![]() Join Date: Aug 2003
1965 Chevrolet C10 - deluxe heater - blower motor - loud squeal on highest fan setting.
Is this something that needs lubrication or is it a death squeal? It is a loud and persistent high pitched squeal... I thought maybe it was dusty or unbalanced, so I tapped on the case housing with it running and squealing and it will quit for a little while, then start back. Is this a bearings going bad situation or does it need some lubrication somewhere? Any tips are appreciated. Thanks. -W 02/02/2013 update EDIT : Burgie's heater box rebuild on his 1964 c60, with photos and more. If you have the same type of heater box, this article will help you a whole lot! ---- photos on my site of the heater box assembly: 02/17/2012 : 28 pics – heater core unit re-assembly
Find answers for your 1960-1966 Chevrolet Truck Questions.
Matraca - my 1965 Chevrolet C10 lwb step side I am unable to reply to send/reply Private Messages since October 2014, so I am not ignoring anyone. Please visit my linked pages above if you wish to ask me anything... I am no longer welcome on the forum, it is a simple fact, nothing more. shadowbanned! Last edited by Woogeroo; 02-02-2013 at 06:34 PM. |
![]() Join Date: Jan 2011
Re: 1965 Chevrolet C10 - heater blower motor squeal?
The bearings are dying, throw a new motor in there, they're cheap.
since it is so nice and nearabouts freezing outside, I left the hood up so it'd cool down faster.
I went ahead and took the blower motor out to check it out. I sprayed a lot of that electronics spray cleaner on it to knock the grime and dust off of it, then let it dry. I also hooked it up so I could run it without it being in the cage and turned it off and on and it didn't squeal again, yet. I put it back together and reinstalled it, sitting still in the driveway, no squealing... hmnn. Not sure what it'll do when I fire it up tho' and get it hot again! Any tips and suggestions are still appreciated. Oh yeah... how do you get the fan off of the motor without destroying them both? I saw the little nut on the shaft there... and I'm guessing it is press fit on... and the piece just below the nut looks like it is separate from the rest of the fan. Thanks folks, -W
Matraca - my 1965 Chevrolet C10 lwb step side I am unable to reply to send/reply Private Messages since October 2014, so I am not ignoring anyone. Please visit my linked pages above if you wish to ask me anything... I am no longer welcome on the forum, it is a simple fact, nothing more. shadowbanned! |
#4 | |
![]() This is where you`re squealing is comming from. drill two holes in the hub, and insert two 1/8 rivets into it.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
I get that the nut comes off... then just pull firmly on the cage until it comes off?
Is there another piece on there that also comes loose, after the nut is removed? -W update : the squealing "Heater/AC Fan Fix" tech article link on persh's site
Matraca - my 1965 Chevrolet C10 lwb step side I am unable to reply to send/reply Private Messages since October 2014, so I am not ignoring anyone. Please visit my linked pages above if you wish to ask me anything... I am no longer welcome on the forum, it is a simple fact, nothing more. shadowbanned! Last edited by Woogeroo; 07-01-2012 at 01:51 AM. |
Not sure woog that was from Persh`s site he had the same issue, fan breaks loose from the hub and just squeals, drill the holes in the middle of the break slightly angled in towards the hub, then insert rivets.
![]() Join Date: Feb 2010
Mine was squealing cause the bearings went bad. Put oil on the shaft after i got the nut off and waited a few days and then used a screwdriver to pry it up carefully around the edge. That cage is pretty flimsy.
ok... using an excellent tip from Wrenchbender Ret.(thanks W.R.!), I got the cage loose... take the nut off, hold or have someone else hold the fan, then tap on the shaft... once it is flush, use a punch or a small screwdriver, etc.. to tap it on through. pop. It is off. Yay.
An issue I had with the replacement motor: the replacement motor(from the parts stores - Siemens VD0 PM102) is longer/deeper and did not want to go back into the heater housing space with the fan on. This is a problem. ![]() I didn't want to pull the entire heater core and housing unit again unless I absolutely had to, so I did some thinking. ![]() This is what wound up working... I took my new motor and plugged it in and laid it down on the fender and the exhaust manifold so that it would get a good ground... why? To test it and make sure it works before I went through all of this hassle... it zoomed along nicely. OK, turn it all off, unplug it and let the aggravation begin... I looked at the old fan and the new fan... lined up the holes that were used and I marked the ones I needed to use on the new motor with a white paint pen(which I had laying around, cuz it is handy for touching up the white grill on a beat up truck, but I digress)... I removed the cage fan from the motor. I put the cage fan up into the housing and slightly on the bench inside so it wouldn't fall back down, then I wiggled the motor into the space, dropped the fan back down onto the shaft and then had a slight tussle with trying to get it to line up on the shaft. Then you have to wiggle the nut onto the end of the shaft with yer fingers and not really being able to see it(use the force!) and run it down finger tight. Once it was lined up and dropped down, there was not a lot of room, so I leaned the motor at an angle, with the cage fan still stuck partly in the housing, and used a small crescent wrench to slip in and tighten the nut down onto the shaft. I found that putting in the first screw, in the hole on the motor, which faces the front of the truck, gives a nice pivot point to work the other two side front holes for putting it all back into the housing. I used a ratchet, 1/4 deep well socket (space issues) one short extension and 1/4 regular socket, depending on which screw I was running in. Remember to plug the fan connecter back in on the back! Maybe all of that will be useful to someone in the future if they are stuck doing this. ![]() It blows the air real strong through the ducts now... whoo hoo. ![]() -W EDIT : this issue with the blower motor not sliding back up and in may only be an issue because of the later model v8(1992 block 350/5.7L) in my truck, I dunno. That is what is in there, so that is what I had to deal with. It may not be an issue in a 327 truck or a inline six, I don't know... but, thought I'd mention it, in case.
Thread Tools | |
Display Modes | |
