Old 02-12-2013, 01:19 PM   #1
mrhurt73
caddy CTS-V oil pan info
ok, so i had the idea i needed a camaro oil pan here.
http://67-72chevytrucks.com/vboard/s...d.php?t=558494
turned out i was wrong, has happened from time to time.
caddy oil pan seemed to be a better fit.
i ordered pan 12631828, does come with gasket and bolts and oil pressure fitting already drilled to 1/8npt thread, just plugged with grease fitting.
ordered 12621299 pickup tube
12611129 windage tray
12584737 dipstick
12584738 dipstick tube
showed original LM7 oil pan for reference.
My Projects-
http://67-72chevytrucks.com/vboard/s...d.php?t=557301
Quest for Hot Rod Power Tour 2013.
http://67-72chevytrucks.com/vboard/s...d.php?t=543735
my 85 GMC 2wd to 4wd conversion for the wife.
mrhurt73 is offline   Reply With Quote
Old 02-12-2013, 01:23 PM   #2
mrhurt73
Re: caddy CTS-V oil pan info
i had seen on the internet that LM7 windage tray and Caddy tray were same part no. but i ordered it anyway. you know one of them have to see deals.
the parts are very similar all bolt holes in same places, only very little bend and cutout differences, could have gotten by without this part. but i put it in anyway i own it now
My Projects-
Old 02-12-2013, 01:30 PM   #3
mrhurt73
ok the pickup tubes are a lot different in size, we should hope so looking at the pans. the o-ring clip on the LM7 is floating ring, while the caddy one is welded. pickup tube does come with o-ring already on it.
i did add an extra M6-1.0 X 15mm bolt with fender washer to the other side of the oil pump where the pickup bolts in. factory only bolts up to one side, so i added bolt to the other side. it was already drilled and tapped, why not use it.
My Projects-
Old 02-12-2013, 01:34 PM   #4
mrhurt73
if you plan on using the oil level switch, i was going to make an idiot light on the dash with mine. the switch that comes with the caddy pan is different than the LM7 switch.
the LM7 switch is 2 pin and the caddy switch is 3 pin.
and the best i can tell with mutimeter, LM7 switch is normally closed contact with no oil in pan, and caddy switch has normally open and closed contacts
My Projects-
Old 02-12-2013, 01:38 PM   #5
mrhurt73
found this picture on the web, where they made a plate to cover both sides, i used factory tab on one side plus added bolt and fender washer on other side.
My Projects-
Old 02-12-2013, 05:19 PM   #6
wgeyer88
Thanks for the breakdown! Out of curiosity, what didn't you like about the Camaro pan, and in what way did the CTS-V pan fit better? I think this thread will be of great help to myself and many other to come who are trying to decide what pan to use!
Will
1970 CST10 SWB LQ4/4L80E
2004 Silverado (sold)
2007.5 Dodge Ram 2500
wgeyer88 is offline   Reply With Quote
Old 02-13-2013, 03:54 AM   #7
BigDan3131
BigDan3131's Avatar
So which year trucks will this work with? Would I need to just notch the crossmember in my 64 to use it?
Custom Painter/Restoration Specialist focusing on all American made vehicles from 1948-1974.
1965 GMC 3/4 Ton LB
1964 Chevy El Camino 11.83 1/4 mile time in 1990
1991 Chevy S10 248K+ miles 2nd Owner
BigDan3131 is offline   Reply With Quote
Old 02-13-2013, 08:28 AM   #8
mrhurt73
sorry didnt go into the camaro pan indepth, the camaro pan comes farther forward than the caddy pan. its not by much but it did make a difference on my truck.
dont know about a 64 frame, i am running a 79 chassis with a crossmember from scotts hot rods.
My Projects-
Old 02-13-2013, 08:07 PM   #9
Daaaanz67
Mine in my swap 69c10 Ctsv pan
Daaaanz67 is offline   Reply With Quote
Old 02-15-2013, 12:05 AM   #10
hotrodwest
hotrodwest's Avatar
I need to change out my 5.3 deep pan for the CTS-V pan. Can I remove it with the engine in place or do I have to jack the engine up?
http://www.hotrodswest.com
hotrodwest is offline   Reply With Quote
Old 02-15-2013, 12:30 AM   #11
Daaaanz67
Probably going to have to lift the motor up just my opinion. When I mocked up this conversion it had the truck pan on and I sat there and studied it thinking about how far the motor needed to go up to swap the pan knowing that the pan would not drop down low enough to clear the bell housing and x member.
