Old 03-10-2013, 01:19 AM   #1
chev-obsession
chev-obsession's Avatar
Question Brake pedal switch????
I'm getting ready to replace the old factory brake switch for a new 2 position brake switch "required" when running the 700R4. I havent found any other threads showing this install and it looks like a real pain in the a$$ to get to.
Does anyone have any tips/advice for getting the old one out?! pics/links to another thread would be cool too!
1965 c/10 swb
1969 c/10 lwb
chev-obsession is offline   Reply With Quote
Old 03-10-2013, 01:28 AM   #2
Trsmotrhed
Trsmotrhed's Avatar
Re: Brake pedal switch????
This is the brake switch I installed for my 4L60E. It was easy to install. Remove the old one, hook up your wires as per the diagram and install. Tight quarters to work in. I had to remove the bolt for brake pedal to get my fingers in there.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
2005 Silverado Duramax - daily driver kinda
My project build thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Trsmotrhed is offline   Reply With Quote
Old 03-10-2013, 07:23 AM   #3
tincan1966
tincan1966's Avatar
Just drop the e-brake handle(4 bolts) then the lower column bracket(4 bolts) The switch is mounted to the bracket. I did this is mine and it made adjusting the switch to the correct depth alot easier. You'll need to use the two nuts from your original switch, too.
tincan1966 is offline   Reply With Quote
Old 03-10-2013, 10:16 AM   #4
chev-obsession
ok, thank you!!! so the 12v wire from the original brakes goes one the far side, and the other brake wire goes on the oppsite? is that how im understanding that?
1965 c/10 swb
1969 c/10 lwb
Old 03-10-2013, 11:51 AM   #5
Trsmotrhed
Trsmotrhed's Avatar
Install your existing brake lights to the two pins near the front. When you hit your brakes it applies power for your brake lights. The two far back pins are just the opposite, power is always there when pedal is not depressed. When you hit your brakes it kills the power to the lead marked TCC which unlocks the converter.
63 SWB C10
Old 03-10-2013, 08:06 PM   #6
TxRat
TxRat's Avatar
I used a late 80's brake light switch. I also used needle nose pliers to put the wires on the switch after it was installed. No problems..
TxRat is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
