Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 99-06 Chevy and GMC Message Board
Old 05-23-2013, 06:04 PM   #1
Rufton
1999 350 vortec K1500 head gasket
My parents 350 has been fouling #4 and #6 for some time; HG or cracked head is suspect.
Recently it starting bleeding coolant out near rear intake manifold flange near drivers side head; this is major problem and has K1500 grounded.
I voted to install new engine but majority vote is to replace HG and maybe one head. I plan to check filter and pan oil for glitter/sludge today; to bad I don't have my filter cutter w/ me.
I could use some help in choosing a quality non-crack prone head.
I don't have service manual so torque specs would help.
Rufton is offline   Reply With Quote
Old 05-23-2013, 06:28 PM   #2
Mykk
Re: 1999 350 vortec K1500 head gasket
Those Vortec 350's are known for intake gasket issues, mostly due to dexcool. Felpro has a revised updated gasket for the application.
That intake gasket separates coolant and oil from air/fuel. I would first replace the intake gasket and go from there.
If your not satisfied after that, do a compression test on all cylinders (for comparative figures) and the coolant test strips.
Cheers ~Mykk
Mykk is offline   Reply With Quote
Old 05-23-2013, 08:02 PM   #3
Rufton
Thanks, I will look for the most expensive Felpro intake gasket.
Old 05-23-2013, 08:11 PM   #4
Rufton
Oil filter element was nearly glitter free. Looks like Head/Intake project is a go. Apparently running a leaky HG for a few years doesn't always destroy engine. Coolant does contaminate oil post radiator pressure testing. I've heard coolant will destroy bearings but apparently bearings can survive. I found no coolant in filter though. Oil was a pretty ebony black
Maybe coolant leaked into cylinder during radiator pressure testing then leaked past piston rings over night. Maybe coolant is burned up in cylinder instead of contaminating oil. If oil was coolant contaminated maybe it would look milky instead of black?
Old 05-23-2013, 08:48 PM   #5
clinebarger
Cheers ~Mykk
The gaskets are a bad design, Dexcool is not to blame for that.
Fel-Pro MS98000T are gaskets you want, I agree with Mykk....Sounds like intake gaskets.
clinebarger is offline   Reply With Quote
Old 05-23-2013, 10:54 PM   #6
Rufton
Thanks for PN cline.
#4 and #6 have lower compression and foul plugs. That's why I suspect bad HG in addition to bad intake.
Old 05-24-2013, 09:35 PM   #7
Rufton
My bad, #3 and #5 are the low compression plug fouling cylinders.
I was impressed; no sludge at all under VC after 160,000 miles w/ pennzoil dino oil.
Dropped pan oil and no water after recent coolant pressure test; did have water when I pressure tested last year.
Unless I'm missing something head needs to be pulled due to low #3 and #5 compression.
There was black buildup on aluminum intake under plastic intake; not sure why.
Have yet to figure out how to remove bracket attached to back of engine; pass side plug wires under bracket; bracket also attaches at coil.
Old 05-25-2013, 04:47 PM   #8
Rufton
This may be the #3 and #5 coolant plug foul leak. It is very hard to see. Slight discoloration under correct light.
Old 05-25-2013, 05:07 PM   #9
Rufton
Filled intake ports then exhaust ports w/ gas. Some valves leak about 1 tsp per hour.
Old 05-25-2013, 05:15 PM   #10
Rufton
More pics shows how faint leak evidence is.
Old 05-25-2013, 10:49 PM   #11
crazy longhorn
Fabricate till you "puke"
The bores don't look too bad for a 160,000 mile engine....with the valves leaking a little Liquid, You might opt for a mag/grind & surface on the heads? AL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 05-25-2013, 11:25 PM   #12
Rufton
I can't feel any ridge at all w/ finger nail (in the carbon free areas of course).
Yeah, at the cross roads deciding what to do w/ head(s).
HG still suspect but just not sure why #3 and #5 fouling.
Plan to pull valves tomorrow.
I would like to get prices on decent heads for compare to machine shop costs; any advice for good cyl heads?
Could a head crack that has leaked for a few years still be invisible to naked eye?
Old 05-25-2013, 11:30 PM   #13
crazy longhorn
I ? a couple spots on the heads....Maybe Cline will chime in....he is the Gm tech, & well respected by all AL
Old 05-25-2013, 11:58 PM   #14
Rufton
What is that junk in the intake runners?
