Old 05-05-2012, 09:40 PM   #1
bucannon
Salty Sailor
bucannon's Avatar
Question using parking brake to get unstuck???
i have heard from people before that when you get a truck with open diff stuck in whatever your stuck in, use the parking brake and it acts like a posi?
i had a buddy that got out of sand like this once
how does this work??
86 c-10 Custom Deluxe
Savannah, Georgia
bucannon is offline   Reply With Quote
Old 05-05-2012, 09:52 PM   #2
ol'blu72
Re: using parking brake to get unstuck???
I have never used the parking brake but have used just brakes. I guess it would depend on which wheel was spinning. What it does is increase the friction on the spinning wheel therefore transferring more torque to the other wheels.
Brad
72 Blazer CST 350/350/205
ol'blu72 is offline   Reply With Quote
Old 05-05-2012, 10:28 PM   #3
Gumby
Gumby's Avatar
sure wouldn't want a floor stomper kicker/clicker, would want a hand lever with a button so you can apply just enough to create drag.
Gumby is offline   Reply With Quote
Old 05-05-2012, 11:16 PM   #4
'68OrangeSunshine
'68OrangeSunshine's Avatar
I got my '68 stepside stuck in some sand near the coast in North Carolina, not too long after I got it. A friendly guy stopped me from over-revving it. Said he used to have a truck just like mine. So I let him have the controls, and he pulled on the parking brake lever while in granny gear, with only slight throttle and that truck eases out of the pit. I did have an open diff then. Yeah, the same trick would take some double-clutching on a '71.
But it works.
Old 05-06-2012, 09:48 AM   #5
68gmsee
Active Member
68gmsee's Avatar
By slowly setting the rear parking brakes as you slowly step on the throttle prevents the spinning tire from turning so the rotation is transferred to the non spinning tire. At least that's the theory and sometimes it works if only one tire is in the mud or snow.
68gmsee is offline   Reply With Quote
Old 05-06-2012, 01:45 PM   #6
Psycho71
Psycho71's Avatar
It'll work on a slick boat ramp too. Used to use my old '98 to tow the boat. Had a buddy trying to pull the boat out one day, and all he could do was spin the one tire. And no matter how fast he spun that tire we didn't go anywhere. He started telling me I needed better tires. "Watch this", I said. I hopped out of the boat, and in the truck, and like a hundred times before I rode the brake and eased into the throttle. I made it out without spinning a bit, and then told him,"it's not all about brute force, finesse works sometimes". He then demonstrated with a hand gesture that I was number one.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 05-06-2012, 05:43 PM   #7
68gmsee
Active Member
68gmsee's Avatar
Originally Posted by Psycho71 View Post
.....I made it out without spinning a bit, and then told him,"it's not all about brute force, finesse works sometimes". He then demonstrated with a hand gesture that I was number one.
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
