11-26-2012, 06:44 PM | #1 |
Early X-mas! 6.0 L96+6L90
I bit the bullet and bought this today. It is out of a 2011 2500 2wd with 19,000 mi. It will be going in my 71 chev swb.
I need to start gathering parts. The place I bought it from didn't know which oil pan I needed, but said to find out and they would get me one at cost. So, first question. What oil pan? I have seen people using an F body pan, ctsv caddy pan, summit pans, etc. My truck has a 4/6 drop with 18/20 wheel combo. What is the best? Thanks in advance for the many questions I will be asking.
1972 3/4T 4x4 Chevrolet (383) 1971 c-10 SWB (400 sb) 1972 4x4 Blazer 1969 SWB 4x4 GMC Projects: 1972 stepside 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=280132 http://67-72chevytrucks.com/vboard/s...d.php?t=285952 http://67-72chevytrucks.com/vboard/s...d.php?t=553672 http://67-72chevytrucks.com/vboard/s...d.php?t=522704 |
11-26-2012, 07:03 PM | #2 |
Re: Early X-mas! 6.0 L96+6L90
Ctsv for me fit perfect bottom of pan was about 1/4 inch above crossmember. My truck is also 4/6.
Posted via Mobile Device |
11-26-2012, 07:14 PM | #3 | |
Thanks John
11-26-2012, 08:26 PM | #4 |
GM swap pan http://www.summitracing.com/parts/nal-19212593
11-26-2012, 08:36 PM | #5 | |
Thanks for the input! john
11-26-2012, 08:53 PM | #6 | |
The list is not complete. Not sure on AFM (active fuel management) engines though, Does the L96 have AFM? |
11-26-2012, 09:06 PM | #7 |
That's gonna be pretty sweet!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
11-26-2012, 09:11 PM | #8 |
I used an f-body pan on mine.
11-26-2012, 09:45 PM | #9 | |
Thanks Rob! Is yours a 2011? The are a few differences over the older GenIV motors, like injectors, intake and exhaust valve material (for E85). I am just wanting to be positive that there were no changes to the oil pan or oil pickup, etc. Thanks John
11-26-2012, 09:47 PM | #10 |
Would that have to do with it being a returnless fuel injection system?
11-26-2012, 11:50 PM | #11 | |
It does not appear that the L96 is not AFM...but does have VVT, So the pan will fit. |
11-26-2012, 11:54 PM | #12 |
Thanks Cline,
Do you have any other advice for this swap? I am from the Old School and don't have much experience with any motors requireing a computer! I have spent quite a bit of time on LS1tech, but not much info on the L96 and 6L90 over there. Thanks John
11-27-2012, 01:59 AM | #13 |
06-08 pan tried to buy used but the wrecking yards laughed at me paid around 280/300 new heres how it looks in my truck
11-27-2012, 09:16 AM | #14 |
Location: Sunny, Florida, some might call it South Alabama
I am using a 98 corvette pan. Seems to be the only one that doesn't even come close to hanging down below the K member.
Just sold my C10...sad day... Looking for a 1972 Blazer to hopefully fill the hole in my heart. |
11-27-2012, 12:17 PM | #15 | |
11-27-2012, 10:16 PM | #16 |
Thanks Dan and Smoke! Appreciate the input.
Rob, I bought the ECE motor mounts and trans mount last year. Not sure if they will be a straight forward setup for this combo. Will probably do a test fit on a bare frame I have and see what kind of mods I will need to do. The motor should be here sometime next week....I hope. Getting excited about this project, but I have a long ways to go as far as getting all the parts! John
11-27-2012, 10:22 PM | #17 | |
I'm looking forward to seeing the finished product, let me know if you have any questions. If you use the ECE mounts you won't be able to use a FBody oil pan (it hits the front crossmember). I used a 2007 Cadillac CTsV pan, but there are several choices out there. The Doug Thorley Headers work well with those mounts also. You can check out my Suburban build thread for pictures of both. Here's a good thread on choosing an oil pan: http://67-72chevytrucks.com/vboard/s...d.php?t=272174 Rob
11-27-2012, 10:28 PM | #18 |
Thanks Rob.
I bought the mounts with plans to put a 5.3 and 4L60 into a 68 GMC. I may just save the mounts for that project. What do you think about the DirtyDingo mounts? I had planned on using the same headers that you did. If I get mine running before the burb is done.....can I use the supercharger for a little while? I will probably have a lot of questions for you when I get further into the swap. John
11-27-2012, 10:44 PM | #19 | |
EDIT: Who did you get your motor/tranny from?
11-27-2012, 10:50 PM | #20 |
Thanks for the pan link. I did a search earlier, but I must have missed that one! Good info!!!!!!!!
The adjustability might be handy with the DD mounts! I would like to use the stock fan setup instead of electric fans. The supercharger would be nice to borrow, but I bet you will be ready to use it before me! John
11-27-2012, 10:52 PM | #21 |
Rob..
pick_a_part on ebay.
11-27-2012, 11:27 PM | #22 |
I'm using ece mounts with electric fans. I don't think it will clear manual fan. When using these mounts with the trans crossmember all my factory holes lined up. Since this is my dd I chose the Holley hooker ls manifolds didn't want to deal with headers even though the thorleys are awesome plus the hookers were cheaper and fit like a glove. Just wanted to share a little info from my recent conversion
11-28-2012, 12:17 AM | #23 | |
John
11-28-2012, 02:41 PM | #24 |
How much was the motor and trans?
11-28-2012, 10:22 PM | #25 |
hope this helps.... Im running the gm muscle car pan it's shallower than the stock truck pans by 1 1/2". I'm guessing the f-body pans are close to the same as the holley pan...
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
Thread Tools | |
Display Modes | |
