Old 06-30-2012, 08:21 PM   #1
jsbgump
Gone Fishing
jsbgump's Avatar
Trans dipstick ?
How are yall bolting the trans dipstick? My block has the hole blanked
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 06-30-2012, 10:06 PM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Trans dipstick ?
maybe that's whats wrong with mine...didn't seem to line up. Figured I'd just need to do some bending... or something creative.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 07-01-2012, 07:31 PM   #3
Dustytrix
I was able to bend the tab so that it would bolt onto the back of the head.
Dustytrix is offline   Reply With Quote
Old 07-01-2012, 08:05 PM   #4
clinebarger
You need a LS style 4L80E dipstick tube, & you need the factory style "double studded" bellhousing bolt & the 8x1.25mm nut.
clinebarger is offline   Reply With Quote
Old 07-02-2012, 09:20 PM   #5
68GMCCustom
Thanks clinebarger...this one's a Hughes steel tube dipstick. Definition shows - "Transmission Dipstick, Locking, Bellhousing Mount, Chevy, 4L80E"
Now that I know where it probably "should mount"...maybe I can inflict a bend or two in just the right spot to line up its single mount point. I'll need that stud and nut for it tho.
Kurt -
Old 07-02-2012, 11:00 PM   #6
clinebarger
But it's not for a LS. GM is the only vendor that I know of with the correct stick & tube. 04 2500HD 6.0L would be the application.
Bending the Hughes mount again wont help...It's made to bolt to the missing bellhousing bolt.
Old 07-02-2012, 11:24 PM   #7
68GMCCustom
oh wow...OK I'll look for an OEM setup. And I thought I was getting the right thing...dang.
so this one wouldn't be accurate either?
Kurt -
Old 02-07-2013, 04:42 PM   #8
suttoncurt
suttoncurt's Avatar
So any more info on this subject ? I'm swapping a lq9 /4l80e into my 69 c-10 and didn't get a dipstick tube with my tranny . Thanks in advance !!
suttoncurt is offline   Reply With Quote
Old 02-07-2013, 07:13 PM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Cline is right...GM is the only one who does this right for the 4l80e. Most places will try to sell you the 4l60e stick, or a universal one. Almost no universal will work because 98% if them do not have the locking top, with exeptions like the REALLY expensive stainless ones from Lokar.
I ended up getting the dipstick tube from my gm dealer, although at the time he couldnt' find a dipstick in stock. I ended up modifying one from a 4l60, cut and welded to the right level. I will replace it this summer though, its a little ghetto. My dealer doesn't stock much, but he will usually give out the part #'s (he doesn't care much about customer retention lol) and I'll buy the stuff from gmpartsdirect or similar.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-07-2013, 07:23 PM   #10
suttoncurt
suttoncurt's Avatar
great info !! Thanks for letting me know . I will look for the proper part number and make the order
Old 02-08-2013, 04:06 AM   #11
mcmlxix
Collector of Projects
mcmlxix's Avatar
I bought a Lokar 4L80e dipstick in black.... Ended up buying a stock GM part. My truck isn't Lokar quality and with the factory heater box, I couldn't find a place I liked to mount the Lokar one... Stock part should work fine for me...
$24.24 15832205 Tube - dip stick tube
$31.28 15183801 Indicator - dip stick : New PN 15791230
$1.98 1259475 - Dipstick tube seal 4L80e
$2.63 15724226 - Stud
prices are from www.gmpartsdirect.com
Rich
1972 K5 Blazer CST Click HERE
Old 02-08-2013, 12:30 PM   #12
suttoncurt
suttoncurt's Avatar
[QUOTE=mcmlxix;5875328]I bought a Lokar 4L80e dipstick in black.... Ended up buying a stock GM part. My truck isn't Lokar quality and with the factory heater box, I couldn't find a place I liked to mount the Lokar one... Stock part should work fine for me...
prices are from [url]www.gmpartsdirect.com
Yea - I went there yesterday and typed in that part number for the dip stick and it said indicator . I was thinking , indicator ??? Looks like i'm the dipstick now
