Old 03-13-2012, 03:00 AM   #1
c10seconds
c10seconds's Avatar
Kooks 1 7/8 headers+ stage2 dropmember= WINNING
Headers are TBSS specific and have pretty good clearance on both sides. 1 7/8 3" collector full length headers They dont hang down as low as I thought they would. Seem like another good header option as long as I can get a steering shaft in there
Im using an Fbody oil pan
c10seconds is offline   Reply With Quote
Old 03-13-2012, 08:27 AM   #2
Shon
Re: Kooks 1 7/8 headers+ stage2 dropmember= WINNING
Nice
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 03-13-2012, 12:08 PM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
Very nice headers!
Is that the 'mild' DM? Did the engine move from stock? What was the problem with the Doug Thorley's?
Not related to headers- do your inner fenders still fit with that setup?
EDIT: Driver's side looks like it hangs lower than passenger's?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 03-13-2012, 05:03 PM   #4
c10seconds
c10seconds's Avatar
Originally Posted by gringoloco View Post
Very nice headers!
It is the mild dropmember and as far as I know, it leaves the motor in stock location.
For the guys with the extreme dropmember the DT 's didn't work because of the motor being raised. There are clearance issues at the firewall. They probably would have worked for me but I just decided on the kooks. The driver side collector is slightly lower than the passenger but I don't think it will be an issue.
I haven't checked to see if the stock inner fender will work. Would be great if they did but Ill have to check with Nate
Old 03-13-2012, 09:14 PM   #5
jtp67-72
jtp67-72's Avatar
Thinking out loud here but I'm wondering if those would work on my extreme drop --with motor raised higher that header plunge would be above bottom of frame----hhhmmmmm..what u think Shon-----and what is the part # for those??...........thanx jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791
jtp67-72 is offline   Reply With Quote
Old 03-18-2012, 06:05 PM   #6
texastrendz
Does anyone have a part number for these headers, any and all help would be appreciated for us ls1 dropmember guys.
texastrendz is offline   Reply With Quote
Old 03-18-2012, 09:00 PM   #7
c10seconds
c10seconds's Avatar
Kooks Part no.6311 on these 1 7/8
They also have the 6310 which is the 1 3/4. They would also work.
Old 03-18-2012, 09:18 PM   #8
jtp67-72
jtp67-72's Avatar
I'll buy U a beer if U could give me a measurement from bottom of f-body pan
to the bottom of header ......with that should be able to figure where header would be as far as clearing under firewall..I'm running f-body pan...thanx ...jim
Old 03-21-2012, 12:56 PM   #9
Super73
Super73's Avatar
Any chance you could take more pics for me. I am trying to get my Edelbrock 1 3/4 stepped to 1 7/8 out of my truck and tried fitting Kooks 2" 4th gen headers in and it's a no go. I know Kooks can make the TBSS headers in a 2" but don't want them made with out more pics.
Pics I would be looking for:
Where both collectors lie relative to the frame (How much room is there, outside of the collector to inside of the frame).
How close the tubes are to the back of the block (how fast they drop, I run a mid plate and worried they might protrude past the block and run in to the plate)
Also, what part number are these?
Thanks a ton!!
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 03-22-2012, 09:39 PM   #10
Last_Paladin
Wow, I think this is what I've been looking for. Thank you very much.
Did you get a steering shaft in there?
What motor mounts and reinforcing plates are you using?
Last_Paladin is offline   Reply With Quote
Old 03-25-2012, 01:09 AM   #11
c10seconds
c10seconds's Avatar
Motor mounts are standard ls mounts that come with the dropmember. Hope to have the steering shaft routed this week.
SUPER73 - I took more detailed pics of the header clearance that ill post shortly. I think they'll work for you. Im very happy with the way they fit.
Jtp - measurement coming!
Old 03-26-2012, 06:39 PM   #12
c10seconds
c10seconds's Avatar
more pics
Old 03-26-2012, 06:42 PM   #13
c10seconds
c10seconds's Avatar
few more
Old 03-26-2012, 06:52 PM   #14
jtp67-72
jtp67-72's Avatar
Great pics----just what I needed--need to get cab in place before ordering--If U don't mind me asking where was best deal on these ...I know there not cheap and I'm not looking for cheap...just best deal with a good vendor!!.........jim
Old 03-26-2012, 10:42 PM   #15
Super73
Super73's Avatar
Thanks for the additional pics!!
1 7/8 through Summit $799: http://www.summitracing.com/parts/KOK-6311/
1 3/4 through Summit $789: http://www.summitracing.com/parts/KOK-6310/
Old 03-27-2012, 01:43 AM   #16
c10seconds
c10seconds's Avatar
Jtp : the headers come down about 2.5" lower than the fbody pan.
Old 03-27-2012, 09:52 AM   #17
jtp67-72
jtp67-72's Avatar
Thanx---get the cab on and I will see about firewall clearance --your measurements and pics should keep me from making a $800 mistake with this extreme drop!!......jim
Old 03-27-2012, 12:01 PM   #18
Super73
Super73's Avatar
Summit will let send them back as long as you don't mess them up. I asked before I finalized my order on the camaro set and the tbss set I ordered.
Old 03-27-2012, 08:12 PM   #19
jtp67-72
jtp67-72's Avatar
That was smart--thanx for tip............jim
Old 03-27-2012, 08:55 PM   #20
Last_Paladin
So, install with blue tape.
Old 03-28-2012, 01:29 AM   #21
Super73
Super73's Avatar
Headers are scratched straight from Kooks in the bent sections. It's one solid tube they bend.
Old 03-30-2012, 02:47 AM   #22
GMC70c20
is your engine in the factory location? i set mine back about 4 in I dont know if the tube thats near wear the factory clutch linkage come through the firewall would clear. What do you mean by TBSS specific?
1970 c20 converted to c10 sleeper
1979 c20 the wood hauler
1991 honda civic daily driver
spray and pray baby
GMC70c20 is offline   Reply With Quote
Old 04-04-2012, 12:53 PM   #23
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
The LS2 powered TrailBlazer SS......and I need a set of those on mine!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 04-06-2012, 01:06 AM   #24
Super73
Super73's Avatar
Grrrr.. The passanger side header does not work for the simple fact that I have an aftermarket 6 bolt head. The passanger front tube passes through two of the lower bolt location. I technically could cut the two ears off, but if I ever go to and aftermarket 6 bolt block, I would need another set of heads.
Would never have thought about it, but this pic shows what I am talking about. Everything else would work with minor adjustments to the motor plate.
Old 04-06-2012, 09:34 AM   #25
Last_Paladin
I ordered a coated set off of LS1 tech. Should be here next week.
