstersan's Avatar
Wow... Good stuff!!
My single wall came with a garage door type, (still looking for a factory,original). Thanx for sharing this great information.
roOstersan is offline   Reply With Quote
Old 12-30-2012, 10:38 AM   #19
Dale99
FYI, the key part needs to come out before the lock pin. Otherwise you will sheer a pin off the key part. Damaged 3 locks yesterday tell I learned this.
Old 01-01-2013, 09:26 PM   #20
jaros44sr
jaros44sr's Avatar
Thanks Leon for your time and pics....my problem is the the lock bolt is half way out, now the plate wont come off. Ill have to drive the lock bolt back in. But at least i now know what im dealing with
thanks dale for finding this... Should be in the faqs
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-03-2013, 08:38 PM   #21
Big Block
Big Block
Big Block's Avatar
Thank you for the great write up.
Big Block is offline   Reply With Quote
Old 01-17-2013, 11:47 AM   #22
LockDoc
LockDoc's Avatar
Thanks guys. Sorry, I guess I need to check this thread once in a while.
Yes, as it says in the instructions in my first post "After the cylinder is out remove the lock bolt. It just slides out." I will add to my original post to make it more clear.
Originally Posted by jaros44sr View Post
Thanks Leon for your time and pics....my problem is the the lock bolt is half way out, now the plate wont come off. Ill have to drive the lock bolt back in. But at least i now know what im dealing with. thanks dale for finding this... Should be in the faqs
It is in the locked position then. If you take it to a locksmith he should be able to pick it to the unlocked position pretty easy if the lock cylinder is not frozen. It is just a simple wafer lock. As stated above If you drive the lock bolt "in" or "out" you will ruin the lock cylinder.
If anyone has a question on this procedure please don't hesitate to PM me.
LockDoc
Leon
Old 01-17-2013, 02:41 PM   #23
Dale99
My comprehension of what I read sucks as well. So that doesnt help the situation either.
Old 01-17-2013, 05:30 PM   #24
LockDoc
LockDoc's Avatar
.. I have that problem once in a while too. I think what I added to post #1 and post #2 will help though. Sorry I wasn't checking the thread. It might have saved you from ruining your cylinders.
LockDoc
Leon
Old 04-14-2013, 02:45 PM   #25
TRUCKRUNNER67
How do u get the handle out of the top
TRUCKRUNNER67 is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
