Old 08-16-2012, 11:48 PM   #1
murd969
1956 Chevy 3100 Corvette Suspension
Here's what I started with.
murd969 is offline   Reply With Quote
Old 08-17-2012, 10:10 AM   #2
Larry Lindley
Re: 1956 Chevy 3100 Corvette Suspension
thats a good truck to start with,appears in very good shape not many are like this one,and welcome from TX.
Larry Lindley is offline   Reply With Quote
Old 08-17-2012, 11:41 AM   #3
Kim57
Kim57's Avatar
Welcome.
Looks like a decent start.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 08-17-2012, 02:04 PM   #4
Dan in Pasadena
Dan in Pasadena's Avatar
So other than the title of your thread, what's the plan?
Dan in Pasadena is offline   Reply With Quote
Old 08-27-2012, 02:30 PM   #5
murd969
The truck needed more work than it looked like. I have replaced the doors, hood, bed, core support and all kinds of other things.
Old 08-27-2012, 02:37 PM   #6
murd969
I will try and get some pics up of what has been done so far.
Old 08-27-2012, 02:56 PM   #7
murd969
Old 08-27-2012, 03:02 PM   #8
murd969
I ended up having a custom frame built. I used a corvette c4 front and rear suspension with a custom 4-link in the rear.
Old 08-27-2012, 03:05 PM   #9
murd969
I also had all motor mounts mocked up with my motor and Ididit steering column.
Old 08-27-2012, 03:07 PM   #10
murd969
For the motor I have a 400 SBC. This was completely gone through. All machine work..bored .60 with roller rockers. I plan on running a 700r4 transmission with it as well.
Old 08-27-2012, 03:09 PM   #11
murd969
The stance on the truck looks perfect. This picture is with no weight on it but with it all together it should sit just right.
Old 08-27-2012, 03:11 PM   #12
murd969
Here are some random pics of the suspension. Once everything is test fitted it will all be broken down and the suspension will be polished and the frame will be powder coated.
Old 08-27-2012, 03:17 PM   #13
murd969
Right now the cab is at the body shop. A lot of metal work is being done. Cab corners are being redone. Dash, cowl, dome light and firewall are being smoothed. Here is the current pic of the can before it went to the body shop.
Old 08-27-2012, 03:19 PM   #14
murd969
I have had to replace a ton of stuff: Doors, inner/outer cab corner, hood, inner fenders, core support, complete bed and a new frame. I also have the one piece window kit for the doors plus a ton of other parts that I will eventually need.
Old 08-27-2012, 04:05 PM   #15
Kim57
Kim57's Avatar
This is shaping up to be a real nice build. Keep the pics coming.
Kim
My build thread
Old 08-27-2012, 05:58 PM   #16
shadow1967
shadow1967's Avatar
Most 4 link for corvettes are @12-14". Yours appear tobe 35-40", looking at the pic. How come so long? Just looking for info, thinking of put one in my 38 sedan.
Build for my 1959 Fleetside...
http://67-72chevytrucks.com/vboard/s...d.php?t=518308
shadow1967 is offline   Reply With Quote
Old 08-27-2012, 10:35 PM   #17
murd969
My 4-link bars are 30 inches. We did it longer to help get a better ride and to limit the pinion angle when there's suspension travel. Also if I ever wanted to put air bags on it I wouldn't have to change up too much.
Old 08-29-2012, 03:15 PM   #18
duwem
duwem's Avatar
What size frame rails did you use to make the frame (width, height, thickness)
1950 Chevy 3100-Transforming into a hot rod.
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=435302
duwem is offline   Reply With Quote
Old 08-29-2012, 03:47 PM   #19
murd969
The truck was originally swapped on a full size frame. They did a horrible job so I picked up an original frame. That frame turned out to be slightly bent in the rear. Plus the original frames had all of the holes in it. I finally had enough and had a new one built. We used 2" x 4" square steel tubing and it's 3/16" thick.
Old 08-29-2012, 10:10 PM   #20
shadow1967
shadow1967's Avatar
Thanks for the info!
Old 08-30-2012, 12:32 PM   #21
_Ogre
_Ogre's Avatar
good looking truck to start with.
nice work on your frame
shop air compressor timer
Old 11-30-2012, 02:40 PM   #22
murd969
Here are some more random pics from the body shop. The cab has been there for a while. I'm having all kinds of work done.
Old 11-30-2012, 02:41 PM   #23
murd969
And some more
Old 11-30-2012, 03:28 PM   #24
murd969
Some newer pictures from the body shop. Smoothed firewall and fitting the driver door with the new step.
1956 Chevy 3100 C4 Suspension Build
Instagram: murd969
Old 11-30-2012, 03:46 PM   #25
Kabwe
Certified Car Nut
Kabwe's Avatar
Really nice looking project.
Kabwe is offline   Reply With Quote
Thread Tools
Display Modes
