04-22-2012, 12:44 AM | #1 |
1957 deluxe heater
what is the difference beetween deluxe and regular heater ?
04-22-2012, 11:32 AM | #2 |
Re: 1957 deluxe heater
I'm not sure about the Task Force Deluxe heaters but on the AD trucks the Deluxe heater had fresh air coming in from outside while the plain heater was a box bolted to the firewall that recirculated the air inside the cab time and again.
04-22-2012, 12:11 PM | #3 |
This is my firewall is it for deluxe or standard ?
Its because i whant to weld the holes i dont need but i dont have a heater box in my truck so i cant check the holes i need . the yellow holes if for a model of heater but im not sure wich one ? But there is more holes (RED) that i dont know why they are there ? |
04-22-2012, 12:41 PM | #4 |
Hey DG, Here's the bolt pattern off of my 57 with a deluxe heater.
04-22-2012, 12:54 PM | #5 |
Here's a deluxe heater in a '57 GMC, its a fresh air heater and the core is a flat style.
In the pic from the drivers side you can just make out the standard heater, its a non fresh air style and has a round heater core. Its in a '56 Chevy. |
04-22-2012, 01:18 PM | #6 |
Here's what the inside looks like.
04-23-2012, 01:12 AM | #7 |
Thank you guys so tomorow i will weld my holes .
And i will try to find a deluxe heater box . But if i find a standard heater box will it fit in the same holes ?? |
04-23-2012, 01:27 AM | #8 |
01-06-2014, 11:59 AM | #9 |
Hey 56ChevTruck,
It looks like you've done a great job at a full restoration of a Deluxe Heater, something I'm about to embark upon. Any advice, cautions or general tribal knowledge you acquired in the process would be most appreciated. Any lead on a source for core rebuild? Your heater looks great! How does it work on a bitter cold day? Thanks, Bill |