Old 02-15-2013, 08:00 AM   #12
mrhurt73
i am betting you will have to jack engine up, the oil pickup tube will get in the way of putting the pan on with engine in place.
My Projects-
Old 02-15-2013, 01:30 PM   #13
Bagood
how big of a pain was it to get the new o ring to seat?
Bagood is offline   Reply With Quote
Old 02-15-2013, 01:32 PM   #14
mrhurt73
not a big pain at all, wiggle pickup little bit while pushing up on it and went right in.
My Projects-
Old 07-27-2013, 08:56 PM   #15
BigRed76
BigRed76's Avatar
I know this is a somewhat old thread, but do you remember what the difference was between the oil dipstick tubes?
Zach
1971 Chevrolet Custom C10, 5.3/4L60E, 3.73's
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
1996 Chevrolet Cheyenne K1500, 5.0L/4L60E, ECSB
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 07-27-2013, 09:10 PM   #16
hotrodwest
hotrodwest's Avatar
I originally had a Lokar dipstick with the 5.3 Vortec pan. When I replaced it with the CTS-V pan the dipstick was too short. I contacted Lokar and they sent me a longer cable. I'm pretty sure it is for an LS-1 application. I think Lokar charged $12 for the longer cable. Hope this helps you.
Old 07-27-2013, 09:15 PM   #17
hotrodwest
hotrodwest's Avatar
BTW as to my original post, I had to jack the front of the engine up and pull the transmission away from the engine to get the new pan installed. Pain in the ass job but worth it since my pan does not hang below the crossmember like the stock 5.3 pan did.
Old 07-29-2013, 07:07 AM   #18
mrhurt73
the best i can remember it was length and mounting location for bolt.
i will try and get a picture of both to compare for you.
My Projects-
Old 07-29-2013, 07:54 PM   #19
BigRed76
BigRed76's Avatar
The reason I ask is because I was thinking that maybe the truck dipstick tube could be trimmed on the bottom to work with the shorter dipstick. But that would only work if the length of the tubes outside of the block are the same.
Zach
Old 07-29-2013, 10:43 PM   #20
Daaaanz67
I'm using the Ctsv pan with truck dip stick and tube. I just fill oil to the cad pan spec and make a mental note where the oil is on the truck stick. Been running this for almost a year with no problems.
Old 07-30-2013, 07:17 AM   #21
mrhurt73
i checked all my pictures and i guess i missed a compare shot of the the dipsticks.
so i took one of it in the engine bay. the yellow dipstick to the left is the CTS-V one and the yellow dipstick on the right is the truck LM7 one.
big difference is total length and mounting location.
My Projects-
Old 07-30-2013, 10:04 AM   #22
Hart_Rod
Hart_Rod's Avatar
My question would be, how much of either dipstick goes down into the pan? If both measurements are the same, you should be able to use either. Just my $.02.
Rob - http://instagram.com/hart_rod
As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17
FOR SALE: DBW pedal bracket, Pedal adapter for LS trucks! http://67-72chevytrucks.com/vboard/s...d.php?t=651123
FOR SALE: ChubTubz, Rear tubs for slammed trucks! http://67-72chevytrucks.com/vboard/s...d.php?t=675754
FOR SALE: Hood Brackets, Bolt in hood brackets! http://67-72chevytrucks.com/vboard/s...d.php?t=679945
1969 SuperBurb - 5.3/Magnacharger..http://67-72chevytrucks.com/vboard/s...d.php?t=200387
1968 Farm truck: LS3/6L80/TVS1900: http://67-72chevytrucks.com/vboard/s...d.php?t=358692
1968 SWB - SHIFTED: PB Xtreme DM/LS1/Dakota Digital/AccuAir/Vintage Air/...http://67-72chevytrucks.com/vboard/s...d.php?t=551258
1948 5 Window Chevy http://67-72chevytrucks.com/vboard/s...=122164&page=3
FAQ: http://67-72chevytrucks.com/vboard/f...play.php?f=220
Hart_Rod is offline   Reply With Quote
Old 07-30-2013, 12:07 PM   #23
mrhurt73
thats the part i didnt photograph before assembly, i think they are relatively the same height, but cant confirm that.
My Projects-
Old 08-10-2013, 12:23 AM   #24
BigRed76
BigRed76's Avatar
Good to know. The dipstick and tube are cheap enough, might as well just get them to match the pan.
Zach
Old 08-10-2013, 12:24 AM   #25
BigRed76
BigRed76's Avatar
Is your engine in the factory sbc location or moved forward?
Zach
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
