Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 Chevy & GMC Pickups Message Board
Old 09-18-2012, 10:29 PM   #1
chevyrestoguy
chevyrestoguy's Avatar
Serpentine set-up/ smog pump question
I am putting an early '90s serpentine belt set-up on my '64, and I have a question for you guys who have that system on your trucks.
I am not going to be running a smog pump, but I have read that there are a couple of different ways to go for the belt.
1): Eliminate the pump and run a shorter (non-smog) belt
2): Buy a smog pump delete pulley and run the stock smog belt.
Any suggestions?
I have also read that if you delete the pump, you also have to remove the idler pulley that's just above and to the inside of the smog pump. You can see it in the picture below:
Last question....I would love to trim away the area of the bracket where the smog pump went. I realize that I would have to leave the two lower attach holes that go into the block, but I think I can trim away about 75% of the lower portion of that bracket. Has anybody done this?
Thanks, guys!
Check out my build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 09-19-2012, 06:20 AM   #2
speedygonzales
speedygonzales's Avatar
Re: Serpentine set-up/ smog pump question
http://www.summitracing.com/parts/NAL-12497697/
99 Z71 (98 body style)
Pride and joy
speedygonzales is offline   Reply With Quote
Old 09-19-2012, 08:48 AM   #3
Greenlee
All of the late 80's and early 90's trucks that I have seen had no smog pump and nothing in those in those lower holes from the factory. You shouldn't need a shorter belt or special idler. I'm running the stock serpentine setup from an 89' suburban. I bought the stock belt etc. There are pics of it in my build thread.
Greenlee is offline   Reply With Quote
Old 09-19-2012, 08:55 AM   #4
Greenlee
I looked back at mine and lower idler is there with no smog pump. There is a picture of it here.
http://67-72chevytrucks.com/vboard/s...92#post5561292
Old 09-19-2012, 08:34 PM   #5
chevyrestoguy
Excellent! That's EXACTLY the information I was hoping for. Now I know just how much of my bracket I can trim off to make it look a little more appealing.
Thank You very much for that info, Greenlee!
Old 09-20-2012, 11:26 PM   #6
67c10rustbuket
67c10rustbuket's Avatar
They also have a non smog bracket for the pass side of the engine that is much more pleasing on the eyes. I have one in my garage from a 91 and my old 93 had the same setup. I can take a pic this weekend if you want to see one. They might be hard to find out there in Cali smog land though.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