Some EPA stuff?
The injector spider leg portion of intake is coated w/ it.
Old 05-26-2013, 05:56 PM   #15
Rufton
Found why 3E failed gasoline leak test. Don't think that is enough to foul plug. Maybe enough to cause lower compression reading.
Old 05-26-2013, 06:12 PM   #16
Rufton
Smart camera auto-focus thinks I'm taking picture of face.
That's a head, silly camera
Old 05-26-2013, 07:16 PM   #17
clinebarger
A cracked head &/or a blown head gasket will put combustion gases in the coolant, Displace the coolant....Then the engine will get hot. I didn't read any of this as a symptom in your posts??
Coolant fouled plugs are a symptom of the engine sucking coolant on the intake side.....Vortecs are Notorious for doing this, I saw one a few weeks ago that filled #2 cyl. full of coolant & hydrolocked with NO external leaks at 50,000 miles....It was just intake gaskets.
If your head is cracked it would be in the intake port, That is Highly unlikely.
Compression test are just about worthless...Unless something major is wrong.
Ive seen engines with a low of 120psi & a high of 160psi on different cylinders run fine. What was your readings anyway??
A leak-down test is the only true way to know a cylinders ability to seal.
Get the head Magna-Fluxed, Lap the valves yourself, & Put it back together.
Old 05-26-2013, 09:52 PM   #18
Rufton
Thanks cline. I am planning to lap valves and feeler gauge flatness. I will price magna-flux job.
Compression test last year. FWIR readings roughly 135 to 165.
Ran perfect until plug foul. Mpg seems off. temp perfect. Coolant looked good till stop leak; I flushed out yukky stop leak. Mild oil consumption.
Worst fouled plug is #3; seems far from intake port.
Only time it got hot was after blew a plastic hose fitting. Hot event caught early. Ran less than 1 mile uphill to safe shoulder. Engine didn't seem that hot and it was winter time. Temp gauge climbed but don't think it pegged.
Engine never had low oil pressure event.
Old 05-27-2013, 10:54 PM   #19
Rufton
Felpro offers 2 head gasket sets. Not sure which is better?
Maybe the PermaTorque Severe DutyŽ head gskts shown below?
Old 05-28-2013, 12:39 PM   #20
Rufton
Riverside Machine Shop does good work. The owner looked at head and plugs, and considered symptoms.
Diagnosis is most likely worn oil control ring plus slight head gasket seepage.
Head gasket seepage is not uncommon after many years of thermal cycles.
Not sure if coolant leak affected oil control ring.
Old 05-28-2013, 10:11 PM   #21
BarryB
BarryB's Avatar
Pm me, if it turns out you need parts or Heads. I know a (used to be a member on here)friend in greenville, that has all kinds of parts for these trucks. Since your in Knoxville. It wouldn't be a bad trip.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 05-29-2013, 12:59 AM   #22
Rufton
Thanks. Right now my parents are interested in buying a K2500 L31 HD 4 bolt main 12530283 engine to replace the K1500 L31 2 bolt main 12530282 engine.
I think it will be a bolt in deal.
Differences seem to be:
4 bolt vs 2 bolt main.
small stem vs 3/8" stem valves.
HD vs SD vlv seats.
12 month vs 3 year warranty.
4L60E vs 4L80E flex plate and starter.
$40 price difference.
Similarities seem to be:
head bolts
harmonic balancer
upper intake
lower intake
pan
H2O pump
crank shaft
balance shaft
oil filter
etc
Old 06-03-2013, 09:35 PM   #23
Rufton
Got the 4 bolt today and it mated to the bell and engine mounts fine. Next I will clean the nasty intake. I'm deleting all proprietary heater hoses all the way to rear core. I deleted the 4 nipple heater hose valve. I'm deleting oil cooler also. May delete the pain in the... bracket attached to rear pass head. I'd like to delete more in the interest of maintainability but I'll behave.
Old 06-03-2013, 10:12 PM   #24
clinebarger
The bracket needs to stay, It supports the harness & shields it from the plug wires.
Old 06-03-2013, 10:24 PM   #25
Rufton
OK. I'll behave w/ the bracket.
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
