Old 09-12-2012, 09:33 PM   #1
bgray
Turbo 350 to 700r4 Swap
Hi all
Wondering if anyone can help me with some info or links in regards to switching to a 700r4 in my 1981 c10 rcsb 2wd.
Thanks for any help or info
bgray is offline   Reply With Quote
Old 09-12-2012, 10:09 PM   #2
kwin
kwin's Avatar
Re: Turbo 350 to 700r4 Swap
700 should be about 3 inches longer than the 350 which will require a shorter driveshaft, if yours is not bent it can be shortened by a driveline shop. If memory serves the cross member is a little further rearward on a 700r4 vehicle , I think you can re-position or re-drill. You would need a new indicator for the shifter, if its a column shift.
Let see what else......
kwin is offline   Reply With Quote
Old 09-12-2012, 10:12 PM   #3
kwin
kwin's Avatar
if your looking at making power , even down the road. Consider a turbo 200r4. They can be built to hold more power than a 700. They held up well with the highly built gnx's of the day. They would be a good choice.
Old 09-13-2012, 07:09 AM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
I went from a 350C tranny in my truck to a 700 R4 and I had to move the rear tranny mount about 1.5" and do some redrilling in the frame. The driveline was shortened to fit the new length and the shift indicator was changed out for the OD setup without much effort. I finally went to a B&M truck Megashifter to get the positive shift control that I wnated and I am not sorry that I did that. My 700 R is built up from the factory specs with the heavy duty clutches, and rotating parts. Over the years I have had to replace the oil pump in the tranny a couple times, since I was abusing it a tad to much.
The tranny is connected to a 383 stroker engine and feeds to 3.73 gears.
Frank
piecesparts is offline   Reply With Quote
Old 09-13-2012, 08:52 AM   #5
foamypirate
foamypirate's Avatar
Are you guys above sure you had the original TH350? Squares should have had a 9" tail shaft instead of the 6" version. I swapped my 700R4 in place of a TH350C and was able to re-use the same drive shaft. The 9" tailshaft TH350 is within 1/16" of a 700R4 in length.
foamypirate is offline   Reply With Quote
Old 09-13-2012, 10:33 AM   #6
SunSoaked
Not meaning to hi jack but I'm putting a 700r4 in my 69K10 mated to a divorced T case. I'm wondering if theres a way to shorten the 700 by using a shorter shaft or if a 350 shaft will work in the 700?
"I once saw a six foot chicken eating prairie dogs like they were worms, but this was while driving between Janos, Chihuahua, Mexico and Agua Prieta, Sonora, Mexico on Route 9, after having consumed my share of El Presidente whiskey "
SunSoaked is offline   Reply With Quote
Old 09-13-2012, 11:17 AM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
sizes
John http://www.youtube.com/user/TheMotornut
1978 Suburban4X2-hit while parked RIPzez
1978 GMCJimmy4X4-350/203http://67-72chevytrucks.com/vboard/s...=421767&page=4
1979 GMCJimmy4X2-305/350http://67-72chevytrucks.com/vboard/s...=1#post5200107
1987 Suburban4X4-writeoff hit while parked RIPzez
1988 Suburban4X4-writeoff hit while parked RIPzez
1989 Suburban4X2 - square igloo/SOLD
2002 Fleetwood
2005 Malibu hit by City bus,2nd time a write-off(01/15/16)
2010 Dodge Van-writeoff hit while parked(01/14/15)
Now I just buy shorter trucks!
Love em low,but get me higher
motornut is offline   Reply With Quote
Old 09-13-2012, 11:20 AM   #8
bgray
Good to hear, I knew i would have to Move the cross-member back. Is the shifter linkage a direct hook up? How do I swap out the indicator(dont want to use floor shifter)?
Local guy cna shorten if nessesary. IS there a certain 700r I should look for out of a certain year car? Not concerned on power handling, just want the truck to have a OD
Old 09-13-2012, 01:40 PM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
indicator thats the ez part
it seperates from the cluster......like so
2002 Fleetwood
Old 09-13-2012, 01:43 PM   #10
foamypirate
You want to look for an 87' and up 700R4 (make sure it's a 700R4 and NOT a 4L60E though!). They have a lot of upgrades the pre-87's don't have.
Old 09-13-2012, 02:26 PM   #11
SunSoaked
motornut-thanks for posting those sizes.
It looks like the 700 uses the shortest (6in) tail housing and since I cant shorten the body, 30 inches is as short as it's gonna get.
Old 09-13-2012, 03:06 PM   #12
frog210
A local transmission guy told me that 700r4 should just bolt in ?
San Antonio, TEXAS
-Frog
-I'm a valet and well I've driven BMWs, Mercedes, Porsche,Bentlys, fiats, Hondas, etc and well even do I like a few features, I love my shortbed, it dosent bore me out, just press on the gas and you'll remember why you love it.
frog210 is offline   Reply With Quote
Old 09-13-2012, 05:45 PM   #13
piecesparts
I still had to shorten mine, but I lowered the truck at the same time as I put the 700 in the body.
Frank
Old 09-13-2012, 11:32 PM   #14
bilfman
bilfman's Avatar
I just did a 4l80e swap here is the build, might be something of interest.
http://67-72chevytrucks.com/vboard/s...d.php?t=537481
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 09-14-2012, 03:37 AM   #15
chebyshortbox65
chebyshortbox65's Avatar
Just did a long tail 350 to 700 drive line bolted right in two crossmember bolts line up had to drill 3 shift linkage all lines up lines will havr to be bent a little buy easy swap
chebyshortbox65 is offline   Reply With Quote
Old 09-14-2012, 09:38 AM   #16
LEEVON
LEEVON's Avatar
tip, get the GM dipstick and tube from the dealer if it doesn't come with the transmission.
'17 Sierra Regular Cab ~ '15 Challenger R/T Scat Pack 392 ~ '11 Escalade ESV ~ '71 Cheyenne swb ~ '66 Country Sedan ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
