Old 09-22-2012, 05:36 PM   #1
Trsmotrhed
Trsmotrhed's Avatar
63 SWB C10 LT1/4L60E Swap
I came across a great deal on an LT1 4L60E combo to install in my 63 swb truck. This is a budget build.
Finished my motor mounts for my LT1 swap into a 63 c10. Raised the motor 5/8" to help clear the AC instead of spending money on brackets. Worked great with all the room under the hood. I cut the stock mounts where they mount to engine and frame and filled in the gap with flat stock steel cut to fit.
Now to fit the headers and fuel lines. Waiting for my stand alone harness and ECM I got a killer deal on with VATS and smog deletes already done.
Trsmotrhed is offline   Reply With Quote
Old 09-22-2012, 05:47 PM   #2
jayman68
Fun Stuff
jayman68's Avatar
Re: 63 SWB C10 LT1/4L60E Swap
Good job, you got it going.
Looks like a nice fit with the engine. Good luck on the build.
Jay
68 C10(project)
88 Honda Accord(DD)
93 Chevy Astro EXT 2wd
jayman68 is offline   Reply With Quote
Old 09-22-2012, 05:58 PM   #3
Trsmotrhed
Trsmotrhed's Avatar
Bolted up the headers from the 350. There was not much gasket difference between the D shape LT1 port and the standard 350 port. From what I've read they will work. I need to weld in the O2 bungs in the collectors next. I'll take pics as I progress.
Old 09-22-2012, 06:49 PM   #4
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Welcome to the board good looking project.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 09-22-2012, 09:24 PM   #5
Bugeyev8
Bugeyev8's Avatar
by the looks of the engine w the green hoses it was a cop car engine?
Bugeyev8 is offline   Reply With Quote
Old 09-22-2012, 11:14 PM   #6
jayman68
Fun Stuff
jayman68's Avatar
So far we have seen pics of the engine and the engine. Do you have any of the rest of the truck? The exhaust ports are pretty much the same. Looking good so far.
Jay
68 C10(project)
88 Honda Accord(DD)
Old 09-23-2012, 12:08 AM   #7
Trsmotrhed
Trsmotrhed's Avatar
Yes, it's a cop car LT1.
Old 09-23-2012, 12:25 AM   #8
Trsmotrhed
Trsmotrhed's Avatar
I'm new here and haven't figured out how to add a pic to my signature. Until I do, here is a pic. So far lots of good info and cool guys on here. Sine this picture I have added PS, PB, disk brakes up front with 5 lug and also 5 lug on the rear from a 72 C10.
Old 09-23-2012, 02:10 AM   #9
jayman68
Fun Stuff
jayman68's Avatar
Cool! Looks pretty clean, just a spot of rust at the corner of the door.
Jay
68 C10(project)
88 Honda Accord(DD)
Old 09-23-2012, 08:32 AM   #10
CRGRS 66
CRGRS 66's Avatar
Nice truck! Welcome to the board!
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 09-23-2012, 05:43 PM   #11
Trsmotrhed
Trsmotrhed's Avatar
Thanks. Already getting some great on my build from guys that have been there done that.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
2005 Silverado Duramax - daily driver kinda
My project build thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Old 09-30-2012, 05:59 PM   #12
Trsmotrhed
Trsmotrhed's Avatar
63 SWB C10
Old 09-30-2012, 06:05 PM   #13
Trsmotrhed
Trsmotrhed's Avatar
Got my harness and ECM the other day. Have a few wires to remove to clean it up. Still has all the smog connections and I need to add fuel pump relay and fuse block. At least I'll know what the harness has for wires when done.
63 SWB C10
Old 09-30-2012, 07:25 PM   #14
Modges'66
Modges'66's Avatar
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Welcome aboard!
I have the same combo in my chassis with a few upgrades.
Gonna be watching close to see your obstacles, as I haven't yet got to the point of hooking anything up, or messing with it.
Modges'66 is offline   Reply With Quote
Old 09-30-2012, 08:28 PM   #15
Trsmotrhed
Trsmotrhed's Avatar
Originally Posted by Modges'66 View Post
Welcome aboard!
