Old 03-06-2013, 07:01 PM   #1
JFetter
How to adjust choke pull-off on Holley style Summit carb?
I have a Summit SUM-M08600VS that is acting up. Quite often when starting, it will not start at all. (unless I depress the pedal and hold it that way)
I suspect it is flooding, and think that it's due to lack of air.
Here's my carb:
http://www.summitracing.com/parts/sum-m08600vs
I've read that it's just a holley knockoff.
I have reset the electric choke housing to the 'factory' condition (index marker), but as I understand it, this shouldn't matter anyway. This is a problem during initial startup.
Some old holley guides talk about using a bent paper clip to adjust the "Choke Qualifying adjustment", but I don't think that applies to my carb?? Pic attached.
I'm suspecting vacuum leak or adjustment problem.
Am I on the right track here?
Is there an easy way to check the choke pull-off operation without the engine running? I.E pulling off one of the vacuum hoses and attaching to a vacuum tool?
I'm very new to carbs and sort of learning on my own here.
Thanks!
1978 K10
JFetter is offline   Reply With Quote
Old 03-06-2013, 10:14 PM   #2
geezer#99
geezer#99's Avatar
Re: How to adjust choke pull-off on Holley style Summit carb?
When you finally get it running, where is the level of the gas in the site glass?
Old 03-07-2013, 06:46 AM   #3
JFetter
About 1/2 full.
1978 K10
Old 03-07-2013, 10:22 AM   #4
geezer#99
geezer#99's Avatar
Lower the fuel level to 1/4 of the sight glass on both bowls. Might stop your flooding and starting problem.
Old 03-07-2013, 02:24 PM   #5
JFetter
Ok thanks! I'll give that a try.
1978 K10
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
