![]() ![]() Join Date: Apr 2005
Project "Shifted"
1968 Chevrolet C-10 Porterbuilt Extreme Drop Member:
Rust free cab (original rockers, cab corners and kick panels), doors and front clip with all glass. Bolt in high hump tranny cover. New rubber cab mounts. New Precision Gasket door seals. Original factory Buddy buckets recovered with white vinyl and green Highlander plaid Original steel front and rear painted sport bumpers and brackets. Hills Rod & Custom fiberglass front tubs for dropped trucks. Porterbuilt Hood hinges with gas struts Custom Steel sectioned rear tubs New stainless steel Flaming River tilt with column shift with Lokar shift linkage. Custom wooden steering wheel. Borgeson steering rod and u-joint steering Custom gas pedal setup with Lokar cables. New Tri-plus core support, bedsides, tailgate, front bed panel and inner wheel tubs and custom “Chevrolet” rear filler panel. Complete Mar-K red oak wood bed kit with polished stainless steel strips and hidden fasteners Bed, tailgate, tubs freshly painted 503 green to match the cab and front clip. Factory short bed chassis with front and rear Porterbuilt Extreme dropmembers. Porterbuilt tubular upper and lower A-arms with new larger ball joints. Porterbuilt rear tubular trailing arms and crossmember. Porterbuilt front radiator crossbar. Porterbuilt transmission mount. Complete Accuair e-level setup with level sensors, compressor, tank, manifold exo-mount, fused power wiring harness, IPOD controller. Front and rear airbags, airline fittings and shocks. New power rack and pinion with braided PS lines. 1.25" Adco sway bar. CPP 2" dropped modular spindles (73-87) with aluminum hubs. CPP front and rear big disc brake kit (13"/12") with black powder coated calipers, zinc coated slotted and drilled rotors, and braided stainless brake lines. New 20x10 and 20x8.5 Billet Specialty Vintecs Fat Lips with TOYO Proxy II tires. Custom two piece 3.5" driveshaft/slip joint and heavy duty carrier bearing. Factory 1968 12 bolt rear with Eaton posi, 3.73 gear and new ECE 5 lug axles, bearings and seals. Captain Fabs brake bracket with new 9" Power booster, new Wilwood master cylinder and proportioning valve. The chassis and all components have been sand blasted and painted with POR 15. New American Auto Wire complete body electrical harness New Dakota Digital VHX gauges All new Vintage Air Gen IV AC components 2002 Z28 330 HP LS1 (5.7 all aluminum)/4L60E with only 25K documented miles. ECM/MAF/O2 sensors. NEW BPAutomotive standalone “SHOW” EFI Harness (braided wrap) with fuse/relay panel. Custom dual pass Entropy aluminum radiator with dual electric fans (with built in tranny cooler). Hotrod Dynamics radiator cover. Custom stainless cold air intake setup. Optima battery. New Holley LS accessories and brackets - ps, ps braided lines, high amp alternator, ac compressor (SD7) all new. 2010 Camaro manifolds with Custom aluminum fuel tank (Linexed) with in tank Walbro fuel pump and 90 ohm sending unit. (with braided fuel lines and Corvette fuel pressure regulator). Custom ECM mount. LOKAR shifter linkage, transmission filler tube, throttle brackets and cables. New ACC rubber floormat FATMAT throughout cab ****** I picked up this nice 68 project from a fellow boardmember Shifty for my son Jake a little less than 2 years ago (thanks for the great deal Jason, ![]() http://ls1tech.com/forums/conversion...-stepside.html Our plans are to keep close to what Jason had orginally planned for the truck, but with a few small "variations". He had bought a fairly orginal 68 short stepper that had an older restoration (the cab on this truck is nicer than the on on my brown/white 68!). He installed a nice low mile LS1/T56 and had planned on bagging the truck with a basic air ride suspension. We plan on sticking with the drivetrain (the T56 should be fun!). Our variations are as follows: Switching the stepper bed for a fleetside A complete Porterbuilt front and rear dropmember setup (thanks Mike Baker!). Swapped Autometer gauge setup for a set of Dokata Digital VHX gauges A set of buddy buckets (of course, ![]() A set of 20's (probably Coys?) Jake likes the patina look, so we're leaving the paint as is for right now. Plans are to get it running and driving for his 16th birthday (we've got a year and a half). Eventually we may tear it back down and repaint it. I'll try to keep you updated as we go. Here's some original pictures of when Shifty first got it.
