Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 07-19-2012, 02:34 PM   #1
Budman56
Budman56's Avatar
Starter problems
I HAVE A 65 & 66 C10 & C20 WITH SMALL BLOCK CHEVY MOTORS, I HAVE STARTER ISSUES WITH THEM AFTER THEY HAVE BEEN RUNNING FOR AWHILE. THEY WONT START, BUT IF YOU LET THEM SIT AWHILE THEY WILL START BACK UP. I HAVE BEEN TOLD THAT THEY ARE BEING HEAT SOAKED BY THE HEADERS. DOES ANYONE KNOW HOW TO FIX THIS? WITHOUT ME REMOVING THE SHORTY HEADER THAT I HAVE ON THE MOTORS?
MY 65 C20 BUILD
http://67-72chevytrucks.com/vboard/s...d.php?t=483346
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
Budman56 is offline   Reply With Quote
Old 07-19-2012, 03:42 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Starter problems
check this out.
..........http://67-72chevytrucks.com/vboard/s...d.php?t=363603
You could install a mini starter but you would have to take the present starter off and that probably means the shorty header
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 07-19-2012, 04:15 PM   #3
Wrenchbender Ret
The relay is a good help for this & also a shield is available for it.
Wrenchbender Ret is offline   Reply With Quote
Old 07-19-2012, 04:28 PM   #4
fixit-p
fixit-p's Avatar
When it doesn't start do you get a click or nothing at all?
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 07-19-2012, 10:19 PM   #5
Budman56
Budman56's Avatar
Originally Posted by VetteVet View Post
check this out.
the 65 has a mini starter the 66 has a normal starter.
MY 65 C20 BUILD
Old 07-19-2012, 10:22 PM   #6
Budman56
Budman56's Avatar
Both starters are new, what relay? Brand? And how do I wire it in? Also where can l get a heat shield for it?
MY 65 C20 BUILD
Old 07-19-2012, 10:23 PM   #7
Budman56
Budman56's Avatar
nothing at all!
MY 65 C20 BUILD
Old 07-19-2012, 11:24 PM   #8
FLEET72
FLEET72's Avatar
Here is an article explaining the kit sold by MAD Electrical, "START'M UP kit".
Heat shields here and here
Oscar
'72 Shortbed Fleetside
'95 Jimmy 4X4
'69 GMC Custom Camper
FLEET72 is offline   Reply With Quote
Old 07-19-2012, 11:53 PM   #9
VetteVet
Msgt USAF Ret
VetteVet's Avatar
All that is covered in the thread I linked and it is the Mad Kit.
If you can jump directly from the large cable on the solenoid to the "S" terminal on the solenoid with a screw driver or wire jumper and the starter still does not turn then the remote solenoid will not help. Make sure the truck is out of gear and the ignition is off. I'm surprised that the mini starter will not turn when the engine is warm. It must be a cheaper model.
VetteVet
Old 07-23-2012, 01:43 AM   #10
Budman56
Budman56's Avatar
Thank you all this fix worked great! Now on to the next problem.
MY 65 C20 BUILD
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