I'll be th Guinea pig. Lol. Do you have a build thread for your build? Would like to stay in touch as we both hit obstacles. After I get the harness straightened out, it's onto the fuel system. Think I'll get a suburban tank and weld in the top from a caprice or Z28 with a steel tank, another guy on thus site told me that's what he did. Option #2 is a fuel pump from Tanks Inc with a baffle and put in a Suburban tank.
Stay in touch.
Tim.
63 SWB C10
Old 09-30-2012, 10:27 PM   #16
Modges'66
Modges'66's Avatar
I'm not sure how to attach a link to my build thread, but it shouldn't be hard to find if you look for my dumb avitar or user name but I will try to attach it now.
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=512904
Old 09-30-2012, 10:29 PM   #17
Modges'66
Modges'66's Avatar
Ha!
It looks like I attached it manually & automatically at the same time!
I shouldn't be hard to find me now!
Old 09-30-2012, 10:45 PM   #18
Trsmotrhed
Trsmotrhed's Avatar
Ha!
You did great. I found your build and looks awesome. I had a 66 C10 years ago and was actually looking for another one when I found this 63 really cheap. My 66 had a 383 Stroker built. Was a blast to drive and race at drag strip and smoke the cars. Miss it. Can't wait to get my LT1 fired up. I'm sure I'll do some mods. Stay in touch. Tim
63 SWB C10
Old 11-09-2012, 11:09 PM   #19
Trsmotrhed
Trsmotrhed's Avatar
Been busy at work and not much time for truck. I got my new radiator this week and installed today. Waiting on a stand alone harness now. The one I had bought was and mess and gave up. Went ahead and ordered a new one from tech rods on ebay. The radiator is a champion aluminum one from ebay also. Very impressed with the quality welds. Darn phone won't upload pic. I'll log in and post pic.
63 SWB C10
Old 11-09-2012, 11:43 PM   #20
Trsmotrhed
Trsmotrhed's Avatar
Attached Picture. Check out the new LT1 Plate on throttle body.
63 SWB C10
Old 11-10-2012, 01:47 AM   #21
McMurphy
McMurphy's Avatar
Hello and to the boards !!!
If you want to see a really awesome LS install build please check out this thread:
http://67-72chevytrucks.com/vboard/s...light=mesquite
He has done an incredible job on his, and there may be some info there that you will find helpful !!
Good luck, always good to see another of these rigs getting the time and attention they deserve.
Sheesh talk about survivors of the road !!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 11-10-2012, 11:53 AM   #22
Trsmotrhed
Trsmotrhed's Avatar
Thumbs down Re: 63 SWB C10 LT1/4L60E Swap
I checked out the build. Wow, I'm jealous. Lol. He's doing a great job. I'll follow his build for sure. Right now I'm trying to fit everything up and than I'll take apart and powder coat and paint.
63 SWB C10
Old 12-06-2012, 09:12 PM   #23
Trsmotrhed
Trsmotrhed's Avatar
Installed my cold air intake I got from ebay. Fits nice and looks great. Also installed the oil bypass adapter to eliminate the oil line cooler.
63 SWB C10
Old 12-29-2012, 11:37 PM   #24
Trsmotrhed
Trsmotrhed's Avatar
Installed the new gas pedal assembly with the Lokar throttle cable along with with finishing the B&M Mega Shifter. Also installed the wiring harness. I ended up buying one from Tech Rods off Ebay and is awesome. Very well built. Just got my ECM back from LT1 PCM Tuning and be hooking it up tomorrow. Next week I'll order the Stainless Steel fuel lines from Purechoice Motorsports to go from the fuel rail to frame. I'll also order the fuel pump from Tanks Inc with the baffle already built in, The PA series. I'll post pics as I progress. I made my own fitting for the steam line off the head and tied it into the heater hose. I didn't want to tap and drill the water pump as I've seen some do. If I ever have a water pump go bad I don't want to have to modify it.
63 SWB C10
Old 01-06-2013, 08:37 PM   #25
Trsmotrhed
Trsmotrhed's Avatar
Installed the stainless steel teflon lined fuel lines from the engine to the frame. I ran steel lines to the back of the truck with a fram filter installed in feed line. I'm also going SS lines from the fram to tank, make is easier to drop tank if I need to for a fuel pump. I got the fuel lines and fittings from Pure Choice Motorsports. They are very helpful and knew exactly what I needed for the swap. Also installed the SS line for the power steering I got from pure choice.
63 SWB C10
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