Rob - http://instagram.com/hart_rod As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: ChubTubz- http://67-72chevytrucks.com/vboard/s...d.php?t=675754 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 FAQ: http://67-72chevytrucks.com/vboard/f...play.php?f=220 Last edited by Hart_Rod; 01-28-2016 at 12:48 PM. |
Re: Project "Shifted"
Here's a couple of pictures of the engine install.
Rob - http://instagram.com/hart_rod As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: ChubTubz- http://67-72chevytrucks.com/vboard/s...d.php?t=675754 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 FAQ: http://67-72chevytrucks.com/vboard/f...play.php?f=220 |
Village Idiot....
![]() Join Date: Jul 2003
That's a good looking truck!
http://www.hubgarage.com/mygarage/n2billet -67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold -71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold |
And here's a couple pictures of the parts we've been gathering....
Thanks Keith. I think it will be a perfect "starter" truck. Sorry I missed you at CTC, I was in Dallas at the time (go figure). Here's some more pictures of the chassis. We still have some welding to finish up and I need to test fit the motor and tranny, then we can blast and paint it. Hopefully things will speed up after that.....
Village Idiot....
CTC was fun, I'm going back next year. Have you thought about mounting the tank on the top of the rails? With it that low if he lifts the front more than the rear it will hit.......ask me how I know.
#7 | |
Village Idiot....
It doesn't look out of place on top (to me).
Man of Mini-Talents
What a fun project. I wonder what insurance will be like on that? No matter, he'll be cool at school for a ton less than the new Camaro kids.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
Oh yes Rob!! I will follow!
-Rus |
Tot Roddin'
Subscribed.... this will be a great build.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
Sweet ride.
#13 |
![]() Join Date: Dec 2008
I'm in for sure!
Rex |
#14 |
Sweeeet ! I'm in.
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
#15 |
NO WAY! I met Jason years ago. I sold him a set of 99-02 silverado seats, I take it he didn't throw those in with the truck? They were really nice too, charcoal and at the time low miles (I think around 70K on them.)
Two years ago? Man, I told him if he ever sold it to let me know! At least it's in really good hands now! I take it he never actaully got it running?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#16 |
nice truck...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#17 |
What was I thinking?
Rob that's a nice step side, I'm in!
Justin '68 C/10 Custom Long wide bed '78 GMC Sierra short wide Project: Second time around...'68 short wide http://67-72chevytrucks.com/vboard/s...d.php?t=423949 |
#18 |
![]() Join Date: May 2009
I'm in too, look forward to seeing this one go together!
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
#19 | ||
Thats probably what I'll end of doing.
![]() ![]() Thanks Nate! Thanks! Thanks! Thanks! Quote:
Thanks Mike! It was, now it's going to be a fleet... ![]() Thanks! **** Well we made a little progress today. We almost got the front clip pulled off, so we can pull the motor/tranny out. Then we'll remove the old chassis so the cab will be ready to put back on the new frame once its blasted and painted. Speaking of drivetrain, since I'm going a different direction with my 68, my son mentioned putting the LS1 with the 4L60E in his truck. He likes the thought of paddle shifters (he got this from his XBOX or maybe TopGear????) and we found this cool setup online thanks to another boardmember: http://www.tciauto.com/tc/shifters/paddle.html. Has anyone tried this? Thoughts? He really likes the idea of a 6speed, but the paddle shifter is pretty cool. I gave him this week to think about it, because one of the engines has to go. I also put one of the Coys wheels off of the suburban on his chassis. He really likes the way it looks, so we'll probably go that route. Here's some pics...
#20 |
![]() Join Date: Mar 2010
LOOKIN GOOD !!
with the LS / T56, this should be very fun to drive..
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629 1969 custom/10 swb--SOLD 1968 swb 50th anniv.--SOLD 1967 camaro ss/rs..LS-6-speed, 16-year long project 1956 chevy nomad 1955 chevy 210 2-dr sedan 1978 el-camino ss 1-owner |
#21 |
That paddle shift would be awesome!!
-Rus |
#22 |
![]() Join Date: Apr 2010
Maybe I missed it, but what brand is your electric fan and shroud set up? Info on where to get it would be appreciated. Thanks
Posted via Mobile Device |
#23 |
I'm in, subscribed
ANDREW 1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072 1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827 1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315 1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788 |
#24 |
![]() Join Date: Dec 2006
Nice build, I'm in to see how it turns out
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#25 |
Looks like this one is going to be fun to watch!!!
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
Thread Tools | |
Display Modes | |
