Old 10-03-2012, 05:52 PM   #1
76k10
Discussion - NP203 Transfer Case Failures
If anyone has broken a NP203 transfer case internally, please tell us how.
I feel like the 203 has a bad reputation, but (like a 12 bolt) I never hear about them actually breaking.
76k10 is offline   Reply With Quote
Old 10-03-2012, 06:10 PM   #2
csb#356
Re: Discussion - NP203 Transfer Case Failures
I have only had one that broke. When you spun the tires locked in 4 wheel drive it would make a ferocious clunking sound. I didn't take it apart to see what actually was going on but I figured it was probably the chain jumping around but not sure. The problem with the one I have now is that there is some slack in the chain and clunks when going into reverse. This case has been in full time four wheel drive configuration since 1979.
csb#356 is offline   Reply With Quote
Old 10-03-2012, 06:16 PM   #3
Redcap
I have owned a few vehicles with NP203s over the years. Chain failures, drive sprocket failures and windowing the passenger side of the low case section are all pretty common. They also burn up fairly easily, even with a lightweight oil.
They are one of the first things I swap out.
Redcap is offline   Reply With Quote
Old 10-03-2012, 06:21 PM   #4
vidman
vidman's Avatar
Best thing to do is stay away from them. The two i had the chain and sprockets went. The last one i had i put a part time conversion in it and it did last longer but not by much..
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 10-03-2012, 08:33 PM   #5
Mike C
Mike C's Avatar
The high/low box is run with NP205 all the time to make a doubler setup, and in that format they are tough. So it looks like the chain and sprockets is the weak point, but obviously, the chain is the weak link in most of the chain drive cases. If it's in good shape, just run it.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 10-03-2012, 08:36 PM   #6
76k10
Mine is in good shape, I just like reading about this stuff.
Old 10-03-2012, 08:46 PM   #7
SunSoaked
Go with what Redcap says. He gets everything for cheap and nothing ever fails.
"I once saw a six foot chicken eating prairie dogs like they were worms, but this was while driving between Janos, Chihuahua, Mexico and Agua Prieta, Sonora, Mexico on Route 9, after having consumed my share of El Presidente whiskey "
SunSoaked is offline   Reply With Quote
Old 10-03-2012, 08:50 PM   #8
76k10
In a perfect world, I would. I am not in a situation where I can spend any money on fun stuff, so I am having to make the best of what I have.
Old 10-04-2012, 06:25 PM   #9
Redcap
Ha! I only know what works and holds up due to things failing. As for cheap...well, that is true. There are a ton of these trucks laying around in these parts and, most of the time, people are real willing to deal considering the economy.
Old 10-04-2012, 11:26 PM   #10
OrrieG
OrrieG's Avatar
I had the 203 rebuilt in 1985 when I put it my 59. The mechanic (good friend now deceased RIP) upgraded the chain and put in a Doug Nash part time kit. It was my daily driver until 2000, about 7K miles a year including camping and hunting in some pretty rough stuff, When I had it out I checked it and the chain is a little loose but not enough to warrant tearing it apart. The full time shaft conversion keep the load off when in 2wd. When they stretch under load the chain will jump the gear (that is the bang) and, I assume eventually break or hand grenade the case. I have also read that the cheaper part time conversions that use the wafer bearing fail over time because the bearing breaks down allowing the internal part to move and lock up causing havoc. IF I had it to do over I would go with a 205 set up but I am not that ambitious and have a good spare ready to go that will probably last the rest of my life, the next owner can do what he wants. The biggest pain is the shifter, it is a rube goldberg affair with sliding cams that get loose and crudded up. Then you get to spend a lot of time getting underneath with a big screwdriver to pry the levers back into place. I converted mine to a twin stick so there are no cams, just two mechanical levers that pivot.
OrrieG is offline   Reply With Quote
Old 10-04-2012, 11:33 PM   #11
76k10
I have found a good spray of WD40 down the shifter boot will free the stock shifter up. Mud is an enemy of those shifters.
Old 10-16-2012, 01:29 AM   #12
kenbob87
kenbob87's Avatar
i have destoryed 3 203's before i swapped it out for a 205. the chains would always slip and on two of them i broke the front output shafts. but i ABUSE mine it is strickly a mud truck so it always under alot of load at the time i was running 35x15.5 thornbirds i also had alot of problems keeping my 203's in low range too
kenbob87 is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
