Old 03-21-2013, 12:49 AM   #1
C10chevy1966
C10chevy1966's Avatar
carrier bearing question
i have to replace to carrier bearing in my 66 lwb c10 how do i figure out which bearing i have . my whole thing is shot rubber and all. please help. pics would help im chevy stupid.
C10chevy1966 is offline   Reply With Quote
Old 03-21-2013, 12:53 AM   #2
Captainfab
60-66 Nut
Re: carrier bearing question
Is it the whimpy light duty one that hangs from the top of the trailing arm crossmember, or is it the 'D' shaped heavy duty one that sits on a plate on the bottom of the trailing arm crossmember?
Here is a pic of the heavy duty one.
Old 03-21-2013, 01:02 AM   #3
HugoV
Subscribed
HugoV is offline   Reply With Quote
Old 03-21-2013, 02:01 AM   #4
RockTonka
RockTonka's Avatar
here's a pic of the wimpy one...
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 03-21-2013, 06:33 PM   #5
C10chevy1966
its the whimpy one now does anyone know the size measurement on it?
Old 03-22-2013, 03:02 PM   #6
joe750
joe750's Avatar
if you're wanting to put the same thing back in there, your local NAPA or auto parts store should be able to get it.
The NAPA here had one on the shelf.
Just told them the year and model. It ran about $34
It makes for a good excuse to change out those old universal bearings too
'66 c10 LWB fleetside 250 I6 3 speed on column
'65 c10 LWB stepside 350/327 3 speed hasn't moved in 10 years. Just rotting away
joe750 is offline   Reply With Quote
Old 03-22-2013, 05:48 PM   #7
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
I don't believe it's just a matter of buying a HD one instead of the regular one either. for one thing, I believe the HD ones take a shaft with a slip joint. You really don't need to know the size, as Joe750 said. I've bought them 2 ways: complete with new hanger, assembled; and just the rubber/bearing. you're going to have to take the yoke off the rear of the front shaft to change the bearing out.
Larry
fleetsidelarry is offline   Reply With Quote
Old 03-22-2013, 06:01 PM   #8
C10chevy1966
thank you everyone now soon as it dries out down here ill be under truck .then its on to the next fix
Old 03-23-2013, 12:25 PM   #9
joe750
joe750's Avatar
Oh yeah, and I don't know how you're going to go about changing it... but your life will be so much easier if you take the whole driveshaft out in one piece and get it out from under the truck.
There's two small U bolts that connect it to the rear end. Remove those, unbolt you're carrier bearing from the crossmember, and slide then slide the whole thing off the tail shaft.
Old 03-23-2013, 01:21 PM   #10
RockTonka
RockTonka's Avatar
The carrier bearing will be sandwiched between the shaft and intermediate yoke on a short splined shaft. Definitely easier to do out of the truck...
My build thread
Old 03-24-2013, 12:02 AM   #11
rustbucket66
One important thing to remember is to mark the middle yoke and the driveshaft tube before you take it apart, so it goes on the same position when you put it back together. You could put it back together out of phase, or in phase but 180 degrees off how it was when it came apart. It is balanced in the position it was before it came apart. Put it together the same, and there won't be any vibration or balance issues.
rustbucket66 is offline   Reply With Quote
Old 03-24-2013, 09:15 AM   #12
fleetsidelarry
Senior Car Nut
I thought it only went together one way, here's the one I put on mine, IIRC the shaft had a corresponding "wide-spline":
and, Woog, I think the HD one needs a rear shaft with a sliding yoke but I'm hoping Captainfab (or someone) will verify when they respond to your question
Larry
Old 03-24-2013, 11:00 AM   #13
rustbucket66
That one only goes on one way, which is good so you can't make a mistake. They aren't all like that, mine isn't. It is also important to mark a slip joint if you take it apart. Tow truck drivers like to just pull them apart to tow the vehicle, so when you put it back together, it might be in phase, but it could be out 180 degrees, with the heavy side AND the weight will be on the same side causing a bad vibration.
Old 03-24-2013, 11:50 AM   #14
fleetsidelarry
Senior Car Nut
thanks for clarifying, rustbucket
Larry
Old 03-24-2013, 12:00 PM   #15
joe750
joe750's Avatar
Woogeroo,
I don't know if you've seen or not but LMC sells a heavy duty carrier bearing.
It is a solid piece that does away with the spot welds and pinch seams.
I can't remember if it is D shaped that bolts to the bottom or just a direct, solid replacement.
I just remember seeing it while browsing through a catalog.
I'll definitely be buying it the next time mine goes out
Old 03-05-2017, 11:41 PM   #16
kevinjr
Hello new guy but a old guy that was a member back in the early 2000.Sold a 66 4x4 and 66 2wd when i moved to a smaller building .Now i just bought my 64 2wd long bed .The question i have is i need my carrier bearing changed out
i cant do it my self my back is fused its a little out of my range now .Do any of you guys know some one from the chicago area that works on these trucks .
Or how do i search for members from chicago .I also will soon remember how to post pictures soon.
Thanks Kevin
kevinjr is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
