Old 03-12-2012, 11:28 AM   #1
C15_Sierra
C15_Sierra's Avatar
Bleeding cooling system
I'm running a stock '80 cooling system in my 5.3 swap, and I'm thinking over my lack of coolant flow issue. I thought it might be a new water pump, but now I'm doubting that and thinking that it's air-locked somehow.
I used '00 Silverado radiator hoses (my 5.3 is from a '00 Silverado), and the upper radiator hose runs up and across to the radiator inlet on the drivers side. I moved it down since it was the highest point in the system, but I'm still not getting any flow. It does seem like there's any coolant in there, so how can I bleed that hose so I can figure out if its indeed my water pump.
Previously, I replaced the thermostat, so I know that's good. Any other tips?
-Steve
1980 GMC C15 Sierra LWB
Dark Carmine Red/Carmine Int
Was: 250/3spd (1980-88), then a 305/TH350 (1988-2011)
Now: 5.3/4L60E, 2.73 12-bolt open rear
C15_Sierra is offline   Reply With Quote
Old 03-12-2012, 02:32 PM   #2
SeventyOne
Re: Bleeding cooling system
Did you run the engine w/o a thermostat and the radiator cap removed?
SeventyOne is offline   Reply With Quote
Old 03-12-2012, 05:32 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Is it running hot or above normal or you just can't feel water moving?
What I usually do is turn the heater to hot and run the vehicle with the cap off while I top off the radiator. Then I'll put the cap on, run it to operating temp (thermostat opens) and after it cools off check it and top it off again if it needs it and make sure the overflow container has coolant in it.
I'll say that in some vehicles you can't always feel water going through the upper hose. I guess I should say, I haven't always felt it but I know it's going through there cause it does get hot..
68gmsee is offline   Reply With Quote
Old 03-12-2012, 06:12 PM   #4
C15_Sierra
C15_Sierra's Avatar
Couldn't run w/o a thermostat because it's built into the water pump inlet housing, low in the system (so replacing it would defeat the purpose)
I didn't feel any heat in the heater hose or in the upper radiator hose...that shoulda told me something
What I DID forget was to back-feed coolant into the block via the upper radiator hose. Did just that, and lo and behold, she ran a steady 197 degrees according to the scan tool. Heater hoses had heat and so did the upper rad hose
Thanks guys!
-Steve
Old 03-12-2012, 06:38 PM   #5
cableguy0
The easiest way to bleed a cooling system is with a funnel like this one Amazon.com: Lisle 24610 Spill-Free Funnel:... Amazon.com: Lisle 24610 Spill-Free Funnel:... . It stops you from making a mess and having coolant blow all over the place from running the vehicle with the radiator cap off.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 03-12-2012, 08:48 PM   #6
68gmsee
Active Member
68gmsee's Avatar
Originally Posted by C15_Sierra View Post
..... lo and behold, she ran a steady 197 degrees according to the scan tool. Heater hoses had heat and so did the upper rad hose
Thanks guys!
Great going!
Originally Posted by cableguy0 View Post
The easiest way to bleed a cooling system is with a funnel like this one Amazon.com: Lisle 24610 Spill-Free Funnel: Automotive . It stops you from making a mess and having coolant blow all over the place from running the vehicle with the radiator cap off.
Good idea. I usually use a funnel but it never seems to want to stay in place. Might have to order one of these since my yearly coolant change is due on my vehicles... Thanks.
Old 03-12-2012, 10:10 PM   #7
truckdude239
truckdude239's Avatar
i got the same funnel at work not quite figured it out yet
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 101kmiles
2002 Honda Accord 4 door With 275k(sisters car)
1998 Honda Accord 4 door with 318k(brothers car)
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 03-12-2012, 10:40 PM   #8
cableguy0
The trick is to not fill funnel to the top. The coolant needs room in the funnel to expand. Also when it first starts pushing the air out while its running it will push the coolant upward. I keep the funnel filled to about when it goes from the large cone to round area right on the line. That way it doesnt overflow.
Old 03-13-2012, 01:58 PM   #9
fastwillie 696969
fastwillie 696969's Avatar
have you tried to jack the rear of the truck up
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
