Old 05-09-2012, 01:03 PM   #1
antman919
antman919's Avatar
Shorten Stock Steering Column?
is it possible to shorten the stock steering column? i would like to back the steering wheel away from me a good 6 inches or so. i have a 67 chevy pickup. i took the plastic pins out of the intermediate shaft and took the two pieces apart. could i cut say 6 inches out, put back together, and put a bolt thru both to hold in place? or am i crazy?
antman919 is offline   Reply With Quote
Old 05-09-2012, 03:00 PM   #2
red69ss
Burnouts are therapeutic
red69ss's Avatar
Re: Shorten Stock Steering Column?
I shortened mine about three inches by just removing the plastic rivets and collapsing it. DON'T put a bolt in it , it was made to collapse in case of a wreck so the column hopefully wouldn't impel you. you can only shorten it so much before it hits the dash on the inside, assuming your using column shift.
Theres a thread in the faq section on how to shorten it.
1969 CHEVELLE SS
1972 C10 ALMOST DAILY DRIVER
1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE)
1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR)
"My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield
"The difference between genius and stupidity is that genius has its limits." - Einstein
red69ss is offline   Reply With Quote
Old 05-09-2012, 04:06 PM   #3
antman919
antman919's Avatar
Thanks Red
Old 05-09-2012, 06:14 PM   #4
antman919
antman919's Avatar
note to self, check faq's BEFORE posting a faq
Bring Da Ruckus
Old 05-10-2012, 11:17 AM   #5
northerngmc
northerngmc's Avatar
I have read that it also moves the steering wheel down lower. Anyone have experience with this issue?
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 05-10-2012, 04:17 PM   #6
red69ss
red69ss's Avatar
yes it does , I lowered my seat to make it more comfortable.
1969 CHEVELLE SS
Old 05-10-2012, 09:31 PM   #7
black_sheep454
Got any pics of it with the shortened column and lowered seat. I'm 6'6" tall and need all the room I can get
1968 chevy lwb, getting ready to join forces with the 70 gmc
1970 gmc swb, getting ready to be a 68 chevy swb
1971 gmc lwb 2500 2wd Sierra Grande
1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins
black_sheep454 is offline   Reply With Quote
Old 05-11-2012, 08:19 AM   #8
red69ss
red69ss's Avatar
I can take some better pics this weekend. This is a before and after of the column. The after is not the best angle but you can tell how close to the dash it is.
If your running a small diameter steering wheel or if your not a great BIG ugly guy like me you may be okay without lowering the seat, it was really tight for me getting in and out. I only took about two inches out of the front of the seat bracket and three out of the back.
Lowering the seat also puts your knees in more of a bind which makes the ride less comfortable, which would deffinently be a consideration at 6'6'' tall..... I'm only 6'1''
1969 CHEVELLE SS
Old 03-26-2014, 07:37 PM   #9
sambudo
sambudo's Avatar
What did you end up doing to get more room? I'm 6'5" and could use the extra space as well. Thanks
1968 C10, 250, L6 4spd OTF, Fleetside
Upgrades: Power Steering
.......................____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
sambudo is offline   Reply With Quote
Old 03-26-2014, 08:05 PM   #10
veedubshafer
Mine...sucked the column down as far as she'd go!
veedubshafer is offline   Reply With Quote
Old 03-26-2014, 11:45 PM   #11
cool68
so, can a tilt column be shortened?
cool68 is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
