Old 06-05-2012, 04:18 PM   #1
mfencl
Exclamation 1987 350 conversion from throttle body to carb
I got a 1987 chevy v20 with a 350. the throtle body isn't working I'm not sure why it ain't. my friends dad is gunna give me a carburator and a intake manifold, what else would I need to covert it over I'm guessin the fuel pump but what else?
mfencl is offline   Reply With Quote
Old 06-05-2012, 05:01 PM   #2
rollinhard
rollinhard's Avatar
Re: 1987 350 conversion from throttle body to carb
The intake won't just bolt on either. The center two bolts on the heads are on a different angle. You can get it to work with some customizing. You can also use the in tank pump with a regulator, again with some jimmy rigging.
If you can't impress them with your inteligence, dazzle'm with your stupidity
1969 GMC lwb 2wheel drive can you say big stroker motor to come hehe
rollinhard is offline   Reply With Quote
Old 06-05-2012, 06:58 PM   #3
76stepsidechevy
Gonna need a distributor too.
76stepsidechevy is offline   Reply With Quote
Old 06-06-2012, 01:52 AM   #4
Desert1957
Desert1957's Avatar
If its the "Original" engine the engine block does NOT have a provision for a mechanical fuel pump. It might look like it does , but the Block is not drilled.
Desert
Desert1957 is offline   Reply With Quote
Old 06-06-2012, 11:29 AM   #5
esbstuff
Why? You are going to spend more money making that carb work than you would have just buying what you need to fix the truck correctly.
And you will need to change tank sending unit(s)...
esbstuff is offline   Reply With Quote
Old 06-06-2012, 02:34 PM   #6
sethv
sethv's Avatar
Fuel pump regulator, carb'd intake for TBI heads, and a distributor. That's all you need. You can keep your old sending unit/fuel pump. TBI is junk anyways so putting a carb on it is better than trying to figure out whats wrong with it.
1981 K10 Scottsdale
305 ci | TH350 | NP208 |
60k miles
sethv is offline   Reply With Quote
Old 06-06-2012, 02:45 PM   #7
76stepsidechevy
Call me crazy but i think id at least try to figure out whats up with the tbi first. Its probably a lot less work to fix the tbi.
Old 06-06-2012, 07:42 PM   #8
GM-power
GM-power's Avatar
I would see what's wrong with your tbi first. I mat be wrong, but I don't think you will gain much in this swap. I love carb engines btw!
GM-power is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
