Old 09-29-2012, 11:19 PM   #1
USMC45
Numbers at the top of firewall?
Anybody know what these are, my truck has them on both sides and I've seen other trucks on here with the same thing.
Junkyard, factory, any ideas?
Here's some pics, looks like a sharpy?
Under Construction* 2011 Chevrolet C1500 | RCSB | 6.7 | 10PSI
*Under Construction* 1968 Chevrolet C10 | SWB | 6.3 | 6PSI
*Under Construction* 1968 Dodge Coronet 440/ Cloned Super Bee | 7.2 | 14PSI
USMC45 is offline   Reply With Quote
Old 09-29-2012, 11:50 PM   #2
jocko
jocko's Avatar
Re: Numbers at the top of firewall?
they are factory assy line markings
ce10934 should match your spid's model number - i.e. longbed 1/2 ton fleetside. Is your truck a gmc (the T, perhaps?)
unsure about the stuff on the right, maybe others can chime in
Old 09-29-2012, 11:53 PM   #3
USMC45
Chevrolet
Old 09-29-2012, 11:58 PM   #4
USMC45
Hmmm, I think you may be right. My MIN is CE10934. Here are my full specs.
68 C10 CST Spec's
Vin CE148S207402
W/ Base 127
SE (Blank)
Model Identification Number
CE10934
Engine Code V0426TCK
Vin Breakdown
C - Conventional
E - 8 Cylinder
1 - 3,900-5,800 1/2 Ton
4 - Pickup
8 - 1968
S - St. Louis
207402 - Vehicle Number
Model ID Number Breakdown
C - Conventional
E - 8 Cylinder
09 - 54"-59" Cowl to Axel Dim.
34 - Cab & Fleetside Pickup Box
Engine Code Breakdown
V - Flint (Engine)
04 - Month
26 - Day
TCK - 1973 - 307
Option # - Option
45?7AD -LT Blue/ Off - White
4N40VC - Power Steering
4A11CA - Tinted Glass
4618AD - Blue Vinyl Trim
4U63HG - Push Button Radio
4Z53GP - Ammeter - Oil Gauge
4C60DL - Air Cond - All Weath
4L30AC - 327 Cu In V-8 Eng
4B93AA - Door Hedge Guards
4Z84RL - Custom Sport Truck
4G80AA - Positract Axel 373R
4P01AA - Wheel Covers
4B98AB - Side Trim Mold Eq
4J70BD - Brake Booster Eq
4M49DG - Turbo Hydra - Matic
4H05AB - Rear Axel 373 Ratio
Old 09-30-2012, 12:13 AM   #5
ls1nova71
ls1nova71's Avatar
The writing on the right side (in the pic, but would actually be the left side of the truck) that says AC30 M49 is the engine and transmission codes, 327 automatic.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10 (avatar truck)
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 09-30-2012, 12:28 AM   #6
USMC45
Yup ok makes sense, I do see that. 30AC=327 & M49=Turbo Hydramatic.
I'll have to check the other numbers tomorrow, they are kind of hard to read in the picture. Good to know, I was worried that maybe it got totaled and salvaged maybe, but all the numbers in the glove box, door seal, and frame all match, the frame is straight and drives like a dream. That's a relief off of my shoulders!
Old 09-30-2012, 12:54 AM   #7
SS Tim
SS Tim's Avatar
Well here is what I can offer. The only thing left are the "T"s repeated on both ends of the firewall, I just don't remeber right now where my reference for this is.
Your extended paint SPID callout is 4537AD and all you need is the 537 code denoting the Light Blue and Ivory two-tone paint
SS Tim is offline   Reply With Quote
Old 09-30-2012, 01:05 AM   #8
SS Tim
SS Tim's Avatar
Better?
Old 09-30-2012, 01:14 AM   #9
USMC45
Thank you SSTim, that looks like the complete breakdown of it expcept the T's. That picture with the outlines really help!
Old 09-30-2012, 01:37 AM   #10
ls1nova71
ls1nova71's Avatar
I've never heard a definite answer as to what they were. I always thought they denoted 2 tone paint, and the ones that said 4T were deluxe 2 tone, (4 tone? example, white, blue, white, blue), but again not positive.
Old 09-30-2012, 01:39 AM   #11
SS Tim
SS Tim's Avatar
No problem glad to be of help.
Old 09-30-2012, 10:56 AM   #12
John H.
John H.'s Avatar
under the ac flapper, this is actually 4T for an AC truck. Not sure what is to the left of that. I have seen an S on non ac trucks.
Also, behind the distributor, there may be a number from 1-1000. This is the production job number and you may find this on the lower cross member below the radiator, on the back of the speedo cluster and on the brake pedal assembly.
John H. is offline   Reply With Quote
Old 09-30-2012, 12:14 PM   #13
Lee H
Lee H's Avatar
The numbers on my 72 were almost unreadable. Matched the SPID and build sheet. The job number was also etched into the fire wall above the brake booster. May be hard to see in picture.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 09-30-2012, 03:25 PM   #14
SS Tim
SS Tim's Avatar
Interesting thought on the "T" and "S" being A/C option status. That may very well be so. But I don't agree that in this case the far right set is something other than "Z84" (CST RPO#). This three character group is a common run and size with the next character "T" being a larger size and at a greater angle relative to level. The "T" is however very similar to the model number that follows is a progressive downhill run. To me this indicates the markings were written as seperate, distinct groups. If you have other clear examples of a "4T" grouping in this location without the CST option or other potential option number overlap I'd like to see it. At this point it would appear that "T" alone could indicate A/C, especially as it is repeated on both ends of the firewall.
Old 09-30-2012, 04:46 PM   #15
USMC45
Your right, there is actually a 6 up there, it's kinda hard to see with the seal sticking up, but I removed it to clean.
Old 09-30-2012, 05:00 PM   #16
kcfirstbuild
Fun to put back on the truck when your all said and done. I scrubbed half of mine off before i knew what i was doing. I some what figured it out and put them back on the fresh paint.
kcfirstbuild is offline   Reply With Quote
Old 09-30-2012, 08:48 PM   #17
bollybib
bollybib's Avatar
I think the T is for the trim. T alone, one trim strip; T with 2, upper and lower.
http://67-72chevytrucks.com/vboard/s...5&postcount=41
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 09-30-2012, 11:22 PM   #18
USMC45
What is upper & lower trim?
Old 09-30-2012, 11:40 PM   #19
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
The trim pieces that run along the sides of your truck...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
GASoline71 is offline   Reply With Quote
Old 09-30-2012, 11:47 PM   #20
USMC45
I guess the CST Bowtie10 are the upper and the side molding the lower?
Old 09-30-2012, 11:50 PM   #21
USMC45
Now that I think about it the T2 is probly the two tone ones with the upper & lower trim like you said, and mine is T for the single.
Old 10-01-2012, 12:42 AM   #22
CG
BlahBlahBlah
Thats really great, nicely done!
Old 10-01-2012, 01:11 AM   #23
SS Tim
SS Tim's Avatar
Thanks, I try to help.
Old 10-01-2012, 05:53 AM   #24
huahuamick
Looks awesome, thanks mate.
huahuamick is offline   Reply With Quote
Old 02-18-2013, 12:17 AM   #25
WIDESIDE72
WIDESIDE72's Avatar
Good info here!
WIDESIDE72 is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2020, vBulletin Solutions Inc.
