Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 06-18-2012, 08:53 PM   #1
Slinger60
Slinger60's Avatar
1970 K5 Project
Ok here goes another build for me. First was my 71 K10 burb not finished yet but all it needs is body work and paint everything else is done. Bought this blazer a few months back. With the plans of doing a frame off. In the mean time I bought a 1970 c/20 pickup with a sweet front clip for a swap.The front diff. needed to be replaced, as it happens I have a dana 44 front diff. off a 1977 k/10 laying around. The disk brake upgrade will be nice.And I also had a rebuilt turbo 350 in the garage. The wiring is in very bad shape splices everywhere and all kinds of micky mouse stuff going on.So I bought a new wiring harness from painless. Plan on repainting her the stock medium blue.
Also bought a new 350 4 bolt from gm to drop in it also. My plan is to finish this project in 2 months (Hopefully) So today I started tearing her apart. but before I started doing that I had to debug her. Killed 4 black widows and found a few wasp nests in the process today. Here are a few pics of her when I brought her home and a few more from today during the tear down process.
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=529970
Shawn
Slinger60 is offline   Reply With Quote
Old 06-18-2012, 08:58 PM   #2
Slinger60
Slinger60's Avatar
Re: 1970 K5 Project
A few more pics. And as you can see I had a little help from mans best freind.
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
Shawn
Old 06-18-2012, 09:01 PM   #3
Slinger60
Slinger60's Avatar
Re: 1970 K5 Project
And a few more pics. And a couple of my friendly flying buddies home.
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
Shawn
Old 06-18-2012, 10:14 PM   #4
VA72C10
VA72C10
VA72C10's Avatar
Re: 1970 K5 Project
looking forward to the build!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 06-24-2012, 09:11 PM   #5
Slinger60
Slinger60's Avatar
Re: 1970 K5 Project
Update of progress after working on it for 2 days this weekend. Stripped the interior out and pulled all the wiring too. Floor seemed pretty solid nothing real bad that jumped out.Sunday I started cutting the rockers off and found a bit of rust nothing really bad but a little worse than I thought it was gonna be. But its always wishfull thinking that there isnt gonna be any rust under rockers when theres rust holes in them to start with. Little bit of a set back on my time frame to finish this project but nothing serious. I am going to cut the floor pan to replace the floor support, not sure if thats the right way but I dont want to mess with the rocker boxes.It seems a little easier to tackle it that way to me.I took out all the body mounts so the body is ready to pull off once I finish the repairs on the floor and both a and b pillers. Also looking for a set of Black belts to replace mine and both the K/5 fender emblems and a set of outer bumper brackets too.
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
Shawn
Old 06-24-2012, 09:20 PM   #6
Slinger60
Slinger60's Avatar
Re: 1970 K5 Project
It never ceases to amaze me how much dirt and rust get piled up inside the rockers. A few more pics of this weekends progress. Hope to have all cab repairs finished by next weekend.
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
Shawn
Old 10-07-2012, 10:28 AM   #7
Slinger60
Slinger60's Avatar
Re: 1970 K5 Project
Ok its been 3 months since my last post. I have been working on the blazer, I have just been to lazy to update my thread. Anyways after cutting all the rust out and replace both a and b pillers and part of the cab floor that I cut to get to everything. Here some pics of how it turned out. I am by no means an expert sheet metal guy but I think it will hold up.
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
Shawn
Old 10-07-2012, 10:34 AM   #8
Slinger60
Slinger60's Avatar
Re: 1970 K5 Project
It took me at least 50 or 60 hrs to cut and fit all the sheet metal in and get it all welded up. I put por15 inside the rocker boxes. And rust protected all the parts before they went in. I was honestly surprised at how long it took me to get this part of the project done. Here are some more pics.
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
Shawn
Old 10-07-2012, 10:46 AM   #9
Slinger60
Slinger60's Avatar
Re: 1970 K5 Project
After all the sheet metal work was done it was time to pull the body off. It took 5 guys to lift it off the chassis and set it on some saw horses that I made.
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
Shawn
Old 10-07-2012, 10:48 AM   #10
Slinger60
Slinger60's Avatar
Re: 1970 K5 Project
A couple more pics of the body and chassis
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
Shawn
Old 10-07-2012, 11:00 AM   #11
Slinger60
Slinger60's Avatar
Re: 1970 K5 Project
Once the body was off then it was time to start tearing down the chassis. And get ready to blast the frame and get it painted.
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
Shawn
Old 10-07-2012, 11:07 AM   #12
Slinger60
Slinger60's Avatar
Re: 1970 K5 Project
Once I had the frame stripped I swapped the front diff with a later model 1977 dana 44 with disc. brakes. Then it was time to power wash and blast the frame. I got lucky with the spring bushings the P.O. had already changed them out a couple years ago. So to save time I left the front and rear diff. on.
