Old 02-15-2012, 02:45 PM   #1
72chevydump
72 Chevy k20 350 won't start
Hello all. I'm having some trouble with a dump truck I just bought. It had a cracked exhaust manifold when I bought it so I replaced them with a set of headers. Well in the process I dented the d/s valve cover. I removed the cover and used a block of wood and a hammer to straighten it all out. Looked pretty good so I reinstalled the cover. Started the truck and had a tap, tap, tap then shut off. Tried to start again and it would only run for 2 or 3 seconds then shut off. Did that a hand full of times then said screw it and pushed the truck outside. I figured from the rockers hittin the cover it wasnt letting the valves open all the way hense the stalling out right away. It sat for about 10-14 days until I got a new cover.
So today I pulled the old cover and replaced with a new used cover. New cover is straight and true. Put the new one on and tried to start it and it just cranks.
The old cover there were 2 light rub marks no deep gouges or anything just rubbed smooth a lil. I'm praying it isn't a bent valve.
Any and all info is greatly appreciated. Would like to get her going cause thy are calling for some snow.
72chevydump is offline   Reply With Quote
Old 02-15-2012, 04:03 PM   #2
cdowns
cdowns's Avatar
Re: 72 Chevy k20 350 won't start
replace fuel filter inside the carb body if it's a quadrajet
Old 02-15-2012, 04:21 PM   #3
72chevydump
I think it is a quadrajet. Any link to how that is done or can anyone kinda walk me through it. Can I clean it?
I am pretty new to carbs. Not really sure what I'm looking for.
Old 02-15-2012, 04:27 PM   #4
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
I don't think your dented valve cover has anything to do with it.. But maybe in the process of replacing it you had a coil wire come off? I would check for spark at the plugs... If none then check to see that you have voltage to the coil. And make sure your coil wire[ from coil to distributer]is making contact.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 02-15-2012, 04:30 PM   #5
dukcaln
dukcaln's Avatar
follow fuel line to front of carb, remove the nut and slide the line and filter out. clean or replace and install again. Have you checked to see if you are getting spark? When it turns over can you smell fuel? More info needed so the members can help
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP
SOLD 1972 chevy c10
dukcaln is offline   Reply With Quote
Old 02-15-2012, 05:32 PM   #6
72chevydump
During the header install I replaced all plugs and wires. Started no prob. But then shut off. I made sure all plug wires were tight at the distributor but still no start. If I manually play wit the carb I can watch fuel spit out but when I'm cranking it inside the cab I do not smell fuel. I will check for spark and try the carb filter.
Ok. There is spark. It is getting fuel.
Gave it a spray of ether and it wouldn't even run on that.
Old 02-15-2012, 05:55 PM   #7
rsavage
rsavage's Avatar
When you replaced the wires did you do it one at a time? If not, start with #1 and follow the firing order around the cap clockwise to make sure they are on the right plug. Driver's side staring at the front has cylinders 1,3,5,7. Passenger side starting at the front has 2, 4, 6, 8. Firing order is cast in on the top of your intake manifold. Make sure the cap is on square if you had it off, and make sure you didn't break the rotor if it wasn't on straight.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 02-15-2012, 06:18 PM   #8
moneypit69
Maybe from the short run time you may have flooded it? Pull one of the plugs to see if it is wet.
moneypit69 is offline   Reply With Quote
Old 02-15-2012, 07:22 PM   #9
dukcaln
dukcaln's Avatar
x2 check the plug. did you mess with the timing at all. gotta be something simple since it was running when you shut it off. look for the obvious first
SOLD 1972 chevy c10
Old 02-15-2012, 10:18 PM   #10
72chevydump
I didnt replace them one at a time no. But I did go by a diagram when putting them back on. I will recheck them tomarrow. The plugs are not wet and I didn't mess with the timing at all.
Could a push rod be bent? There are 2 shiney spots on the old valve cover from where they were hitting/rubbing.
Old 02-22-2012, 11:20 AM   #11
72chevydump
Ok. Sorry for the time lapse I have been busy and finally got back around to working on the 72 Chevy 350.
So I found out that in the process of denting the valve cover I must have stuck one of the rockers. The 3rd cyl back on the drivers side (#5 i think) the rocker closest to cyl #3 only moves maybe a 1/4"-1/2". With the cover off and cranking the motor I can watch all the rockers moving lets say with 1" of travel up and down with the exception of that rocker. It's the 4th one in from the firewall making it the 1st rocker/valve(front to back) on the #5 cyl.
Any and all help greatly appreciated.
