Old 07-16-2012, 08:58 PM   #1
mfencl
87 350 tbi timing
I got my truck to finally run after like 3 month truck won't idle two things I could think of time which I do not have access to a timing gun or my butterflies aren't opening enough to let it idle but friend did say that the butterflie were completly closed when I let off the throttle the butterflies r completly closed anyone know how to adjust that?
mfencl is offline   Reply With Quote
Old 07-17-2012, 12:56 AM   #2
wyattglock
wyattglock's Avatar
Re: 87 350 tbi timing
That is controlled by the idle air control valve. If it is stuck closed the truck won't crack the blades open far enough to get air flow and idle properly. I ran into the same thing on my tbi 454.
wyattglock is offline   Reply With Quote
Old 07-17-2012, 01:20 AM   #3
Desert1957
Desert1957's Avatar
you CANNOT time a "TBI" engine without a timing light, Beg, Borrow, or Steal one . Disconnect the little brown wire, and set it the right way. trust me I have seen it tried and some of the attempts were 40-50 off.
Desert
Desert1957 is offline   Reply With Quote
Old 07-17-2012, 11:04 AM   #4
rfmaster
rfmaster's Avatar
You must have timing light - sorry no if's, but's or whatever's - got to have this piece of TE to work on EFI equipped cars / trucks!
Unlike classic, non-ECM carburetor equipped engines the ECM in TBI system controls timing advance (and other things as well). For ECM to carry out its duties, the base timing should be set to 0deg, with EST connector open. When you open EST connector (single brown-white wire just under brake booster) the SES will lite (this normal) and idle will drop down to 600 RPM. Once set reconnect and shut engine down. Clear SES code by disconnecting battery for 30 seconds (engine off!!!!). After engine restart check timing at idle - it will be bouncing between 16 and 20 deg - this normal as ECM continuously varies SA timing. You are done with timing.
It is normal (in TBI ) for throttle blades to be closed at idle. The IAC controls amount of idle air getting into engine during idle. IAC should be reset - use search function I have posted this procedure on several occasions.
All of the above assumes that you've mechanically sound engine, there are no vacuum or exhaust leaks, ignition system is in working order and there are no fuel pressure issues.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
