Old 08-06-2012, 09:50 AM   #1
jbgroby
jbgroby's Avatar
need advice on door adjustment
I did a search on this topics and did not quite find what I needed. So I'll start a new one
I've hung the doors and need to get them set correctly so I can get the fenders on and shimmed up so I don't pop paint.
Any ideas you have for mounting and adjusting will be appr. I was reading one post where a member used "paint sticks taped to the various areas around the door" as a temporary shims/filler support for the doors? This sounds good but I can't find the post now - go figure)
Afain any thought and idea you have are appri.
Jake
jbgroby is offline   Reply With Quote
Old 08-06-2012, 12:37 PM   #2
62 Barnfind
62 Barnfind's Avatar
Re: need advice on door adjustment
I looked for a tread also but couldn't find it. I used paint sticks and eye balling to get it close. It took a while to get it aligned and straight. The factory didn't do a good job in the alignment and spacing. Here is some pics of my doors.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 08-06-2012, 12:43 PM   #3
Rich 5150 69
Rich 5150 69's Avatar
Jake you got it right, paint sticks sets it real close to factory specs, use lots of masking tape to protect the edges...lots of patience...good luck
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 08-06-2012, 12:53 PM   #4
jbgroby
jbgroby's Avatar
Thanks,
would it be normal to use a shims to "lift" out the fender so I have some breathing room. Is there a set "thickness" for the size of the shims, I have a Paint and Body store in town where I can get some shipm a handful would be plenty, but hate to buy the wrong size.
Any thoughts on this aspect/
Old 08-06-2012, 12:56 PM   #5
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Here drive yourself crazy.
Old 08-06-2012, 01:17 PM   #6
Rich 5150 69
Start your shimming and alignment at the door, then to fenders, then hood, some have even used a string with strong magnets to run a line from back of cab to fender tip for alignment.
Old 08-06-2012, 01:23 PM   #7
1963c-10
1963c-10's Avatar
62 Barnfind....that looks real good in my opinion
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 08-06-2012, 09:40 PM   #8
62 Barnfind
Thanks! It took along time to get it to that point. I just removed the doors again to prime the inner doors and jams. I hope that thy line up again. This time it is just in and out adjustment. Thanks again for the complement.
John Z
62 Barnfind
Old 08-06-2012, 11:07 PM   #9
theastronaut
theastronaut's Avatar
Once you get them in their final position, drill through the hinge and body with a 1/8" bit. Drill each half of the hinge in two different spots. Whenever you have to take the door off, all you'll have line up are the holes- no guessing or readjusting to get the doors back in adjustment.
theastronaut is offline   Reply With Quote
Old 08-07-2012, 07:08 AM   #10
dthela
dthela's Avatar
be careful where the front fender meets the door! they should NOT line up! the door i believe should be slightly in further or they hit! dimensions in the assembly manual. if you need i can email you if you email me!
dthela is offline   Reply With Quote
Old 08-07-2012, 07:09 AM   #11
dthela
dthela's Avatar
just saw the post above, never mind lolol.
Old 08-07-2012, 07:27 AM   #12
C-10cutty
C-10cutty's Avatar
What he said.
C-10cutty is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
