show pics of your 4x4 exhaust
show how you ran your exhaust-------thanks
1961 chevy K10 my build is------------61K10 build |
GMC's n H.D.'s too!
![]() Join Date: Oct 2010
Re: show pics of your 4x4 exhaust
I would like to see this as well.
Jason 1960 GMC 4x4 Babe (the Blue Ox) - Build Thread 1965 Chevy C-10 Sleeping Beauty (My Son's Truck) |
'75 K5 3" duals into single 4". Pics aren't great but you'll get the idea.
This space for rent. |
Enjoying left field
What specifically are you looking for? Some guys have duels, some have singles. What motor and tranny do you have? Mines a diesel. I'm running a single 4" to duel 3" tailpipes.
Clint 70 Chevy 4WD "Ultimate Work Truck" 83 K5 6.2/700r4. 18mpg on 33's- Grenaded/sold 64 4 door Chevy II FI 250/t5 soon to be LS 5.3/t5 70 GMC Suburban LS 5.3/5 speed- Sold |
Pic #3 looks like that would heat up the trans.
I have a 61k-10 swb/fside sbc V8. 4sp and 221 tf case. I will probably go single in 2 1/2 (will be a stock 350 eng) walker has a nice front y-pipe (2") set up off ramhorns that crosses to the drivers side. plenty of room down that side. one problem i have is the pto driveshaft to the winch, might have to mod the y-pipe. of course i can build it from scratch as i might have to. also thanks for the pics-----
We can make that
![]() ![]() Join Date: Feb 2004
67 k10
![]() Join Date: Dec 2011
Well you had to ask. I know, but times are tough...lol..
"I once saw a six foot chicken eating prairie dogs like they were worms, but this was while driving between Janos, Chihuahua, Mexico and Agua Prieta, Sonora, Mexico on Route 9, after having consumed my share of El Presidente whiskey " ![]() |
Not a thread steal by any means but boz is your exhaust spot welded? and is that a diy4x inboarding shock kit? if so hows it work
as far as exhaust i HAD 91 suburban single stock exhaust with a glass pack that sounded perfect unfortunately i will be changing it to dual
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 t-top play toy 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 1995 Geo Metro - 5spd play toy - Sold 2001 3500 6spd 5.9L - Tow truck - Sold 2003 1500 Silverado - Weekender 2004 3500 6spd 5.9L - Tow truck - For sale LS info http://lsx4u.com/lsxinfo.html http://www.pirate4x4.com/tech/billav...SPrimer/Part1/ http://www.pirate4x4.com/tech/billav...SPrimer/Part2/ |
post up any exhaust--might give somebody some ideas.
![]() ![]() I have Thorley Tri-Y headers, H pipe right behind the Xfer case and two 50series Flowmasters. I have a HUGE 37gal gastank that takes up all the room right behind my rear axel so the exhaust guy had to route my tail pipes out side the frame to just behind the bumper. I told him make it high & tight and he did an awesome job. That and it's way secure..no shaking or wiggling anywere!! Solid! I had simple turn downs on my old exhaust and on the trail it sucked as MAJOR DUST blew out from under me..the guy behind me didn't like it too much also ![]()
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() |
#12 | |
The collector joint is slipped over the outside of the collector. It is a type of "V" flange. It slides over several inches & is a very tight fit. Only a few spot welds are required to hold it in place. It does not leak. That is the only place that is spot welded. Yes it is a DIY4x inboard kit. I like it. Just remember you need much stiffer shock rates when your shocks are inboard. Even stiffer when they are leaning. Sorry for the slow reply. I don't hit the innerweb every day.
#13 |
Looks that way, but i don't have any issues. I run a temp gauge in the pan to keep an eye on it.
#14 |
Resident of Here
Mine dumps there too. I cut the stock muffler out and welded a summit street/strip 3in/3out muffler in with a bend from the cut off exhaust for a turndown. stock 2.5 off the manifolds down to a crappy Y into stock 3".
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
Thread Tools | |
Display Modes | |
