Old 04-13-2013, 05:25 PM   #1
jbgroby
jbgroby's Avatar
How to attach the inner fender dust sheilds
I was able to pick up a set of OEM inner fender braces and new dust shield rubber from Tony at 4-5-6 chevy (Thank You) Does any one have an explaination on how to attach them of a guideline on placement?
Is it as simple as stripping some copper wire and making staples?
jbgroby is offline   Reply With Quote
Old 04-13-2013, 07:37 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: How to attach the inner fender dust sheilds
Yep! That's exactly what I did. I clamped them together drilled small holes and ran the wire.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-13-2013, 07:37 PM   #3
65chevysub
65chevysub's Avatar
I made staples out of some small wire several years ago. I made a radiator seal for my 65 out of some material I had purchased and used the original holes. It looks factory. Good Luck.
65chevysub is offline   Reply With Quote
Old 04-13-2013, 08:01 PM   #4
jbgroby
jbgroby's Avatar
Anybody got a pic I'm trying to get them to set right?
Old 04-16-2013, 09:21 AM   #5
rossboss
rossboss's Avatar
I just used staples out of my staple gun. I held the piece of rubber in place and drilled holes in the rubber using the existing holes in the metal piece as a guide. The staples fit perfect, just shoved them through the rubber and bent them over.
rossboss is offline   Reply With Quote
Old 04-16-2013, 10:55 AM   #6
cru_zn_29
cru_zn_29's Avatar
Stainless paper clips has worked for me. You can reshape to fit old holes.
kenny
cru_zn_29 is offline   Reply With Quote
Old 04-16-2013, 11:24 AM   #7
jbgroby
jbgroby's Avatar
Thanks for the picture, that helps me a lot (worht a thousand words) will use copper wire, AND some adheavsive - I likes lots of protection
Old 04-17-2013, 12:50 PM   #8
63burban
Chevy addict
I have stainless staples here just for that purpose, I use a hammer and dolly to bend them over after drilling the holes.
63burban is offline   Reply With Quote
Old 04-17-2013, 01:26 PM   #9
par4tom
I used a rivet gun. Drilled some holes through the molding and sheet metal, put some RTV adhesive on both the panel and molding, stuck them together and used a rivet.
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=705185
How to Get Audiophile Sound in 60-66 Trucks
http://67-72chevytrucks.com/vboard/s...=1#post7236896
Building Your Own Speaker Kick Pods
http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495
par4tom is offline   Reply With Quote
Old 04-17-2013, 01:44 PM   #10
slorio
slorio's Avatar
Jake:
I used floral pins. I have a picture of them here:
http://67-72chevytrucks.com/vboard/s...57#post4310757
Hope this helps.
Regards,
Steve
New Orleans
slorio is offline   Reply With Quote
Old 04-17-2013, 03:17 PM   #11
jbgroby
jbgroby's Avatar
hey thanks steve, this way I don't need bend much!
Jake
Old 04-17-2013, 08:52 PM   #12
64tantruck
64tantruck's Avatar
Hi all. the corvairs "tins" ave the same type of staple to hold the rubbers. You can but the stainless steel wire from Clarks Corvair also.
Glenn
Glenn Korec
Jamesville NY
64 C20 350ci Turbo 350 tranny 3.73 gear with air ride.
61 Apache10 (wife's truck) 327ci powerglide.
http://67-72chevytrucks.com/vboard/s...d.php?t=570100
64tantruck is offline   Reply With Quote
Old 04-18-2013, 12:39 PM   #13
61K10
61K10's Avatar
ok--now that the seals are on what is used to mount them back on the fenders? the stock inserts are gone. pop rivet or self tapers?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 04-18-2013, 02:49 PM   #14
jbgroby
jbgroby's Avatar
456chevy has the clips, they came with my package.
Old 04-19-2013, 12:19 PM   #15
61K10
61K10's Avatar
thanks jb--i bought some from somebody and they were too small. will ck out 456--
1961 chevy K10
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
