Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 02-17-2012, 12:25 PM   #1
m455sx
m455sx's Avatar
62 wiring diagram
Does anybody have or does anybody know the wiring diagram for guages to the motor. I have purchased a wiring harness for the guage kit and was wondering if i have to buy one for the guages to the motor. Attachement is the new AAW wiring harness i installed for the guages, making sure it is istalled correctly since i do not have guages now. Hopefully the harness will plug up to the existing harness in truck.
1970 442 convertible
1970 Cutlass SX
1962 Chevy Stepside
2011 GMC 3500HD Crewcab SLT DRW
m455sx is offline   Reply With Quote
Old 02-17-2012, 01:08 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: 62 wiring diagram
I have one for the 64 so I will post it up. the wires are generally as follows.
1. Green--temperature sensor wire to temp light in dash or to temperature gauge. It looks like the far left in your picture.
2. Pink and Tan small wires to the fuel gauge, The pink goes to the fuse panel and the tan goes to the fuse panel and then to the fuel tank sender.
3. The gray wires are just the dash light wires. The light blue and dark blue on the 64 dash are for the directional signals, I'm not sure what the dark blue wire is on your dash.
4. Now her is a big difference between the two. All the positive power to your truck goes through the amp meter and there should be two large wires running to it. The fourth diagram shows how it is wired. I think the 63 was the last year this style amp meter was used. The 64 diagram shows a charging light in the diagram I posted. It looks like the amp meter in your attachment has the red and black wires going to it.
This is the engine diagram. If you follow the wiring colors you can see where they go. Green to temp and dark blue if you have a light is the oil light.
This is the fuse panel and cab diagram. If you follow the pink and tan wires from the gauge lights back to the fuse panel you can see where they go.
This is the wiring to the tail lights and the fuel tank sender which is a tan or light brown wire.
This is the old style amp meter wiring which will have large wires on each side of the amp meter. The main thing to remember is that both these wires are positive and do not hook a ground to either side or the harness will burn up, or worse.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 02-18-2012, 08:16 AM   #3
m455sx
m455sx's Avatar
the green wire far left i believe is the high beam light and the lt blue and dark blue is turn signal indicator i need to switch those. the temp sensor wire is dark green and pink. i believe as long as the green wire make a connection the the sending unit i should be ok?
1970 Cutlass SX
1962 Chevy Stepside
Old 12-05-2015, 09:01 AM   #4
chicken
chicken's Avatar
scribed
making the tobaccoo company mad by growing my own bacca.
chicken is offline   Reply With Quote
Old 12-05-2015, 08:48 PM   #5
ray_mcavoy
I haven't been able to pin down the exact year GM changed from the full flow to the external shunt type ammeters. However, some of the wiring diagrams in the 60-66 truck assembly manual seem to indicate that it may have been as early as 1960 (at least for some models/applications). And it appears as though the C/K series were pretty much all changed over to the external shunt type by 1961.
From what I've seen on the 1962 wiring diagrams:
The cluster harness is considerably different. But you've addressed that issue already by replacing it with the correct one for gauges.
The dash harness is basically the same for trucks with either warning lights or gauges. GM simply re-used the dark green "hot" light wire for the temp gauge. And they re-used the red "gen" light wire for one leg of the ammeter circuit. They also re-used the light green "cold" light wire for the other leg of the ammeter circuit. Yes, that does make for inconsistent color coding having that leg of the circuit change between black & light green.
The engine harness is slightly different for warning lights vs. gauges. The light green wire for the "cold" light is not present in the gauge style harness. Instead, there is a black wire with a 3 amp inline fuse that connects one leg of the ammeter to the "BATT" stud on the starter solenoid. To duplicate this (minus the color code) you could simply disconnect that light green wire from the old temp switch, add an inline 3 or 4 amp fuse, and connect it to the starter solenoid "BATT" stud.
The front light / generator harness is the same for trucks with either warning lights or gauges. However, there is a very important connection difference at the voltage regulator. Trucks with warning lights have a 20ga red wire for the "gen" light connected to the "ARM" terminal of the regulator. With gauges, that wire gets moved over to the "BATT" terminal on the voltage regulator. The 1961 Chevy truck shop manual supplement has the following to say about that connection:
When the vehicle is equipped with an ammeter, it is absolutely necessary that the 20 gauge red wire be connected to the BATT terminal on the voltage regulator. If the wire were connected to the ARM terminal of the regulator, a dead short would result which would quickly burn up the wiring in the ammeter circuit. To guard against this occurring, a 3 amp fuse is included in the ammeter circuit. This fuse is located in the wiring harness just ahead of the dash connector on the engine side of the dash panel.
I'd also recommend adding another 3 or 4 amp fuse inline with that 20ga red wire. That'll give you a fuse in both legs of the ammeter circuit to protect against over-current through the meter and shorts to ground on either leg.
ray_mcavoy is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
