Old 01-27-2013, 09:26 PM   #1
lil_sahara450r
aftermarket transmission crossmembers
Hey guys,
looking for opinions on different trans xmembers that are available. I'm swapping out the original 3 speed for a TH400 and I need one. I've looked at the ones from CPP and ECE and wander what y'all would buy (although I typically avoid CPP). Are there any other options out there? Thanks a lot guys!
lil_sahara450r is offline   Reply With Quote
Old 01-27-2013, 09:42 PM   #2
ol_skool_chevy
ol_skool_chevy's Avatar
Re: aftermarket transmission crossmembers
I just ordered this one..........Clean and simple.
http://www.speedwaymotors.com/Straig...ount,3279.html
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 01-27-2013, 10:28 PM   #3
rawraw67
rawraw67's Avatar
Im going to try puting 67-72 crossmember
rawraw67 is offline   Reply With Quote
Old 01-27-2013, 11:05 PM   #4
ACK
ACK's Avatar
I was contemplating this one since I need a parking brake. I ended up not getting it because of price. http://www.bowtieoverdrives.com/cata...php?ITEMID=108
EDIT:
Sorry about that, it's for a 700R4
My truck ain't dead, it just smells funny.
“Beer’s intellectual. What a shame so many idiots drink it.” — Ray Bradbury
A collection of Chevy C10 ideas, fixes, and mods ... https://www.pinterest.com/ack215/
ACK is offline   Reply With Quote
Old 01-27-2013, 11:15 PM   #5
ol_skool_chevy
EDIT:
Yep $175.00 is pretty steep a price for that
Mark with Chalk
Cut with a torch
Old 01-27-2013, 11:53 PM   #6
Slow Build
Slow Build's Avatar
I have read that the frame width remained the same thru the 73-87 trucks. If you feel like gettin your fingers dirty you can probably find something that will work at a dismantler yard.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 01-28-2013, 02:16 AM   #7
Captainfab
60-66 Nut
I've never bought an aftermarket trans crossmember. I've always just used an original one from a '63-'87 pickup or Suburban.
Old 01-28-2013, 03:21 AM   #8
padresag
I do have a stock 66 trans crossmember for a 400
ron
padresag is offline   Reply With Quote
Old 01-28-2013, 03:42 AM   #9
DesertCat
DesertCat's Avatar
Porterbuilt makes one for the 67-72 for $89 like what I just snapped up http://67-72chevytrucks.com/vboard/s...d.php?t=563187
I imagine he would make you one for your truck for about the same
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131
DesertCat is offline   Reply With Quote
Old 01-28-2013, 11:08 AM   #10
gabe2000
My truck crossmember is straight across so I opto to run muffler through the outside of frame. The Ebrake cable runs inside the frame. IMO sometimes it's better something To buy already fabricated vs. Paying to get it fab. I don't have welder.
gabe2000 is offline   Reply With Quote
Old 01-29-2013, 12:03 AM   #11
Z POPPY
I bought a pre-made crossmember with the e-brake mount and added to it. Made just for our trucks.
*http://www.bowtieoverdrives.com/cata...php?ITEMID=108
I canalbized the old crossmember parts from it. Used clevis pins, cotter keys, drilled, bent and made a brass bearing. I didn't use a spring. I have springs on each side on my rear disc brakes. Mocked up clears my 4L85E just fine. Yes I do have a powdercoat problem, my son suggested a 12 step program for me.
Z POPPY is offline   Reply With Quote
Old 02-19-2013, 01:20 PM   #12
KVB
Will a stock crossmember from the 63-87 truck / subrban, bolt in, or is there some drilling or welding to do?
KVB is offline   Reply With Quote
Old 02-20-2013, 02:32 AM   #13
Captainfab
60-66 Nut
There is no welding necessary, just drilling some holes. How many depends on what trans you are installing as some of the factory holes in the frame may line up.
Old 02-20-2013, 08:40 AM   #14
KVB
CaptainFab,
I have a 1965 GMC shortbox with a 230 motor. I have two scenarios in mind. Could you answer some questions I have about them please.
The first is a 700R4.
1. The first cross member back from the motor mounts has to be removed.
2. I have to fit in a another cross member to support the rear of the transmission, 73-87 or aftermarket.
3. Will the transmission fit under an low hump floor
4. If I put in an aftermarket support, how do I make sure the transmission is level. Use a level on the intake manifold? I plan to take a loop off of the coils in the front, to drop the nose a little
5. With a 700R4, I have to pull out the motor and transmission as a unit, as they support each other
The second is a NV3500 or NV4500
6. I keep the first cross member back from the motor, so I can support the bell housing.
7. Will the transmission fit under an low hump floor
8. Is it difficult to setup the hydraulic clutch system.
Another question about power steering, I see that you sell an adapter. What year of truck should I be looking for, to get a power steering box ?
Any other suggestions or ideas you may have about this swap, are greatly appreciated.
Old 02-20-2013, 12:48 PM   #15
padresag
here is what the stock 64-66 a/t crossmember looks like
the 700r4 will fit under a low hump with a little work to the seam that protrudes down from where the floor meets the firewall
if you ca
nm mount a standard trans to the orig style b/housing that mounts to the orig crossmember you are fine. if you use a later or a/market b/housing that doesn't mount to that c/member then you will have to install a rear trans mount c/member.
if you install a 700r4 you should remove the old bellhousing c/member and install a rear mount one. you can drop the a/t without having to remove the engine. bolt in that rear
crossmember so that it can be either dropped or slid back to ease removing an a/t if it ever has to be done. If removing an a/t in this style of application always remember to remove the distr cap so that it doesn't get broken when the rear of the eng drops a hair when you take the tranny out.
you can't go wrong with the capt's steering box mounting plate
ron
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
