Old 03-10-2013, 03:23 PM   #1
jmking9
jmking9's Avatar
1970 swb c-10
Finally getting around to starting a build thread. First, a little history on the truck. I bought this truck in 1996 when I was 14. It was a 70 Long bed with a 350/350 that was in really good shape. A friend of my dads owned a little car lot and took it in on a trade. He knew I had been looking for a 67-72 so he gave us a call the evening he traded for it. An hour (and an empty savings account from mowing yards) later, I had purchased my first truck. I drove it daily through high school and the first year of college. Then it sat for several years without being drove much. I always wanted to make it a shortbed and restore it myself. It was just a matter of having the time/space/money to do it. I have been working on it slowly for about 4 years and have recently made a strong push toward finishing it. I will add pics and descriptions untill I get caught up with where it is today. First a couple of pictures from when I first got it.
1970 SWB Build
jmking9 is offline   Reply With Quote
Old 03-10-2013, 03:25 PM   #2
jmking9
jmking9's Avatar
Re: 1970 swb c-10
Junior Prom
1970 SWB Build
Old 03-10-2013, 03:36 PM   #3
jmking9
jmking9's Avatar
Re: 1970 swb c-10
The first thing I did was rebuild the tired 350. Some specs on the motor:
*355ci
*Edelbrock RPM aluminum heads
*Edelbrock RPM air gap intake
*Comp cams Xtreme Energy 284 cam
*Comp 1.6 roller rockers
*Edelbrock 750 carb
*MSD dist/ign
I had the transmission rebuilt and b&m 3500 converter
1970 SWB Build
Old 03-10-2013, 03:43 PM   #4
jmking9
jmking9's Avatar
Re: 1970 swb c-10
Found a shortbed frame. Sand blasted and painted it with eastwood chassis paint.
1970 SWB Build
Old 03-10-2013, 04:09 PM   #5
jmking9
jmking9's Avatar
Re: 1970 swb c-10
I blasted all the frontend parts and completely rebuilt everything. I also installed a ECE 4.5/6 drop kit and disc conversion and Inline Tube brake lines.
A few pictures from the frontend assembly.
1970 SWB Build
Old 03-10-2013, 04:17 PM   #6
jmking9
jmking9's Avatar
Re: 1970 swb c-10
A couple more of the front end
1970 SWB Build
Old 03-10-2013, 04:23 PM   #7
jmking9
jmking9's Avatar
Re: 1970 swb c-10
Some pictures of the rear suspension. 6in ECE springs, shock relocaters, super track bar. Rearend is a 3.73 Posi BTW
1970 SWB Build
Old 03-10-2013, 04:29 PM   #8
jmking9
jmking9's Avatar
Re: 1970 swb c-10
Rolling chassis completed. Wheels are REV Classic 100 20x8 front with 255-40-20 toyo proxis. Rear is 20x10 with 295-40-20 toyos
1970 SWB Build
Old 03-10-2013, 04:33 PM   #9
jmking9
jmking9's Avatar
Re: 1970 swb c-10
I sold my long bedsides and bought a set of reproduction short bedsides. My floor was in very good shape so I cut it down and re-used it along with the wheel housings and front panel. A reproduction tailgate completed the bed assembly
1970 SWB Build
Old 03-10-2013, 04:35 PM   #10
jmking9
jmking9's Avatar
Re: 1970 swb c-10
bed
1970 SWB Build
Old 03-10-2013, 04:36 PM   #11
jmking9
jmking9's Avatar
Re: 1970 swb c-10
Made a couple of small changes in the look of the motor.
1970 SWB Build
Old 03-10-2013, 04:38 PM   #12
jmking9
jmking9's Avatar
Re: 1970 swb c-10
CPP power booster, master cyl, and prop valve Pic is from when I did a mock up a while back. I have to run a vaccum canister due to the size of the cam.
1970 SWB Build
Old 03-10-2013, 04:45 PM   #13
jmking9
jmking9's Avatar
Re: 1970 swb c-10
Got the truck put together in the spring of 2012 and drove it like this all through the summer. I put quite a few miles on it, and got alot of the bugs worked out. It runs and drives great. This made me really hate the thought of taking in apart for paint and body. But I did it anyway.