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
Shawn
Old 10-08-2012, 10:45 PM   #13
Slinger60
Slinger60's Avatar
Re: 1970 K5 Project
Next I power washed and took a putty knife to the frame to get most the the grime and grease off the frame before blasting
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
Shawn
Old 10-08-2012, 10:55 PM   #14
Slinger60
Slinger60's Avatar
Re: 1970 K5 Project
I used 700 lbs. of play sand to blast the frame it was cheap enough that I didnt reclaim any of it. I started with some safety googles but quickly learned that it wasnt going to work with them. So I took my welding helmet and took the lens out and used that, way better. Darn sand hurts when it hits your face.
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
Shawn
Old 10-08-2012, 11:11 PM   #15
Slinger60
Slinger60's Avatar
Re: 1970 K5 Project
Once the frame was blasted I gave her a good coat of primer the paint.Then on went my tires and rims and shocks. Then I put the fuel line back in and the brake lines. Bought the front steel brake line kit from Classic Industries to except the swap from drum to disk on the front. Had to drill new holes for the front brake lines.
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
Shawn
Old 10-08-2012, 11:31 PM   #16
Slinger60
Slinger60's Avatar
Re: 1970 K5 Project
Then it was back to the body since I was waiting for a buddy of mine to rebuild my transfer case. Had lots of holes to fill. Both rear quarters had these big holes from a P.O. that had put on whip antennas. Got one of before and one after. I wasnt to good at taking a lot of pictures.I would get on a roll and forget to take any pictures untill the end of the day.
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
Shawn
Old 10-08-2012, 11:51 PM   #17
Slinger60
Slinger60's Avatar
Re: 1970 K5 Project
After fixing the rear quarters and filling the trim holes on the body I had to take care of the windsheild frame. There was only one nut left on either side to hold the trim on so I had to cut out both sides and weld in new sections that I fabricated with new nuts welded on the back side.And of course I didnt take any pics of before so here are a couple after. I found one before I fixed the bad area I cropped it to fit so you can see a little bit of the area before I fixed it.
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
Shawn
Old 10-09-2012, 12:05 AM   #18
Slinger60
Slinger60's Avatar
Re: 1970 K5 Project
After I fixed a few hundred holes in the dash and all over the body it was time for a bit of primer. I didnt fix every little dent and ding in her I just tackled the major ones. I am going to use this blazer for camping, hunting and some four wheeling so I wasnt to concerned with making it totaly perfect.
Because if I did I wouldnt want to take it off road and scratch up all my work.
My main concern was making her weather tight and stopping as much rust as possible.
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
Shawn
Old 10-09-2012, 10:51 PM   #19
Slinger60
Slinger60's Avatar
Re: 1970 K5 Project
Here are a few pics of the body after I painted the inside of the tub.
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
Shawn
Old 10-09-2012, 11:02 PM   #20
Slinger60
Slinger60's Avatar
Re: 1970 K5 Project
I got my transfer case back so it was time to get back to the chassis.Time to put the new motor in. I modified the the original exhaust to work with my headers saved a little money on putting putting all new in.
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
Shawn
Old 10-09-2012, 11:10 PM   #21
Slinger60
Slinger60's Avatar
Re: 1970 K5 Project
Wet sanded body down one more time before I painted the outside. Here are a few pics of how the outside of the body turned out. I dont think it turned out to bad for painting in my driveway.
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
Shawn
Old 10-09-2012, 11:18 PM   #22
Slinger60
Slinger60's Avatar
Re: 1970 K5 Project
A few pics of the night before I put the body back on. I need to repaire the nose on the frame. Looks like somebody at one time pulled the bumper off jerking on something. But I have a doner truck for that.
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
Shawn
Old 10-09-2012, 11:29 PM   #23
Slinger60
Slinger60's Avatar
Re: 1970 K5 Project
Its been a long haul to get this project to this point I started on June 10 or so.
And the end is in sight now. My goal is to get it in driving condition by mid Nov. (hopefully) Here are a few pics of the body on with all the new mounts in. I am gonna try and update this a little more often now.
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
Shawn
Old 10-09-2012, 11:29 PM   #24
boonedogs72
boonedogs72's Avatar
Re: 1970 K5 Project
looks real good!
boonedogs72 is offline   Reply With Quote
Old 10-09-2012, 11:36 PM   #25
Slinger60
Slinger60's Avatar
Re: 1970 K5 Project
Hey your from the same area. And thanks.
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
Shawn
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
