Old 03-26-2012, 02:44 AM   #1
markeb01
Senior Enthusiast
markeb01's Avatar
Pedal Pad Question
Does anybody know if 67-72 brake and clutch pedal pads will fit on 60-66 pedals?
Also, has anyone ever tried to install 67 Chevelle brake and clutch pedal pads on a 60-66 truck? They sure do look similar in size and shape. I always liked the way the disc brake pads looked, far more than the truck pads.
Thanks for any input.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 03-26-2012, 03:23 AM   #2
Woogeroo
Talking Re: Pedal Pad Question
I want to write that the brake pedal is wider on the 67-72 trucks... but I'm not sure, it's just a visual in my head.
I'm sure someone in here knows.
What are you up to now markeb01 ?
-W
Woogeroo is offline   Reply With Quote
Old 03-26-2012, 02:47 PM   #3
1963c-10
1963c-10's Avatar
The truck pedals from 60-72 are the same size. Im not sure if the pedal for the 67-72 with the chrome trim will work on a 60-66, but the standard pedals will.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 03-26-2012, 03:28 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
-W
I'm gathering up the parts to switch over to a 71-72 cable throttle. I love the Cal Custom gasser pedal I've been using for years, but I've never been able to dial in the level of smoothness I'd like. So time for another project, and I'll end up with another hot rod trinket added to the garage wall collection. This is what's going away. I'll post photos of the project once it's in and working. I'm still waiting for stuff to arrive.
If I have to lose the pedal, I'd really like to add the Chevelle pedal pads. I waited a long time before I could afford to put a 4 speed and disc brakes in my 67 Chevelle and always liked the looks of those pads. They may fit with some modification to the steel mount. I'm probably going to find out one way or the other! It does help that I have a spare set of pedal arms to play with.
Old 03-26-2012, 03:29 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
Cool. Thanks for the input.
Old 03-26-2012, 03:54 PM   #6
1963c-10
1963c-10's Avatar
No problem.
Old 03-26-2012, 05:17 PM   #7
MisterC
MisterC's Avatar
Subscribed to this one for tracking. I want chrome trim on my pedals with the least amount of modification necessary.
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 03-26-2012, 06:23 PM   #8
Woogeroo
Wink Re: Pedal Pad Question
ah... it's the fancy chrome one I was visualizing in my head.
Thanks 1963c-10, that is good to know.
-W
Old 03-26-2012, 06:51 PM   #9
markeb01
Senior Enthusiast
markeb01's Avatar
If the 60-66 and 67-72 pads both fit the pedals, the trim shouldn't be any trouble at all. It just slips over the front and is retained with tabs like on the paper dolls my sister had as a kid. Here are gas pedal photos posted by another member, showing the trim front and back:
If I don't do the Chevelle pads, I'll probably add the later truck pads with the trim.
Old 03-27-2012, 11:13 AM   #10
1963c-10
1963c-10's Avatar
I would think that you are right in that the trim shouldn't be a problem. I know for a fact the standard covers will work though.
Old 03-27-2012, 08:45 PM   #11
ConnDemned
I would believe that chevy didn't make different pedals for cars and trucks seperate so those pads should swap right on to your pedals. I know the pads seem pretty universal from the 60s to the 80s. Maybe a quick visit to a junk yard to see if you could find some to test.
Last edited by ConnDemned; 03-27-2012 at 08:48 PM. Reason: posted before I finished my thought
ConnDemned is offline   Reply With Quote
Old 03-27-2012, 09:27 PM   #12
markeb01
Senior Enthusiast
markeb01's Avatar
I知 thinking the same thing. I went ahead and bought a new Chevelle/Camaro disc brake pad so we値l know soon enough. They listed the years from 67-81 so they are pretty universal. If it fits right on, I値l pick up a matching brake pedal pad. If it doesn稚, I知 going to remove the emblem and see what is required to mount it on a spare 1960 pedal pad I have, just to see what it takes. Depending on those results I値l either end up with Chevelle/Camaro pads or the 67-72 truck style with the disc brake emblem added.
I was amazed shopping for pedal pads what a huge variance in quality and originality are offered. Here are four different examples:
This is the one I ordered. The emblem looks authentic to me in both curvature, shine, and font. The emblem looks too high up on the pad because of the angle of the photo:
This emblem has been smashed in, and the font doesn稚 match the first example:
This one looks like a freeze plug and the pad is all stretched out of shape indicating the disc is too big to fit correctly:
And this is the worst of the lot. The emblem is smashed in at various depths around the stampings, and the font is blocky, looking very little like an original. It is also cut too deep into the pad, and the stainless surface is all scratched up:
It certainly does pay to comparison shop!
Old 03-28-2012, 08:48 AM   #13
1963c-10
1963c-10's Avatar
Yeah, I agree. The worst thing is that you can order the best looking one online and get the worst one delivered.
Old 04-15-2014, 11:55 PM   #14
eric8
So any word if the chevelle pads fit our pedals? I personally am no fan of the stock waffle pedal pads. Interesting you posted the design shown above in your first post as standard for 67-72 trucks, when I thought the waffle pads were the only ones offered on our trucks.
eric8 is offline   Reply With Quote
Old 04-16-2014, 01:15 AM   #15
markeb01
Senior Enthusiast
markeb01's Avatar
That is correct, only the waffle pads were offered in the 60-66 series. The 67-72(?) pads however fit perfectly on our pedals with or without the trim, with no modifications. I went ahead and added the later deluxe pads to mine. Here's a recent photo:
BTW, the Chevelle pads don't even come close. They look like 3/4 scale miniatures by comparison in real life:
Old 04-16-2014, 05:20 AM   #16
eric8
Man, I wish they made something that would fit that is similar to the deluxe pads, but without the stainless trim. I'm afraid that if I got the deluxe pads that you have (without the trim), it just wouldn't look right because you'd be able to see the cutouts where the trim is supposed to go.
Old 04-16-2014, 10:47 AM   #17
markeb01
Senior Enthusiast
markeb01's Avatar
Do you have a part number or a photo? I'd like to see them.
Old 04-16-2014, 02:35 PM   #18
markeb01
Senior Enthusiast
markeb01's Avatar
Very cool. Thanks for sharing, I didn't know they made a generic pedal pad like that. I might grab one of my extra pedals and see if it can be modified to fit the Chevelle pad.
Old 04-16-2014, 06:57 PM   #19
63burban
Chevy addict
Dude, totally dig your interior !!!!
63burban is offline   Reply With Quote
