Old 04-27-2013, 09:49 AM   #1
PatrickGMC70
PatrickGMC70's Avatar
Temp sensor question
I'm rebuilding my engine and I'm at the point where it's going back together.
It looks like I have two temp sensors in the block - one is the light style and the other is the gauge style. My dash has a temp gauge (I'm not sure if it has a light and can't check at the moment because the truck isn't here)
The manual says that one head has the temp sensor and the other is oil pressure. But I thought my oil pressure was that little line that come out the back of the block near the distributor.
Can anyone clarify this for me? If I'm supposed to have two temp sensors does it matter which one goes in which head?
Thanks,
Patrick
Pic below:
Oh, one other thing, what is this? It was bolted to the intake manifold.
PatrickGMC70 is offline   Reply With Quote
Old 04-27-2013, 10:03 AM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Temp sensor question
So you had one of those senders in each head? The factory location for sending units is the drivers side head only. Unless someone ran another temp sending unit in the passenger head to run a thermostat for electric fans. But they both are factory style senders. I'm sure there were some applications that used 2 sending units. But I haven't a clue on that...
I have gauges as well in my '72 GMC and have the one in the top of the pic located in my drivers side cylinder head.
The hunk of metal in your lower pic looks like a part of the "spark knock control" unit from a '72 truck. There should have been a wire harness that went to it. I had that on my truck as well when I bought it. I removed the whole assemply and wire harness toot sweet. I also completely rebuilt the engine and used a Holley carb and Edelbrock intake.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
GASoline71 is offline   Reply With Quote
Old 04-27-2013, 10:04 AM   #3
rkn463
rkn463's Avatar
I'm assuming a small block Chevy ( not that familiar with the big block layout). Anything on the head is water temp, the small hole by the distributor is oil pressure. I'm a fan of the gauge and a light to get attention.
-Richard
I may have too many Chevys... Is that possible?
68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713
rkn463 is offline   Reply With Quote
Old 04-27-2013, 12:03 PM   #4
PatrickGMC70
Oh, I guess some details would have helped...
1970 GMC C1500 350, 3OTT. The truck seemed stock, or at least 95% stock.
Driver side hole is near the front of the head (between #1&3) and passenger side hole is near rear of head (between #6$8).
Old 04-27-2013, 12:24 PM   #5
Lattimer
Lattimer's Avatar
You should have had either one or the other of those sensors, not both. Top is for a gauge and bottom is for a light.
Oil pressure is like you stated, and should be 1/8" NPT IIRC.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 04-27-2013, 12:32 PM   #6
PatrickGMC70
If I'm only supposed to have 1, what goes in the other hole? The shop manual says oil switch, but as far as I know, there's coolant in those passages, not oil.
Old 04-27-2013, 12:47 PM   #7
Shyguy
Junior Member
Shyguy's Avatar
All the older engines I have had only had a plug in the passenger side head. Newer engines sometimes has a sensor in the passenger side head to control an auxilary electric fan.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 04-27-2013, 01:00 PM   #8
john
member #16
john's Avatar
Those are part of the TCS system (transmission controlled spark) It only allows vacuum advance when the engine is up to operating temp and in high gear. Temp sender should be in pass side head.
john is offline   Reply With Quote
Old 04-27-2013, 02:20 PM   #9
GASoline71
GASoline71's Avatar
Yup... just a NPT pipe plug. 1/2" I think.
Gary
Old 04-29-2013, 06:56 AM   #10
MikeyMan
My 71 C/10 307, 3OTT has 2 senders.
The top one in your pic is correct for the gauge, mounts in drivers side.
I also have a sender in my passenger side head. It was for the TCS, but the rest of that wiring and controls were removed by the PO.
You can just plug the ps with a 1/2" pipe plug. That's also a good location to run an aftermarket mechanical temperature gauge. 2 readings are better than one.
MikeyMan is offline   Reply With Quote
Old 04-29-2013, 07:27 AM   #11
PatrickGMC70
Thanks everyone. Weird that I had both. I could have sworn there were wires hooked up to both; guess I'll know more when I start putting it back together tonight.
Old 07-29-2013, 01:24 AM   #12
TexasLS1
TexasLS1's Avatar
Reviving an old thread, I know... Does anyone know where to find a new connector/terminal to slide onto the top temp sending unit? I want to replace the wire and the connector but couldn't find one at the parts store. Does a regular female connector that would slide onto a spade work?
TexasLS1 is offline   Reply With Quote
Old 07-29-2013, 05:48 AM   #13
MikeyMan
Yes, I believe a regular female crimp connector will work.
You might have to tweak it a little. You may have to spread it open slightly. Pry it with a super skinny screwdriver or pocket knife. Squeeze it with a needle nose pliers if it's too loose. Adjust it for a snug fit over the sender tit before you crimp it on the green temperature wire.
The green temperature sending unit wire is a pretty small gauge, like maybe 18ga. So, you'll need a connector for that size wire. A Red or Blue should do, Yellow will be too big for that wire. Make sure everything fits snug to make a proper connection.
Old 07-29-2013, 10:20 AM   #14
FirstOwner69
FirstOwner69's Avatar
Here's a link to the connector you need if you want the original type. This place has just about everything you could want related to electrical connectors.
http://www.repairconnector.com/produ...Connector.html
FirstOwner69 is offline   Reply With Quote
Old 07-29-2013, 10:42 AM   #15
Lattimer
Lattimer's Avatar
Thanks for posting. I needed that also!
Shawn
Thread Tools
Display Modes
Copyright ©2000 - 2021, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