Old 02-22-2012, 01:21 PM   #12
Tomahawk30
Tomahawk30's Avatar
This is just spitballin, and may not help at all, but make sure the spring for that rocker isn't busted. I had this happen on my 65 Impala. The spring cracked in half, but the break was on the rear where i couldn't really see it initially. Being a complete newbie at the time, I overtightened that rocker and bent the crap out of the lifter. I lucked out and just had to replace the lifter and spring and it ran like a champ.
1979 Silverado C10 Shortbox - Photo Album
1977 Silverado K20 Camper Special - Photo Album
1972 C10 Custom Deluxe Highlander - sold
1971 Cheyenne Super Longhorn -sold
1972 Cheyenne Super SWB 4x4 -sold, bought back, sold again... I'm dumb.
1970 Chevy C10 SWB "Sprout" -sold
1972 Cheyenne K20 -sold
1969 GMC Shortbox Stepside 4x4 -sold
1972 GMC Jimmy 4x4 -sold
Tomahawk30 is offline   Reply With Quote
Old 02-22-2012, 02:37 PM   #13
72chevydump
To check for this do I still need to pull the head or can I check while it's still on the truck?
Old 02-22-2012, 03:40 PM   #14
FrankieD
FrankieD's Avatar
Was it a running driver when you bought it? If it had been sitting for a while the gas could be bad also check the points if it still has them I believe the gap should be .030 use a small file and gap them and make sure the file or emery and feeler gauge is clean no oil residue. Re trace your steps, check the coil for cracks where the wire goes in or if oil leaking from it or inside it. Your spark should be a bright blue if it’s orange you have a weak coil.
As far as the spring look and feel real close for a broken spring but it should still run with one bad cylinder, there is a fitting you can get at the parts store that you can put an air fitting in and pressurize the cylinder with both valves closed to see if the valve is all the way up, if the spring is broke with the valve all the way up it will be loose.
I would stick with ignition and gas, one other thing did you pull the starter? Check the wires on the starter if original you should have 2 wires, the out side one is for the ignition and the inside one is for the solenoid you could of possibly put them on backwards which would let it start while you crank it and shut off when you let the key go I know I did it and it drove me crazy. You could of also nicked or broken the wire while installing the headers.
Here is the wiring diagram.
94 k2500 EXCab Long Bed 350ci New Toy
95 K2500 Suburban New PlowTruck 454ci
Support our Troops @ http://anyairman.com
http://www.woundedwarriorproject.org/
FrankieD is offline   Reply With Quote
Old 02-22-2012, 04:02 PM   #15
72chevydump
Yes it was running when I bought it. The top coil where the 2 wires connect are def oily. I don't rem the color of the spark but I did install new plugs and wires. I gapped the plugs correctly. If the spark is weak will it not fire? I didn't touch the starter. Just removed the main power wire to install the headers.
After the header install it fired right up but only ran for about 20 seconds. After that it would only fire up and run for 3 seconds. I know I screwed up the plug wires the first time and it's prob still out of time but we are having a hell of a time getting it in time.
Old 02-22-2012, 04:33 PM   #16
Tomahawk30
Tomahawk30's Avatar
Full disclosure: I'm a crappy mechanic. But the broken spring is just one of those things I've run into and worked through on my own. And one of the few things that turned out to be GOOD news as it was a really easy fix!
You just need to pull the valve cover to check the individual springs. Not sure if this has anything to do with it running then dying, but without the pressure of the full spring pulling the valve upward, that valve will fully seat and that cylinder has no compression. I actually found the broken spring on mine after I'd done a compression check and had no pressure at all on that cylinder. The broken spring made that valve pretty darn noisy. Again, no clue if this is even the right track, but if you have the valve cover off it isn't hard to take a second and look all the springs over just in case.
Old 02-22-2012, 06:00 PM   #17
rsavage
rsavage's Avatar
Based on your description, I still think it is either spark plug wiring and timing or fuel issue. Even if you bent a pushrod (why don't you remove that rocker and check the pushrod and rocker and spring) the engine should run on 7 cylinders easily if it has fuel and correctly timed spark. Start over from scratch - put it on TDC on number 1 with both valves closed, make sure your rotor is pointing at number 1 on the cap when the cap is seated on the distributor and follow the firing order clockwise insuring that the wires go to the right cylinders. It ran before you changed the plugs and wires right? If so, start there. Good luck
1961 C1 Corvette
2021 Durango RT 5.7
Old 02-22-2012, 07:31 PM   #18
Tomahawk30
Tomahawk30's Avatar
I agree that is should run on 7 cylinders. I certainly don't think the spring would be the ONLY issue, as mine was still running (rough) with no compression on #6. The other symptoms just sounded painfully familiar so I thought I'd put it out there to at least take a look at them.
