Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 03-22-2013, 08:56 PM   #1
lolife99
Old Member
lolife99's Avatar
Longer a-arms for the BAGGED, S10 framed, trucks,...
Michigan Metal Works has a new longer a-arm for you S10 framed 47-54 (55 1st series) guys.
Check them out here:
http://michiganmetalworks.com/
http://www.facebook.com/MichiganMetalWorks
Have a 47-54 Chevy Truck that you want to swap an S-10 Chassis underneath?
We whipped up a set of these conversion arms for a customer who is swapping a mid 90's S-10 Chassis onto a 47 Chevy body.
The arms push the wheels out to fill the fenders correctly and run an inboard shock to maximize your turning radius compared to stock arms.
They lay on 22s, with ease, and come with a steering kit to wrap it all up!
Keith
Convert to disc brakes.
WTB: Radio Delete Plates and clips.
Old 03-31-2013, 02:12 PM   #2
Larry Lindley
Re: Longer a-arms for the BAGGED, S10 framed, trucks,...
they look nice but whats the Price?
Larry Lindley is offline   Reply With Quote
Old 03-31-2013, 04:25 PM   #3
mr48chev
mr48chev's Avatar
You can kind of judge the price by looking at their other prices. Those pieces are pretty heavy as they are made out of plate steel.
Longer a arms are something that the S-10 swap guys have needed all along though.
Scott: How about a longer Tube A arm with matching tie rod sleeves package for these guys?
If you can't fix it with a hammer, you have an electrical problem.
My ongoing truck projects:
Old 05-09-2013, 11:43 AM   #4
98layinframe
98layinframe's Avatar
I would seriously consider running an offset upper bag cup/mount that pushes the bag out towards the spindle another 1" or more, otherwise the pressures to lift the truck will be alot higher and the ride will be very soft due to the increased lever ratio.
91 s10 - bagged bodydropped 4", 350/700R4, narrowed reared, cantilever rear air bag setup
1951 chevy 3100 - in build/acquiring parts process. Have full C4 Corvette suspension front and rear, tpi 350, 700r4, 18" torque thrust II wheels
98layinframe is offline   Reply With Quote
Old 06-22-2013, 03:31 PM   #5
Jeebus
Jeebus's Avatar
The kit comes with an offset bag cup, pushes the bag out 3/4" toward the spindle.
It rides great, so far have tested in LS swap motors, SBC swapped motors, without issue. Ride quaity is much improved, with the better shock options available instead of the puny s10 shocks, something to actually work correctly with the weight of the truck up front.
Taylor
Oops!
Jeebus is offline   Reply With Quote
Old 11-21-2013, 06:31 PM   #6
mcdonald77
mcdonald77's Avatar
Sorry to bump an old thread, but does anyone have more pics of these arms installed? I am thinking of using them on my LS swapped Jimmy to get rid of the 2" wheel adapters. I will be using them with ridetech coilovers. I've search but only found the above posted photos. Is Anyone running a 18x9.5" wheel with them?
mcdonald77 is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
