Old 08-12-2012, 09:19 PM   #1
c10 custom
lowering a 1968 chev truck
hi guys i am getting a 1968 chev shortbox truck and i want to lower it as much as i can without airbags what is the best way to do the job any advice would be greatly appreciated and any pictures of trucks from 67-72 lowered would be great thank you
c10 custom is offline   Reply With Quote
Old 08-12-2012, 09:47 PM   #2
HotRod C/10
HotRod C/10's Avatar
Re: lowering a 1968 chev truck
do a search on static drops........tons of pics
-77 CHEYENNE SWB
5/7 BellTech drop
20x10 & 20x8.5 Eagle 225's
LS SWAPPED
HotRod C/10 is offline   Reply With Quote
Old 08-12-2012, 09:51 PM   #3
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Drop springs from ECE in the rear, can do front drop springs also...
Smitty
71 C10 283/3SPD (I know its not original but I like the motor) 4 Whl Disks,Dakota Dash,Moved Fuel Tank,Frame Off
71 GMC 1500 Sierra Grande 350/700R4 3.42 rear, Tilt, Power windows, Custom Seats, Torque Thrust II's, Serpentine Set-up w/AC. Reframed Coils and Trailing Arms, 4 inch ECE drop. 4 Wheel Disks. Repainted with my own hands and it looks Freaking Sweet....
70 Suburban Former military GSA truck,,still solid as a rock! Its starting,,,350/700R4 3.42 rear, Dodge seats.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber...Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one.....
71meangreenc10 is offline   Reply With Quote
Old 08-12-2012, 10:01 PM   #4
jmking9
jmking9's Avatar
My 70 swb is lowered 4.5-6. I have seen trucks with 5-7 static drops. I wouldn't want to be any lower than I am if you plan on driving the truck alot.
As far as the parts, I used Early Classic Enterprises (ECE as it reffered to here) and would highly recomend them to anyone. Quality, service, and knowledge well above the competitors. Classic performance Parts (CPP) is another place you could look at. I have had good luck with them, although there are others that haven't. There are several others that sell lowering kits. These are just the two that I have bought parts from. Search around the site you you will find tons of info and pics that include suspension and wheel/tire specs.
1970 SWB Build
jmking9 is offline   Reply With Quote
Old 08-12-2012, 11:28 PM   #5
GMC Canuck
Take a read through the suspension forum. Lots of good info (and pics) there. The 'make it handle' thread is really good (long but good). Most of the vendors cruise that forum and the good ones are willing to guide you in right direction. Do some reading, know what you want to achieve. Make a long term plan (and budget). Once you figure out how to make these trucks go around corners it can be additive. And not all the mods are high dollar parts.
Drop spindles on the front are a little more money but keep your suspension travel and geometry unchanged. I wouldn't go more than 2 1/2 with 15” tires.I went 3” and wound up with clearance issues on the lower control arms. 2” block on rears the most you can do after that you can get any number of drop springs. You'll be limited on how far you can go on whether you want a c notch. You've got about 6“ before you're on the bump stops.
GMC Canuck is offline   Reply With Quote
Old 08-12-2012, 11:42 PM   #6
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Here is mine... ECE 4.5/6 drop love their parts. If you can get board member lolife99 to weight I think you will be money ahead as he has a ton of wisdom with drops and brakes etc.
Buck
Instagram: C10_ustacould
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 08-13-2012, 07:54 AM   #7
AusTx68
AusTx68's Avatar
I'm also running the ECE 4.5/6 drop kit on my 68'. It sits on 20" wheels with no issues at all.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 08-13-2012, 12:21 PM   #8
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
Take out the springs.
ProStreet68SB is offline   Reply With Quote
Old 08-13-2012, 02:21 PM   #9
C10_ustacould
Buck
Ellie SOLD
Shiro SOLD
Old 08-13-2012, 02:30 PM   #10
1969Chev
1969Chev's Avatar
I lowered my truck by heating the springs and bouncing on it til it was at my desired height. I only lowered it a couple inches.
1969 CST/20 396/TH400 Tach Posi
1969Chev is offline   Reply With Quote
Old 08-13-2012, 02:39 PM   #11
CC69Rat
CC69Rat's Avatar
A lot of people use the ECE stuff, I have heard nothing but good things about them.
Chad
1968 C10 SWB - 50th Anniversary Tribute Project http://67-72chevytrucks.com/vboard/s...d.php?t=444414
2017 Jeep Wrangler Rubicon (daily)
2001 Jeep Cherokee XJ
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 08-13-2012, 06:13 PM   #12
ProStreet68SB
Originally Posted by BucksSS View Post
That would lower it as much as possible without bags.
Old 08-13-2012, 08:02 PM   #13
68streetrod
Here are a couple pics of my 68 that is close to done 6/5 drop
68streetrod is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