It does sound more like an ignition / timing issue with it only running briefly. I actually had THAT issue with my 69 GMC last spring. Fought it and fought it between cold weather spells, and finally determined it was combination of EXTREMELY advanced timing, and poorly gapped (and eventually fouled) plugs. I eventually started from scratch, pulled and reseated the dizzy, set TDC on number 1, gapped and replaced the plugs, and it started right up on the first tap of the starter. It has started with little to no effort ever since, even in single degree temps.
I've definitely made a lot of mistakes playing with my rigs, but eventually you learn something when you fight your way through it (and do a lot of reading on the forums!).
Old 02-23-2012, 12:19 AM   #19
72chevydump
Thanks everyone for your all your input thus far. Greatly appreciated.
When I am finding tdc on comp stroke my thumb is being blown off the sparkplug hole on #1 cyl. Correct? As soon as that happens I then check the distributor. The rotor(little metal tab) is pointing almost directly at the drivers seat. Standing at the front of the motor it's pointing like 1 o'clock. Is that correct? So now i put my #1 plug wire in that spot on the distributor cap and follow the firing order clockwise. Also I noticed there is a groove/line on the harmonic balancer and that line is about 2" past the timing tab.
The timing tab is around the 2 o clock position and the line falls after the tab around the 3 o clock position. I dont know if that needs to at a certain spot.
I never pulled the distributor out. Just changed the wires. I don't know about previous owners but I havent removed it.
Old 02-23-2012, 12:29 AM   #20
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
here
John
1999 Toyota Tacoma 4x4
Old 02-23-2012, 12:34 AM   #21
oldblue1968chevy
Im not an expert just know enough to get in trouble
I usually stick my finger over the hole soon as i feel it blow it off i turn the harmonic balancer clockwise until I line up the balancer mark on the 0 on the timing tab
Should be #1 tdc compression
John
Old 02-23-2012, 08:10 AM   #22
rsavage
rsavage's Avatar
The above diagram is for an HEI distributor where there is no "points adjustment door" and number 1 is at the 5:30 position as you look back at the distributor. If you have a points distributor, Number 1 is the first one on the cap to the left of the point adjusting door as you are standing in front of the truck looking at the distributor on a points distributor.
Here is a diagram for a points distributor and there is an article that it is from that will help you for either a points or HEI distributor:
http://www.classiccarauto.com/impala...istributor.png
Here is the article:
http://www.classiccarauto.com/impala...ng_order.shtml
If you have the valve cover off, click the engine over until the timing mark on the crank balancer lines up with the 0 TDC mark on the timing tab on the timing chain cover. Look at and feel both rocker arms for the number 1 cylinder - both should be fully up with no pressure on them. The piston is at the top on both the compression stroke (what you want) and the exhaust stroke (the exhaust valve would be open What you don't want). If your distributor is in correctly, the rotor should be pointing at the number 1 on the cap. Your vacuum advance if it is a points distributor should be pointing at about 8:00 o'clock for initial starting.
If your rotor (assuming a points distributor) is pointing at 1:00 o'clock instead of 7:00 - 7:30 it is one of two things - you were on the exhaust stroke not the compression or your distributor was put in 180 degrees off.
1961 C1 Corvette
2021 Durango RT 5.7
Old 02-23-2012, 10:52 AM   #23
72chevydump
Where is 0 on my timing tab. I can't see any numbers it just has like 5 teeth. Would it be in the middle? It is the factory timing tab if that helps at all
Old 02-23-2012, 01:13 PM   #24
rsavage
rsavage's Avatar
I looked at the one on my Blazer and it has 7 teeth with 0 (TDC) being the middle one. There is writing on the tabs - usually "before" and "after" and numbers like 2, 4, 6, etc. Clean it off real well and you will see them. Mark 0 with some chalk along with the timing mark on the crank balancer.
1961 C1 Corvette
2021 Durango RT 5.7
Old 02-23-2012, 02:13 PM   #25
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
Did'nt see wher you said if it were an HEI dizzy or not but if you do have points the gap should be .017 not .030 If you were to use a dwell meter to check the points the dwell should be set to 30
from what I have read here about your problem its sounding like a ignition problem, if it wont start on starting fluid it is probably not a getting spark.
good luck
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