1970 SWB Build
Old 03-10-2013, 05:01 PM   #14
jmking9
jmking9's Avatar
Re: 1970 swb c-10
Thought I'd throw in a couple pictures of my son in the truck last spring. He LOVES sitting in the truck and pretending to drive.
1970 SWB Build
Old 03-10-2013, 05:09 PM   #15
lolife99
Old Guy
lolife99's Avatar
Re: 1970 swb c-10
Very nice!
Keith
Convert to disc brakes.
WTB: Radio Delete Plates and clips.
Old 03-10-2013, 05:14 PM   #16
jmking9
jmking9's Avatar
Re: 1970 swb c-10
Last fall I took it apart and did the rust repair on the cab. It wasn't too bad, outer floors, braces, cab corners, and rockers. (You know, the usuall) Everything went together very well.
Once i had this done I reasembled the body to make sure everything lined up. I replaced my doors with a really nice set that I bought from a board member Joes Junk a few years ago. My doors were in decent shape, but these were perfect. Since the truck is already a collection of parts anyway, it didn't bother me to use these on it. i plan on repairing my original doors and keeping them for a future project. heres some pictures from the final mock up. Took several late nights to get the panels to line up. They arent perfect, but they werent from the factory.
1970 SWB Build
Old 03-10-2013, 05:26 PM   #17
jmking9
jmking9's Avatar
Re: 1970 swb c-10
Next was paint. I started with the cab. I am using PPG omni for my epoxy and high build. This is the first vehicle I have ever painted. I have known all along that I wanted to do the paint work myself. Since I have done everything else up to this point in my shop, I figured I would give it a go. I painted several practice hoods untill I was confident in my technique. Then dove in...
1970 SWB Build
Old 03-10-2013, 05:27 PM   #18
jmking9
jmking9's Avatar
Re: 1970 swb c-10
Cab roof blocked out and ready for sealer.
1970 SWB Build
Old 03-10-2013, 05:29 PM   #19
jmking9
jmking9's Avatar
Re: 1970 swb c-10
Completely painted the interior. Color is 526 med gold
1970 SWB Build
Old 03-10-2013, 05:34 PM   #20
jmking9
jmking9's Avatar
Re: 1970 swb c-10
This is after the Color and clear went on the cab. Again, PPG 526 gold/White base and PPG 2021 concept clear. I am very happy with the results. It is not going to win an award at SEMA, but its better than I ever imagined I could pull off in the shop with no booth.
1970 SWB Build
Old 03-10-2013, 05:37 PM   #21
jmking9
jmking9's Avatar
Re: 1970 swb c-10
Next was the fenders, doors, cowl, and hood
1970 SWB Build
Old 03-10-2013, 05:39 PM   #22
jmking9
jmking9's Avatar
Re: 1970 swb c-10
Hung some of the front sheetmetal. Its starting to look like a truck again.
1970 SWB Build
Old 03-10-2013, 05:45 PM   #23
jmking9
jmking9's Avatar
Re: 1970 swb c-10
And this is where I am as of today. Finished painting the tailgate yesterday. All I have left is the bed. After the bed is painted, I will try my hand at cut and buffing. This part makes me nervous, but I figure no guts no glory. It looks pretty good as it is, but i want to make it even better. I guess i'll cross that bridge when I get to it.
Once I get the body assembled, I'll roll it out in the sun and get some better pictures of it with a real camera. (instead of the crappy cell phone pics)
Anyway, My goal is to finish the truck this summer in time to drive it about an hour and a half from here to Branson MO for the Shepherd of the Hills Cruise. Not that there is anything really special about this show, I just needed a goal. We'll see...
1970 SWB Build
Old 03-10-2013, 05:51 PM   #24
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: 1970 swb c-10
Love this project!!!
Hope to see it around this year.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 03-12-2013, 03:03 PM   #25
jmking9
jmking9's Avatar
Re: 1970 swb c-10
Brown left this on my porch yesterday. I opened it up and it looks like fun. Does anyone know if I would just be better off renting the crimper tool from AAW or is there a better option?
1970 SWB Build
Thread Tools
Display Modes
Copyright ©2000 - 2022, vBulletin Solutions Inc.
