Old 01-10-2013, 12:20 AM   #1
travz500
travz500's Avatar
pics of how you ran fill hose on rear mounted tanks
Hey guys I have heard of lots of different fill hose ideas but have seen no pictures how did you all hook up your fill hose to your rear mounted tanks?
I am gonna buy the boyds tank and would like to see some pics of how you all hooked them up I am also trying to decide if I should get the top fill and just go thru the bed floor but my truck is 4x4 and has a 8" lift and will have
38" tires so will be tall and I think the fuel doors look funny on these beds
travz500 is offline   Reply With Quote
Old 01-10-2013, 01:23 PM   #2
travz500
travz500's Avatar
Re: pics of how you ran fill hose on rear mounted tanks
anyone??
Old 01-10-2013, 01:30 PM   #3
Goinlow64
I dont have a picture, but I just wrapped my filler hose up this week. I have an LMC rear mount tank. The problem was the flush mount bed filler I had was 1.5" and the tank is 1 and 3/8" on the neck. SO I used a copper 1 1/4" to 1 1/2" reducer. The 1.25 end fit perfect in the neck on the tank. I also sweated in a 1.5" street 45 to get the neck pointed up instead of angled. I Right now I have the bed off, so I just have about 6" of fuel fill hose contacted to the filler and the neck. Hope that makes sense!
Goinlow64 is offline   Reply With Quote
Old 01-10-2013, 02:11 PM   #4
travz500
travz500's Avatar
so is yours going up thru the bed or the bed side?
kinda lost me had to read it twice
Old 01-10-2013, 03:06 PM   #5
63burban4x4
63burban4x4's Avatar
here's an idea, from a suburban
63burban4x4 is offline   Reply With Quote
Old 01-10-2013, 03:34 PM   #6
travz500
travz500's Avatar
good Idea but I just dont want a fuel door if i can avoid it I may even fab up somthing to fill from inside the bed sidewall If i dont go up thru the wood instead
Old 01-10-2013, 05:43 PM   #7
hop sing
hop sing's Avatar
STARTED THINKING THEN SAW A ADD FOR A 56 210 AND THOUGHT THROUGH TAIL LITE ,,?? JUST A THOUGHT ALOHA HOP SORRY FOR CAPS NO GLASSES TODAY
hop sing is offline   Reply With Quote
Old 01-10-2013, 06:18 PM   #8
wayno
This is what I'm thinking of doing Travz.
wayno is offline   Reply With Quote
Old 01-10-2013, 06:23 PM   #9
travz500
travz500's Avatar
looks good wayno havent ordered my tank yet because not sure how I want to fill it from top or side???????
Old 01-10-2013, 06:24 PM   #10
wayno
Another option if your filler does come up directly between the boards - looks like this is off a rice rocket - could even probably get a key - that might be kind of interesting - like this look a bit more than the other option I found.
Old 01-10-2013, 06:27 PM   #11
wayno
I bit the bullet and ordered mine today - I'm not much of a fabricator so I'm going to try my luck with the floor and that way I get a couple of shots to get creative (being that I'm going to try to cut my own new floor boards) - saw somewhere on here where someone posted the measurements and which dato blades to use. Post up some pics when you get yours done I'd love to see where you ended up with it.
Old 01-10-2013, 06:28 PM   #12
BigRed76
BigRed76's Avatar
You could do something like this since it's a lifted 4X4...
Zach
1971 Chevrolet Custom C10, 5.3/4L60E, 3.73's
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
1996 Chevrolet Cheyenne K1500, 5.0L/4L60E, ECSB
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 01-10-2013, 06:36 PM   #13
travz500
travz500's Avatar
yes bigred thought about that but at the same time if I ever go play in the mud after the money I am spending might cry if it gets messed up but I also live on gravel so that option would not work. Could end up with to much junk in the tank even thought about going strait out the back but not even sure I like that idea
Old 01-10-2013, 07:11 PM   #14
BigRed76
BigRed76's Avatar
I understand that. I'm not too familiar with the 60-66 thrucks, but you might be able to do a tail light filler of some sort, where the tail light flips down to access a hidden fuel filler.
Zach
Old 01-10-2013, 08:22 PM   #15
JrJc66
What about behind the rear license plate?
JrJc66 is offline   Reply With Quote
Old 01-10-2013, 09:42 PM   #16
McCoyAZ
McCoyAZ's Avatar
IF you put the filler neck in the wood bed and you spill gass all over the place it will become an issue.
Behind the license plate would work
or
If you want to do "a little" modification you could open up one of the rear stake pockets and run it inside and bring it out inside the bed up off the floor.
McCoyAZ is offline   Reply With Quote
Old 01-14-2013, 08:52 PM   #17
travz500
travz500's Avatar
well ordered 2 drivers side fill tanks for 2 trucks and 2 aluminum 4 row radiators and electric fans from Pro Performance forum vendor here I am gonnna try to run in up by the tail light and put a fill hole there somewhere I wont have to look at from the side everytime I get in so it wont bother me as much thanks for the input guys
Old 01-14-2013, 11:45 PM   #18
raiderfan34
raiderfan34's Avatar
Here's mine. New to posting pics so I hope it works. If not im gonna look like an idiot.
raiderfan34 is offline   Reply With Quote
Old 01-14-2013, 11:51 PM   #19
raiderfan34
Here's one more
Old 01-15-2013, 09:02 AM   #20
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Raiderfan, do you have a boyds tank? How did you put the fill from the bed to the tank?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-15-2013, 10:19 AM   #21
kieth
kieth's Avatar
Here is how I did mine....in the bed Kieth
http://kieth.smugmug.com/Trucks/66-G...4975&k=sMtpxWj
kieth is offline   Reply With Quote
Old 01-15-2013, 10:24 AM   #22
TxRat
TxRat's Avatar
Not the most practical but it is a better set up than what I had. I will figure out a more permanent fix later.
TxRat is offline   Reply With Quote
Old 01-15-2013, 10:36 AM   #23
oldtrux
oldtrux's Avatar
have you seen these khttp://www.classictrucks.com/tech/1002clt_1947_chevy_truck_bed_wood_tailgate_install/photo_22.htmlits
sorry,dont know what happened there,anyways its a hidden underbed hinge kit that lifts that board up=no nasty gas spills on your new beautiful wood floor
oldtrux is offline   Reply With Quote
Old 01-15-2013, 11:12 AM   #24
Chevy Fleetside
Chevy Fleetside's Avatar
I did this with mine when it was a step side. The cap is from a Ford Mustang of the 2000 yr models. It was a pain when I had stuff in the back and had to put gas in. .
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Truck pictures: http://s49.photobucket.com/albums/f2.../The%20Trucks/
Chevy Fleetside is offline   Reply With Quote
Old 01-15-2013, 01:48 PM   #25
austin60c10
austin60c10's Avatar
Is your truck a fleet or stepside trav? I have a stepside and we ran it to the top of the fender and put a popup motorcycle cap on it idk if I have pics I'll look.
A
austin60c10 is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
