Old 02-25-2012, 04:57 PM   #1
Touchdown67
Touchdown67's Avatar
Sway bar choices
Can anyone recommend a front sway bar for a 1965 C10. I have seen alot of aftermarket brands, which ones fit the best w/o having to modify anything?
Touchdown67 is offline   Reply With Quote
Old 02-25-2012, 05:00 PM   #2
Wrenchbender Ret
Re: Sway bar choices
I get them for 55-59 trucks from CCP. They are good vquality & fit good.
Wrenchbender Ret is offline   Reply With Quote
Old 02-25-2012, 06:07 PM   #3
64shortbox
64shortbox's Avatar
I got my Sway Bar from the local Self Serve wrecking yard. A front sway bar from a 67 - 87 Chevy Truck is a direct bolt in. I pulled mine from a 77 One Ton truck. It's 1-1/4" in diameter and set me back a whopping $20.30 A little time with a wire brush and rattle can of Satin Black spray paint and you're good to go.
Here's a fantastic link that should answer all your questions:
http://67-72chevytrucks.com/vboard/s...ad.php?t=72338
64shortbox is offline   Reply With Quote
Old 02-25-2012, 09:31 PM   #4
hd74
if it was at a pull your own part,i would like to know how you removed at the yard/ thanks
hd74 is offline   Reply With Quote
Old 02-25-2012, 10:20 PM   #5
protrash64
Resistance is Futile
protrash64's Avatar
8 3/8's bolts and nuts......done!
I used one off a 67-72. Got new bushings from Auto zone; painted gold!!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 02-25-2012, 10:21 PM   #6
k1rodeoboater
I got mine form a pull a part off of a square body. You should grab the brackets while you're at it. IDK why but the truck I got mine off of had bolts instead of rivets so it was easy. Luckily it was the 1st truck I looked at too. IDK if they're all like that or not.
BTW if you're lowered you don't need those brackets. Just get new bushings, mount to the A Arms first, then hold it up to the frame and figure out if you need to drill 1 or two holes for the frame mounts. We did this on my buddy's squarebody and it worked great.
1966 C10 Long step build on a budget http://67-72chevytrucks.com/vboard/s...d.php?t=445201
no garage, no shop, limited storage space and tools....no problem.
k1rodeoboater is offline   Reply With Quote
Old 02-25-2012, 11:27 PM   #7
nomrlz
nomrlz's Avatar
I originally was going to use the 1/2 ton swaybar on the 86 front I'm bolting under the 66. Then after reading on here. I found a 1 ton bar off an 84. Then goin to do the factory iroc rear bar
nomrlz is offline   Reply With Quote
Old 02-26-2012, 02:31 AM   #8
Woogeroo
sway bar options for 1960-1966 trucks
as Wrenchbender Ret. mentioned, CPP sells 'em.
Early Classic Enterprises also sells the sway bar, the brackets, bolts and bushings... all together or separately.
-W
update/edit :
Make it handle : August 2010 /+1600 posts
all years, all sorts of trucks... lots of golden information in this one.
This is the thread scottofksu mentions below.
Be sure to explore the 60-66 FAQ Index for more links to threads and articles about sway bars. If this link disappears/changes, the 60-66 faq is maintained as a sticky at the top of the 60-66 message board forum.
Find answers for your 1960-1966 Chevrolet Truck Questions.
Matraca - my 1965 Chevrolet C10 lwb step side
I am unable to reply to send/reply Private Messages since October 2014, so I am not ignoring anyone. Please visit my linked pages above if you wish to ask me anything... I am no longer welcome on the forum, it is a simple fact, nothing more. shadowbanned!
Last edited by Woogeroo; 11-21-2013 at 05:25 AM. Reason: updated URL for sway bar article
Woogeroo is offline   Reply With Quote
Old 02-26-2012, 08:30 AM   #9
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Great thread!! Subscribed.
Steve
61_FL_Apache is offline   Reply With Quote
Old 02-26-2012, 09:26 AM   #10
scottofksu
scottofksu's Avatar
You should check out the "Make it Handle" thread In the suspension area. It will blow your mind... Reason I mention it is that the optimal sway bar size is discussed somewhere in the thread as is the best types of bars to consider.
Travis' Tribute Truck - 65 C10 Frame Up Restoration
http://67-72chevytrucks.com/vboard/s...d.php?t=495073
scottofksu is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
