Old 09-26-2012, 08:41 AM   #1
dean jendro
Old and crusty
dean jendro's Avatar
Front anti sway bar question
I have a new problem. Without looking closely at my 65 Chev C10 I ordered front stabilizer bushings from Classic, #74-811, which is really a Moog K8204. Upon trial fitting them on the bar I found them to be too small. The unit appears to be factory as the brackets are riveted to the frame but the bar diameter is 15/16 and these bushings are for 3/4 inch bars. I looked on the Moog site and all they list for 64 is 11/16 dia and for 65, 66 and 67 they list bushings for 3/4 inch bars. In 1968 Moog offers bushings for 1-1/16, 1-1/8, 1-3/16 and 1-1/4 inch bars. They are also the correct style for my clamps.
What the heck do I have and where do I find bushings for a 15/16 inch bar?
Link to Moog
http://www.moog-suspension-parts.com...s.asp?cat=2276
65 Chevy long wide daily driver - SOLD!
64 Chevy Short Step LS
dean jendro is offline   Reply With Quote
Old 09-26-2012, 11:11 AM   #2
sigshooter
sigshooter's Avatar
Re: Front anti sway bar question
The bushings will have a gap in them until you tighten the clamp down, this ensures a good tight fit
1965 long bed ( grandpas old truck )
1964 long bed BBW Custom Cab
1966 Short stepside
1964 long bed
1965 long bed Custom Cab, factory air, V-8, powerglide
sigshooter is offline   Reply With Quote
Old 09-26-2012, 11:39 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
yup, you kinda have to crank on them a little bit.
I've had to do sway kits on other cars, and trust me this is the easier method. Ones that don't have split bushings, or ones that don't have any real movement in the clamp are a PITA. Usually you have to grease the living heck out of the things, but wd40 works since it dries out in a little, wherease grease gets all over.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-26-2012, 10:38 PM   #4
dean jendro
Old and crusty
Here's some pics of my issue. I know there should be a gap when installed so they tighten down but these bushings are made for a 3/4 diameter bar not 15/16 diameter like I have. You can see what a 3/4 diameter bar would look like, a normal looking gap. Looking at my current sway bar set-up you can see the style of the bushing is not the same either. The bushings and clamps look like the ones that ECE sells for their 1-1/4 bar.
I can't find any reference to any 15/16 sway bars on our trucks so maybe some previous owner installed an aftermarket one and used the factory brackets on the frame. I guess if I can't find the correct bushings for this diameter bar I'll need to get a more common one from a wrecking yard and buy Moog bushings for a later model truck. Pictured is from Moog site, Part number K6169 for many years and models. 68 and up. They also have that style in 1-1/8, 1-3/16 and 1-1/4 but not 15/16.
Anyone have a similar sway bar size?
Old 09-26-2012, 11:08 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
I had no idea the size of my sway bar so I just went out and tried some wrenches on it. The bar turns out to be 1 1/16". It was on the 1975 front suspension I swapped in a number of years ago. I probably bought the bushings from Napa Auto, as I see they still carry that size. I checked through all of the bushings they offer and 1 1/16" is the smallest they list back to 1968. For 1967 they show only 3/4". I couldn't find anything in 15/16".
Mine are rubber as I don't like the squeeking associated with urethane:
http://www.napaonline.com/Catalog/Ca...236_0315083600
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 09-27-2012, 08:39 AM   #6
dean jendro
Old and crusty
Thanks for checking Mark. I guess when I re-do the front suspension I'll just change out the sway bar to a 1-1/16 or 1-1/4 inch as they seem to be the more common sizes. Then I should be able to get the right bushings. All the front end components appear to be stock, even the ball joints are riveted in.
Maybe a good winter project although all the joints are still tight and greased so it's not a high priority fix.
Anyone else have any odd sway bar sizes?
Old 09-27-2012, 12:10 PM   #7
luvbowties
luvbowties's Avatar
Thumbs up Re: Front anti sway bar question
Link to Moog
Try here for K-8792. http://moog-suspension-parts.com/pro...rod=MOOG-K8792. Also check local houses for 1971 Ranchero, Fairlane, Torino. HTH, sam
luvbowties is offline   Reply With Quote
Old 09-27-2012, 01:22 PM   #8
markeb01
Senior Enthusiast
markeb01's Avatar
Outstanding. Thanks for finding the correct size bushing and sharing the link for anyone else having this problem..
Old 09-27-2012, 03:37 PM   #9
dean jendro
Old and crusty
OMG!! It just got worse. My truck's part Ford!
Old 09-27-2012, 03:43 PM   #10
dean jendro
Old and crusty
I feel better now. I searched the Moog site for sway bar bushings and came up with their universal sway bar bushing page. It shows all kinds of different sizes. When you click on any size it brings up possible usages for that bushing. That's where the Ford usage comes from. Whew!
http://www.moog-suspension-parts.com...r_Bushings.asp
PS. Thanks luvbowties; you saved me from pitching my 15/16 sway bar.
Old 09-17-2013, 09:20 PM   #11
1963c-10
1963c-10's Avatar
i just got a factory sway bar off a 65 that was also 15/16". i ordered the same moog sway bar bushings #k8792 also, so ill know in a few weeks how it'll go together. glad i came across this thread as i almost did the same and ordered 3/4" bushings
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 09-18-2013, 01:11 PM   #12
verdell
verdell's Avatar
I took a sway bar from the salvage yard and measured the diameter with a caliper. Took that measurement and bought Energy Suspension Polyurethane bushings from local auto parts stores. Kind of late but I hope this helps...
verdell is offline   Reply With Quote
Old 09-18-2013, 01:19 PM   #13
1963c-10
1963c-10's Avatar
No, I appreciate the reply. The 15/16 is sort of an oddball and all my local places don't have them. I have them ordered from Moog. I talked w/dean jendro who opened this thread to see if he encountered any issues....he went with a larger sway bar. So I'll get some pics of the install with the 15/16" bar to add to the thread. Thanks again for the reply.
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
